Greylisting by subnetwork
Please store in the greylist triplet only the subnet part of the IP, such as 123.123.123.* or even 123.123.*.*.
Reason: Many services nowadays use multiple (often hundreds if not thousands) IPs for sending mail. Such mail never passes greylisting because each connection attempt is made from a different IP.
Bypassing greylisting by SPF may alleviate the problem for large services that have their SPF correctly configured, but I have seen too many legitimate servers, such as university department servers, that do not have SPF correctly configured, so mail from them never passes greylisting.
This renders greylisting unusable since the damage from missing an important business message is much greater than the annoyance from spam.
However, such servers usually use addresses from the same subnetwork, such as 123.123.123.11, 123.123.123.12, 123.123.123.13, etc. Identifying the sender by the subnet, such as 123.123.123.*, would GREATLY reduce missed messages and GREATY improve delivery time from such servers, while almost not increase chances for a spam message to pass.
Re: Greylisting by subnetwork
hMailServers internal design isnt ready for such massive tasks. If you want to block thousands of IPs with a fast rate its a job for the Windows Firewall or a DMZ Gatekeeping Firewall. The other mitigation technique for such scenarios is blocking entire DNS-Zones at DNS-Server level (for example: Bind DNS-Server RPZ DNS-Firewall feature allows something like this).
Yes, greylist whitelisting IPs by CIDR notation could be really helpful!
Another nice option would be by domain like in postgrey. Then with one rule we could for example whitelist Outlook/Office365: *outbound.protection.outlook.com
Well...
Option Explicit
' ********** Settings **********
' COM authentication
Private Const PASSWORD = "You'd like that, eh?"
' ********** Functions **********
Function Wait(sec)
' .Run "sleep -m " & Int(sec * 1000), 0, True
' .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True
Function LockFile(strPath)
Const Append = 8
Const Unicode = -1
Dim oFile, i
For i = 0 To 30
On Error Resume Next
If Not (Err.Number = 70) Then
Set LockFile = oFile
On Error Goto 0
Exit For
On Error Goto 0
Wait(1)
Set oFile = Nothing
If (Err.Number = 70) Then
Err.Clear
ElseIf (Err.Number <> 0) Then
EventLog.Write("Error : " & Err.Number)
EventLog.Write("Source : " & Err.Source)
Err.Clear
.Global = False
.Pattern = strRegEx
.IgnoreCase = True
' ********** Subroutines **********
Sub GreyWhiteList(strIP, strDesc)
With LockFile("c:\hmailserver\temp\greywhitelist.lck")
oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Refresh
If (oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP) Is Nothing) Then
With oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Add
.Description = "# " & Date & " " & strDesc
.IPAddress = strIP
.Save
With oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP)
.Save
On Error Goto 0
.Close
Sub ExpireGreyList
Dim j, m_Days : m_Days = 30
For j = oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Count-1 To 0 Step -1
If (Left(oApp.Settings.AntiSpam.GreyListingWhiteAddresses(j).Description, 1) = "#") Then
If (DateDiff("d", Mid(oApp.Settings.AntiSpam.GreyListingWhiteAddresses(j).Description,3,10), Date) > m_Days) Then
oApp.Settings.AntiSpam.GreyListingWhiteAddresses(j).Delete
' ********** hMailServer Triggers **********
Sub OnHELO(oClient)
Dim strRegEx
' Dynamic GreyList Whitelist
strRegEx = "^[a-z]+[0-9]{2}(-)[a-z]{2}[0-9](-obe\.outbound\.protection\.outlook\.com)$|" &_
"^(((mail134-)[0-9]{1,3})|((out22-)[0-9]{1,2}))(\.mail\.alibaba\.com)$|" &_
"^(a)[0-9]{1,2}(-)[0-9]{1,3}(\.smtp-out\.amazonses\.com)$|" &_
"^(mail-)[a-z]{2}[0-9](-f)[0-9]{1,3}(\.google\.com)$|" &_
"^(spring-chicken-)[a-z]{2}(\.twitter\.com)$|" &_
"^(mail)[a-z](-)[a-z]{2}(\.linkedin\.com)$|" &_
"^(mx)[0-9](\.)[a-z]{3}(\.paypal\.com)$"
If Lookup(strRegEx, oClient.HELO) Then
Call GreyWhiteList(oClient.IPAddress, oClient.HELO)
As usual, excellent work SorenR
From research I've found that the OnHELO sub is only populated on the second connection. This happens only with StartTLS connections to your mailserver.
On first OnHELO connection, oClient.helo is blank
After negotiating a successful StartTLS, OnHELO is triggered a second time, and this time oClient.helo is populated appropriately.
So, I think for this script to work, hMailserver needs a SSL certificate installed, and to have 'StartTLS (optional)' set for port 25, and for the sending server to try StartTLS.
All legitimate connections from outlook.com are StartTLS enabled were accepted
Ah.. I don't use TLS, it's either SSL or No SSL and unsecure connections are receive-only Don't like to give people a choice when it comes to securitymattg wrote: ↑2018-07-12 00:22As usual, excellent work SorenR
Actually, I have switched off Greylisting since several months ago...
I use a 20 second delay on "OnClientConnect", "OnHELO" and "OnSMTPData" and that seems to filter out the worst hogs.
Then I filter the HELO/EHLO greeting ... and impose a complete rulebook of SPAM Catchers before delivering mail to recipients - that is, some mails go to my SPAM account - ONLY!
An important note ... My Rules are NOT processed if SpamAssassin/DNSBL/SURBL/SPF/DKIM found something fishy. If it's SPAM, it's SPAM. It cannot be more or less SPAM!
By not refusing everything (I Ban only when absolutely positive it's a SPAMMER), I can set up whitelists to capture mis-configured mailservers or fix my own prejudice.
This RegEx "/(iPhone (3G|4|5|6|SE|7|8|9|X)(C|S)?( Plus)?)/gmi" I commonly use in Subject or Body, mostly I'm correct in marking as SPAM, but there are execptions.
.Global = bGlobal
.Pattern = strRegEx
.IgnoreCase = True
Sub OnHELO(oClient)
Dim strRegEx, Match, Matches
' Exclude Backup-MX & local LAN from test
If (Left(oClient.IPAddress, 10) = "80.160.77.") Then Exit Sub
' Filter out "impatient" servers. Alternative to GreyListing.
' Deny servers with specific HELO/EHLO greetings
strRegEx = "^(\[#MY#\.#IP#\.#ADDRESS#\.#HERE#\])$|" &_
"^(#MY#\.#DOMAIN#)$|" &_
"^(#MY#\.#FQDN#\.#HERE#)$|" &_
"^(.*\.[a-z]{4,})$|" &_
"(0\.0\.0\.0)|" &_
"(127(?:\.[0-9]{1,3}){3})"
If Matches.Count > 0 Then
For Each Match In Matches
Result.Value = 2
Result.Message = "5.7.1 CODE02 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means. {" & Match.Value & "}"
Call AutoBan(oClient.IPAddress, "BLACKLIST - " & oClient.HELO, 7, "d")
Exit Sub
' Validate HELO/EHLO greeting
Const myKnown = "^(LouisesPC)$|^(LouisesHuawei)$"
strRegEx = strFQDN & "|" & strIPv4 & "|" & strIPv6 & "|" & myKnown
Result.Value = 2
Result.Message = "5.7.1 CODE03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
Call AutoBan(oClient.IPAddress, "Bad HELO - " & oClient.HELO, 7, "d")
Exit Sub
Thank you for your comments!
I think some of users who commented on this missed my point.
I do NOT mean massive blacklisting, so this does not have anything to do with Windows firewall. If any, my suggestion can be seen as massive whitelisting.
I do NOT ask what other ways of blocking spam there are.
This is a feature request on how greylisting should work in hMailServer.
Currently: by default, all IPs are blocked, but if an IP such as 123.123.123.10 contacts the server, then all four bytes of this IP are stored in the DB, and next time if it contacts the server, it will pass.
My proposal: instead, store in the DB only three first bytes: store 123.123.123, so next time when any IP in the range 123.123.123.0 to 123.123.123.255 (that is, 123.123.123.*) contacts the server, it is unblocked.
This is very minor change to the code (a couple of lines of code: just set the last byte of the IP to 0 when storing it in the DB and when checking the new IP against the DB), which will GREATLY improve usability of hMailServer and the quality of life of its users.
I can provide the specific line of the code that is to be changed.
Actually here is it:
In the file GreyList.cpp, after line 45:
replace
std::shared_ptr<GreyListTriplet> pTriplet = PersistentGreyList::GetRecord(sSenderAddress, sRecipientAddress, remoteIP);
by
std::shared_ptr<GreyListTriplet> pTriplet = PersistentGreyList::GetRecord(sSenderAddress, sRecipientAddress, remoteIP & 0xFFFFFF00);
and
pTriplet->SetIPAddress(remoteIP);
by
pTriplet->SetIPAddress(remoteIP & 0xFFFFFF00);
That's all that you need to make thousands of people a lot happier and more productive. Not too complicated, either.
replace
by
and
by
i agree, partially.gelbukh wrote: ↑2018-09-11 04:58My proposal: instead, store in the DB only three first bytes: store 123.123.123, so next time when any IP in the range 123.123.123.0 to 123.123.123.255 (that is, 123.123.123.*) contacts the server, it is unblocked.
however particularly big providers (Hotmail, Gmail...) rotate beyond /24.
Greylisting in HMS (as it is) is useless in time/mission critical email exchange. this has been discussed :
http://www.hmailserver.com/forum/viewto ... ng#p185133
HMS 5.7, MariaDB 10.4.10, SA 4.0.0, ClamAV 0.103.8
Yes, big providers rotate beyond /24. My proposal will alleviate this problem 255 times, even if will not solve it completely. Ideally, the mask is to be user-configurable (maybe /16 is a better value by hit/miss balance, we don't know), if you are willing to modify more than two lines of code.
Yes, greylisting is bad for time-critical exchange (email is bad for it anyway). But without greylisting, email is useless at all -- all messages are lost in spam. Spam filters are much worse for mission-critical exchange than greylisting. So, with greylisting, a tiny fraction of users potentially may experience delays with a tiny fraction of their messages (for almost all users, almost all messages are not time-critical); without greylisting most users lose most of their messages (just not seeing them in the heap of spam) or lose mission-critical messages (caught in spam filters). I prefer to lose a tiny fraction over losing it all, but those in time-critical business can just turn it off.
I used to run GreyListing and a custom script to cater for a dynamic host list (5'th post in this thread ), but have now skipped it completely. I have a 20 second wait inserted for port 25 at "Sub OnClientConnect(oClient)", "Sub OnHELO(oClient)" and "Sub OnSMTPData(oClient, oMessage)" and it works just as fine, actually better
After having fought the fu***ers for a couple of years now, I do see less and less meaningless traffic - except for the occational bot.
Yes, there are other (and maybe better) ways of fighting spam.
However, this thread is not about "how else can we fight spam?". This is a specific feature request for this specific feature present in HMS.
Who should I address for these two lines of code to be changed? Or, is there a good argument against the requested feature? (Other than "greylisting is not the only way to fight spam".)
The 20 sec trick may be an excellent idea, but involves some risk: some legitimate server (say, from some university) can have 15 sec timeout, and then I will have no way ever to know that I am missing ALL mail from this server, and they will have no way at all to contact me. Greylisting does not have this problem.
Or, can I implement this my idea via a script? Such as in some event handler temporarily changing the incoming IP before greylisting, and then restoring the original IP? I did not find it.
If you use a custom build with OnHelo event >> http://www.hmailserver.com/forum/viewto ... 60#p203420
Then you could use the OnHelo event to do that
This is what I have done in past (note that most is commented out, I don't find this useful in the fight against spam.) You could modify the code to your needs.
If you need I can add the other subroutines that are used but not included
Sub OnHELO(oClient)
'custom hMailserver event in RVHD's builds
'uses functions: CustomMonthlyLog, AutoBanIP, Lookup, Wait, RandomRejection
Dim tempString, strRegEx
If CheckIPRange(oClient.IPAddress) = -1 Then
EventLog.Write("Details for OnHELO - IP Address = " & oClient.IPAddress & " Helo sent was '" & CStr(oClient.helo) & "'")
If oClient.helo = "ylmf-pc" _
Or oClient.helo = "User"
Then
TempString = " Helo = '" & oClient.helo & "' was Autobanned for using known spammer EHLO"
Call CustomMonthlyLog(TempString, "Port" & oClient.port)
Call AutobanIP(oClient.ipaddress, 14, oClient.helo & " as EHLO")
Result.Message = RandomRejection()
EventLog.Write("Random Rejection sent to IP - " & oClient.IPAddress & " Rejection Message was '" & Result.Message & "'")
Wait(14)
Result.Value = 2
' Else
' Add to Greylist Whitelist if from major email sender
' strRegEx = "^[a-z]+[0-9]{2}(-)[a-z]{2}[0-9](-obe\.outbound\.protection\.outlook\.com)$|" &_
' "^(a)[0-9]{1,2}(-)[0-9]{1,3}(\.smtp-out\.amazonses\.com)$|" &_
' "^(mail-)[a-z]{2}[0-9](-f)[0-9]{1,3}(\.google\.com)$|" &_
' "^(spring-chicken-)[a-z]{2}(\.twitter\.com)$|" &_
' "^(mail)[a-z](-)[a-z]{2}(\.linkedin\.com)$|" &_
' "^(mx)[0-9](\.)[a-z]{3}(\.paypal\.com)$|" &_
' "^(cyberoam)" &_
' "^(mx-out\.facebook\.com)$"
' If Lookup(strRegEx, oClient.HELO)= True Then
' dim oApp, NewWhitelistEntry, oWhiteList, i, checker
' Set oApp = CreateObject("hMailServer.Application")
' hMailServer settings.
' Call oApp.Authenticate("Administrator", g_sAdminPassword)
' Set oWhiteList = oApp.Settings.AntiSpam.GreyListingWhiteAddresses
' checker = 0
' For i = 1 To oWhiteList.count
' If oWhiteList.item(i-1).ipAddress = oclient.IPAddress Then
' checker = checker +1
' Exit For
' End If
' Next 'i
' This bit below adds to the Greylist >> Whitelist
' Probably need to add greylist triplet instead
' If checker = 0 Then
' Set NewWhitelistEntry = oWhiteList.Add
' With NewWhitelistEntry
' .IPAddress = oClient.IPAddress
' .Description = "Auto Added - HELO = '" & oClient.helo & "'"
' .Save
' End With
' TempString = "added '" & oClient.helo & "' to Whitelist"
' Call CustomMonthlyLog(TempString, "Port" & oClient.port)
' End If 'checker
' End If
Thank you! Still your solution involves some things that I would avoid. Such as delays, or relying on large providers (in my case, I need to receive messages from university departments with their own servers).
But back to my request: greylisting with a mask, like /24. Is there a way to implement it with a script? Or can you (or who?) make it in the code? Or is there a reason not to do it?
hMailserver is open source on Github (as you've found), feel free to make your own port
Is there a reason not to do this?
Yes, absolutely.
This is one of the sillies ideas that I've seen I reckon.
Consider two people with gMail addresses send you an email, first one gets bounced, second and subsequent once never get bounced. Why greylist at all??
And yes I know that I code in delays, and all sorts of other impediments - that's the point. Real mail will tolerate such things, Spammers won't.
If you look at my script near the top of this thread, you will see that I maintain the "GreyList Whitelist" by examining the HELO/EHLO message. If Sending server identifies itself in the proper manner the script does not care which IP is used or if these servers are located on each their own continent.
The Windows scheduler periodically run a "clean-up" script to keep things at a manageable level.
"Sub OnHELO(oClient)" is right before hMailServer receive recipient address(es) and does it's GreyListing thing, so this way the script can function in a "pro-active" way.
Sender is validated by RegEx to match the EHLO string like "^(mail-)[a-z]{2}[0-9](-f)[0-9]{1,3}(\.google\.com)$" and then hMailServer do not really care if it's IPv4, IPv6, earth-based or extraterrestrial.
BTW... The Wait and LockFile functions are there since VBScript do not handle record locking at all!!
Option Explicit
Function Wait(sec)
Const Append = 8
Const Unicode = -1
Dim oFile, i
For i = 0 To 30
On Error Goto 0
Exit For
On Error Goto 0
Wait(1)
Set oFile = Nothing
Err.Clear
Err.Clear
.Global = False
.Pattern = strRegEx
.IgnoreCase = True
.IPAddress = strIP
.Save
.Save
On Error Goto 0
.Close
Sub ExpireGreyList
Sub OnHELO(oClient)
Dim strRegEx
Unfortunately these HELO/EHLO messages can be faked as well. So i got bit futher and enhanced SorenR's script to validate the ipaddress against know SPF rangesSorenR wrote: ↑2018-09-12 11:13If you look at my script near the top of this thread, you will see that I maintain the "GreyList Whitelist" by examining the HELO/EHLO message. If Sending server identifies itself in the proper manner the script does not care which IP is used or if these servers are located on each their own continent.
So with the EHLO string like "^(mail-)[a-z]{2}[0-9](-f)[0-9]{1,3}(\.google\.com)$
I validate it against the SPF ip range for google.com
Sub AddGreyList(ByVal strIP, ByVal strHELO)
Dim oRegEx
oRegEx.IgnoreCase = True
oRegEx.Global = False
Select Case getDomainName(strHELO)
case "google.com"
oRegEx.Pattern= "^64\.18\.([0-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^64\.233\.(1([6-8][0-9]|9[0-1]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^66\.102\.([0-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^66\.249\.(8[0-9]|9[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^72\.14\.(1(9[2-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^74\.125\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^108\.177\.([8-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^173\.194\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^207\.126\.(1(4[4-9]|5[0-9]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^209\.85\.(1(2[8-9]|[3-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^216\.58\.(1(9[2-9])|2([0-1][0-9]|2[0-3]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^216\.239\.(3[2-9]|[4-5][0-9]|6[0-3])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^172\.217\.([0-9]|[1-2][0-9]|3[0-1])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
"^108\.177\.(9[6-9]|1([0-1][0-9]|2[0-7]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$"
' other ip ranges
Case Else
oRegEx.Pattern= "^(?:[0-9]{1,3}\.){3}[0-9]{1,3}$"
End Select
If oRegEx.Test(strIP) Then
Dim oApp
Call oApp.Authenticate("Administrator", "YOURPASSWORD")
With LockFile("E:\Email\greylistwhite.lck")
If oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP) Is Nothing Then
' REM Logging
' REM Call LogHELO(strIP, strHELO, "E:\helo.log")
.Description = Date & " Auto-Added '" & strHELO & "'"
.IPAddress = strIP
.Save
.Save
On Error Goto 0
.Close '// Close LockFile
Set oApp = Nothing
' REM Logging
Call LogHELO(strIP, strHELO, "E:\helo_error.log")
Set oRegEx = Nothing
Sub LogHELO(ipaddress, helo, path)
Dim objFSO
Dim objTextStream
If not objFSO.FileExists(path) Then
'File not found.
call objFSO.CreateTextFile(path, True)
end if
'OK to access the file.
'Open the text file
Set objTextStream = objFSO.OpenTextFile(path, 8)
'Display the contents of the text file
objTextStream.WriteLine "HELO: " & ipaddress & " From: " & helo
'Close the file and clean up
objTextStream.Close
Set objTextStream = Nothing
Set objFSO = Nothing
Function getDomainName(strHELO)
dim aryDomain, str2ndLevel, strTopLevel
getDomainName = Null
If Len(strHELO) > 0 Then
aryDomain = Split(strHELO,".")
If uBound(aryDomain) >= 1 Then
str2ndLevel = aryDomain(uBound(aryDomain)-1)
strTopLevel = aryDomain(uBound(aryDomain))
getDomainName = str2ndLevel & "." & strTopLevel
Oh boy... How much time do you spend maintaining that monstrum ??RvdH wrote: ↑2018-09-12 11:25
Sub AddGreyList(ByVal strIP, ByVal strHELO) Dim oRegEx Set oRegEx = CreateObject("VBScript.RegExp") oRegEx.IgnoreCase = True oRegEx.Global = False Select Case getDomainName(strHELO) case "google.com" oRegEx.Pattern= "^64\.18\.([0-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^64\.233\.(1([6-8][0-9]|9[0-1]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^66\.102\.([0-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^66\.249\.(8[0-9]|9[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^72\.14\.(1(9[2-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^74\.125\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^108\.177\.([8-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^173\.194\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^207\.126\.(1(4[4-9]|5[0-9]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^209\.85\.(1(2[8-9]|[3-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^216\.58\.(1(9[2-9])|2([0-1][0-9]|2[0-3]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^216\.239\.(3[2-9]|[4-5][0-9]|6[0-3])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^172\.217\.([0-9]|[1-2][0-9]|3[0-1])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_ "^108\.177\.(9[6-9]|1([0-1][0-9]|2[0-7]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$" .... ' other ip ranges .... Case Else oRegEx.Pattern= "^(?:[0-9]{1,3}\.){3}[0-9]{1,3}$" End Select If oRegEx.Test(strIP) Then Dim oApp Set oApp = CreateObject("hMailServer.Application") Call oApp.Authenticate("Administrator", "YOURPASSWORD") With LockFile("E:\Email\greylistwhite.lck") On Error Resume Next oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Refresh If oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP) Is Nothing Then ' REM Logging ' REM Call LogHELO(strIP, strHELO, "E:\helo.log") With oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Add .Description = Date & " Auto-Added '" & strHELO & "'" .IPAddress = strIP .Save End With Else With oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP) .Description = Date & " Auto-Added '" & strHELO & "'" .Save End With End If oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Refresh On Error Goto 0 .Close '// Close LockFile End With Set oApp = Nothing Else ' REM Logging Call LogHELO(strIP, strHELO, "E:\helo_error.log") End If Set oRegEx = Nothing End Sub Sub LogHELO(ipaddress, helo, path) Dim objFSO Dim objTextStream Set objFSO = CreateObject("Scripting.FileSystemObject") If not objFSO.FileExists(path) Then 'File not found. call objFSO.CreateTextFile(path, True) end if 'OK to access the file. 'Open the text file Set objTextStream = objFSO.OpenTextFile(path, 8) 'Display the contents of the text file objTextStream.WriteLine "HELO: " & ipaddress & " From: " & helo 'Close the file and clean up objTextStream.Close Set objTextStream = Nothing Set objFSO = Nothing End Sub Function getDomainName(strHELO) dim aryDomain, str2ndLevel, strTopLevel getDomainName = Null If Len(strHELO) > 0 Then aryDomain = Split(strHELO,".") If uBound(aryDomain) >= 1 Then str2ndLevel = aryDomain(uBound(aryDomain)-1) strTopLevel = aryDomain(uBound(aryDomain)) getDomainName = str2ndLevel & "." & strTopLevel End If End If End Function
I get a headache just looking at it
Not that much...the spf range for google is unchanged for more then a year now, outlook.com range on the other hand
hint: d-fault.nl/CIDRtoRegEx
I was wondering... The HELP text for the topic Whitelist in Greylisting indicate that you can use wildcards...
Anyone tried it? Like "192.168.0.*" or how?
This would be exactly the desired behavior: gMail addresses should NOT be bounced.Consider two people with gMail addresses send you an email, first one gets bounced, second and subsequent once never get bounced. Why greylist at all??
However, since greylisting works by triples, acceptance of a message requires coincidence of THREE things: IP (subnet in my proposal), from, and to.
For a legitimate farm of round-robin servers, this will pass the message normally from the second attempt, which is exactly the desired behavior.
For a spammer, this will block the message, even if he has several computers infected on the same subnet (because the triples will be always different).
No, a legitimate server does not have to respect unrealistic delays (especially not well-configured, but legitimate one). What it does respect is faults. This is why greylisting was invented, and not just delays.delays, and all sorts of other impediments - that's the point. Real mail will tolerate such things
This solves the problem only of google, but not of other legitimate servers, such as the University of Chilpansingo. Unless you maintain a regex of all legitimate servers in the world -- then, indeed, why greylist at all??EHLO string like "^(mail-)[a-z]{2}[0-9](-f)[0-9]{1,3}(\.google\.com)$
Plus, this relies on that spammers don't happen to use "google" in EHLO. One day they will.
I am not good at github. More importantly, I want this to be done for all, not only for me.feel free to make your own port
Special thanks for encouragement. But I am still to see a valid counterargument (other than to regex on EHLO, which, I admit, is also an exceptional idea).This is one of the sillies ideas that I've seen I reckon.
- jimimaseye
- Moderator
+1
What smtp service will occupy 255 different ip address in the same subnet? Most will be a handful which will attempt delivery from the same server address. Bigger hosts (gmail, office365 etc), IF using round robin when greylisted, use 1000s of addresses and likely the delivery attempts will be on different ranges if it's not the same address. What is being asked for here is something to handle a very specific and rare event of an smtp 'server' using round robin to attempt redelivery following greylisting on a different address when there is only a handful of them in the first place. As rare as they are let them handle greylisting and its defined established functionally as it is. After all its not like greylisting is a mystery. Is it.
No but it does have to respect realistic ones. RFC 2821 informs servers are to allow a lot longer before timing out. As call backs must allow 30 seconds before timing out, 20 seconds is nothing. All serious respecting servers will wait 20 seconds for the response on connection. If they do not then they are ill configured and non RFC confirming.
I apologize for being insistent.
Here is just today's example (user name hidden, but it is the same user):
In this example, it took 3 hours for this message to pass. Sometimes it takes days, or gmail just gives up.
The message was real, and a very important one.
And this is gmail. Not very rare 'server', is it?
With my proposal, this message would have passed in 5 minutes, at the second attempt. Instead of 3 hours (and I was lucky).
And please don't say that you can regex for "goodle". If Google can do it, then others will do it, too.
BTW, you see that Google (and others) don't care about its users when it comes to money. Some day they will not care about this your RFC either. Greylisting is a great idea and is very reliable, and we need to modify only two lines of code to bring it to life again.
Unfortunately, my logs show that both major services (gmail, outlook, etc.) and smaller university servers do this all the time.a very specific and rare event of an smtp 'server' using round robin to attempt redelivery following greylisting on a different address when there is only a handful of them
"SMTPD" 3128 36364 "2018-09-12 04:56:43.216" "209.85.167.46" "RECEIVED: EHLO mail-lf1-f46.google.com"
"SMTPD" 3152 36364 "2018-09-12 04:56:43.388" "209.85.167.46" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303"
"SMTPD" 3128 36364 "2018-09-12 04:56:45.868" "209.85.167.46" "SENT: 451 Please try again later."
"SMTPD" 3188 36375 "2018-09-12 05:02:41.034" "209.85.167.48" "RECEIVED: EHLO mail-lf1-f48.google.com"
"SMTPD" 3192 36375 "2018-09-12 05:02:41.206" "209.85.167.48" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303"
"SMTPD" 3188 36375 "2018-09-12 05:02:42.844" "209.85.167.48" "SENT: 451 Please try again later."
"SMTPD" 3136 36385 "2018-09-12 05:20:52.115" "209.85.167.42" "RECEIVED: EHLO mail-lf1-f42.google.com"
"SMTPD" 3152 36385 "2018-09-12 05:20:52.287" "209.85.167.42" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303"
"SMTPD" 3188 36385 "2018-09-12 05:20:54.065" "209.85.167.42" "SENT: 451 Please try again later."
"SMTPD" 3192 36418 "2018-09-12 05:58:18.145" "209.85.167.47" "RECEIVED: EHLO mail-lf1-f47.google.com"
"SMTPD" 3172 36418 "2018-09-12 05:58:18.317" "209.85.167.47" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30302"
"SMTPD" 3172 36418 "2018-09-12 05:58:20.126" "209.85.167.47" "SENT: 451 Please try again later."
"SMTPD" 3140 36450 "2018-09-12 06:43:20.569" "209.85.167.53" "RECEIVED: EHLO mail-lf1-f53.google.com"
"SMTPD" 3172 36450 "2018-09-12 06:43:20.756" "209.85.167.53" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303"
"SMTPD" 3188 36450 "2018-09-12 06:43:22.394" "209.85.167.53" "SENT: 451 Please try again later."
"SMTPD" 3140 36490 "2018-09-12 07:46:49.721" "209.85.167.46" "RECEIVED: EHLO mail-lf1-f46.google.com"
"SMTPD" 3188 36490 "2018-09-12 07:46:50.548" "209.85.167.46" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303"
"SMTPD" 3136 36490 "2018-09-12 07:47:00.969" "209.85.167.46" "SENT: 250 OK"
I wish you were right. Nope. They don't care.As rare as they are let them handle greylisting and its defined established functionally as it is.
OK, with 10,000 addresses, after some 20 attempts on average (40 in the worst case), the /24 subnet will repeat and -- with my proposal -- the message will pass in some 20 hours = 1 day (1 hour / attempt, as my log shows). Without my proposal, it will take some 5,000 hours = half a year = never. Even in this extreme case, a 20-hour delay (my proposal) is better than not getting the message at all.Bigger hosts (gmail, office365 etc), IF using round robin when greylisted, use 1000s of addresses and likely the delivery attempts will be on different ranges
OK, this is probably a good argument. But greylisting is a great idea, and it does not rely on whether the server is compliant.RFC 2821 informs servers are to allow a lot longer before timing out.
Well, you just delivered proof that Greylisting sucksgelbukh wrote: ↑2018-09-13 00:36Here is just today's example (user name hidden, but it is the same user):
In this example, it took 3 hours for this message to pass. Sometimes it takes days, or gmail just gives up.Code: Select all
"SMTPD" 3128 36364 "2018-09-12 04:56:43.216" "209.85.167.46" "RECEIVED: EHLO mail-lf1-f46.google.com" "SMTPD" 3152 36364 "2018-09-12 04:56:43.388" "209.85.167.46" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303" "SMTPD" 3128 36364 "2018-09-12 04:56:45.868" "209.85.167.46" "SENT: 451 Please try again later." "SMTPD" 3188 36375 "2018-09-12 05:02:41.034" "209.85.167.48" "RECEIVED: EHLO mail-lf1-f48.google.com" "SMTPD" 3192 36375 "2018-09-12 05:02:41.206" "209.85.167.48" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303" "SMTPD" 3188 36375 "2018-09-12 05:02:42.844" "209.85.167.48" "SENT: 451 Please try again later." "SMTPD" 3136 36385 "2018-09-12 05:20:52.115" "209.85.167.42" "RECEIVED: EHLO mail-lf1-f42.google.com" "SMTPD" 3152 36385 "2018-09-12 05:20:52.287" "209.85.167.42" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303" "SMTPD" 3188 36385 "2018-09-12 05:20:54.065" "209.85.167.42" "SENT: 451 Please try again later." "SMTPD" 3192 36418 "2018-09-12 05:58:18.145" "209.85.167.47" "RECEIVED: EHLO mail-lf1-f47.google.com" "SMTPD" 3172 36418 "2018-09-12 05:58:18.317" "209.85.167.47" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30302" "SMTPD" 3172 36418 "2018-09-12 05:58:20.126" "209.85.167.47" "SENT: 451 Please try again later." "SMTPD" 3140 36450 "2018-09-12 06:43:20.569" "209.85.167.53" "RECEIVED: EHLO mail-lf1-f53.google.com" "SMTPD" 3172 36450 "2018-09-12 06:43:20.756" "209.85.167.53" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303" "SMTPD" 3188 36450 "2018-09-12 06:43:22.394" "209.85.167.53" "SENT: 451 Please try again later." "SMTPD" 3140 36490 "2018-09-12 07:46:49.721" "209.85.167.46" "RECEIVED: EHLO mail-lf1-f46.google.com" "SMTPD" 3188 36490 "2018-09-12 07:46:50.548" "209.85.167.46" "RECEIVED: MAIL FROM:<some-user@cs.biu.ac.il> SIZE=30303" "SMTPD" 3136 36490 "2018-09-12 07:47:00.969" "209.85.167.46" "SENT: 250 OK"
This is one of the reasons why I abandoned Greylisting - I simply got tired of having this whining noise in my ear saying "I'm trying to reset my password on XYZ and the email has not come through yet" or "Joe User just sent me a list on email 10 minutes ago but it's not in my inbox".
Greylisting once WAS good stuff... Before Social media and 1,000 CPU MailServer Farms sending mails on behalf of half the world about stuff that noone really cares about but they have to read it to be in with the right crowd...
I'm getting to the age where I don't give a sh*te. I know how to program, I can read math formulas and have hapily forgotten all about Laplace transformations and Fourier analysis, I can sew a zipper in a pair of pants, heel my shoes, Cook a decent Thai red curry with ข้าวผัดไข่, change the timing belt in my car, plaster my walls, sand the woodwork or use the lathe, do a 1/4 mile in my 1982 Audi Quattro and plow the fields with my 1952 Ferguson TEA-20. Spending 6 hours on a 16HP Lawn mover once a week gives you ample time to reflect on some of life's great adventures - like Greylisting ...
And remember, to the chemist, alchohol is not the problem, it is a solution...
Me too.
A gmail address was a poor example on my behalf.
If an ISP has their own servers on say 4 IP addresses, and own two thirds of a /24 IP range block, and all other of their own IPs are provided to users, then once you allow the /24 block through grey listing, then almost anybody could be the next to send from that /24 block.
There is a setting to bypass greylisting on SPF pass, the issue with that is two fold.
#1. Hmailserver passes SPF records that end in +all, or ~all for all IPs
#2. Most spammers send from an address that has a valid spf record
Pretty sure I have tried that, also FQDNs like spf.gmail.com which would in itself solve this issue fairly easily (If Office365 also used a similar method to show their sending server addresses.
I also find that Sub OnHelo doesn't always return a HELO/EHLO, It seems to when there is StartTLS involved on my system for incoming mail. ****EDIT This should say OnSMTPData, not OnHelo ****
That is odd, you should get receive EHLO/HELO response before and after the once the STARTTLS command is received. EHLO/HELO is requested/send only for SMTPD/SMTPC
With debugging"TCPIP" 3400 "2018-09-13 10:58:06.289" "TCP - x.x.x.x connected to x.x.x.x:25."
"SMTPD" 3400 3508 "2018-09-13 10:58:06.304" "x.x.x.x" "SENT: 220 mail.server.com ESMTP"
"SMTPD" 824 3508 "2018-09-13 10:58:06.320" "x.x.x.x" "RECEIVED: EHLO something.com"
"SMTPD" 824 3508 "2018-09-13 10:58:06.351" "x.x.x.x" "SENT: 250-mail.server.com[nl]250-SIZE 41943040[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 824 3508 "2018-09-13 10:58:06.367" "x.x.x.x" "RECEIVED: STARTTLS"
"SMTPD" 824 3508 "2018-09-13 10:58:06.367" "x.x.x.x" "SENT: 220 Ready to start TLS"
"TCPIP" 3416 "2018-09-13 10:58:06.398" "TCPConnection - TLS/SSL handshake completed. Session Id: 3508, Remote IP: x.x.x.x, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"SMTPD" 3416 3508 "2018-09-13 10:58:06.413" "x.x.x.x" "RECEIVED: EHLO something.com"
"SMTPD" 3416 3508 "2018-09-13 10:58:06.445" "x.x.x.x" "SENT: 250-mail.server.com[nl]250-SIZE 41943040[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 3416 3508 "2018-09-13 10:58:06.460" "x.x.x.x" "RECEIVED: MAIL FROM:<***@***.**>"
"SMTPD" 3416 3508 "2018-09-13 10:58:06.523" "x.x.x.x" "SENT: 250 OK"
"SMTPD" 3416 3508 "2018-09-13 10:58:06.523" "x.x.x.x" "RECEIVED: RCPT TO:<***@***.**>"
"SMTPD" 3416 3508 "2018-09-13 10:58:06.538" "x.x.x.x" "SENT: 250 OK"
"SMTPD" 2320 3508 "2018-09-13 10:58:06.554" "x.x.x.x" "RECEIVED: DATA"
"SMTPD" 2320 3508 "2018-09-13 10:58:06.554" "x.x.x.x" "SENT: 354 OK, send."
"TCPIP" 3980 "2018-09-13 10:58:06.647" "Connecting to 127.0.0.1:783..."
"SMTPD" 3980 3508 "2018-09-13 10:58:10.516" "x.x.x.x" "SENT: 250 Queued (3.900 seconds)"
"SMTPD" 1284 3508 "2018-09-13 10:58:10.516" "x.x.x.x" "RECEIVED: QUIT"
"SMTPD" 1284 3508 "2018-09-13 10:58:10.516" "x.x.x.x" "SENT: 221 goodbye"
"TCPIP" 3008 "2018-09-13 11:09:31.968" "TCP - x.x.x.x connected to x.x.x.x:25."
"DEBUG" 3008 "2018-09-13 11:09:31.968" "Executing event OnClientConnect"
"DEBUG" 3008 "2018-09-13 11:09:31.999" "Event completed"
"DEBUG" 3008 "2018-09-13 11:09:31.999" "TCP connection started for session 3714"
"SMTPD" 3008 3714 "2018-09-13 11:09:31.999" "x.x.x.x" "SENT: 220 mail.server.com ESMTP"
"SMTPD" 3008 3714 "2018-09-13 11:09:32.014" "x.x.x.x" "RECEIVED: EHLO something.com"
"DEBUG" 3008 "2018-09-13 11:09:32.014" "Executing event OnHELO"
"DEBUG" 3008 "2018-09-13 11:09:32.108" "Event completed"
"SMTPD" 3008 3714 "2018-09-13 11:09:32.108" "x.x.x.x" "SENT: 250-mail.server.com[nl]250-SIZE 41943040[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 3400 3714 "2018-09-13 11:09:32.108" "x.x.x.x" "RECEIVED: STARTTLS"
"SMTPD" 3400 3714 "2018-09-13 11:09:32.124" "x.x.x.x" "SENT: 220 Ready to start TLS"
"DEBUG" 3008 "2018-09-13 11:09:32.124" "Performing SSL/TLS handshake for session 3714. Verify certificate: False"
"TCPIP" 3008 "2018-09-13 11:09:32.342" "TCPConnection - TLS/SSL handshake completed. Session Id: 3714, Remote IP: x.x.x.x, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"SMTPD" 3008 3714 "2018-09-13 11:09:32.342" "x.x.x.x" "RECEIVED: EHLO something.com"
"DEBUG" 3008 "2018-09-13 11:09:32.342" "Executing event OnHELO"
"DEBUG" 3008 "2018-09-13 11:09:32.576" "Event completed"
"SMTPD" 3008 3714 "2018-09-13 11:09:32.576" "x.x.x.x" "SENT: 250-mail.server.com[nl]250-SIZE 41943040[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 2416 3714 "2018-09-13 11:09:32.716" "x.x.x.x" "RECEIVED: MAIL FROM:<***@***.**> SIZE=88575"
"SMTPD" 2416 3714 "2018-09-13 11:09:32.763" "x.x.x.x" "SENT: 250 OK"
"SMTPD" 3400 3714 "2018-09-13 11:09:32.810" "x.x.x.x" "RECEIVED: RCPT TO:<***@***.**>"
"SMTPD" 3400 3714 "2018-09-13 11:09:32.810" "x.x.x.x" "SENT: 250 OK"
"SMTPD" 2416 3714 "2018-09-13 11:09:32.826" "x.x.x.x" "RECEIVED: DATA"
"DEBUG" 2416 "2018-09-13 11:09:32.826" "Executing event OnSMTPData"
"DEBUG" 2416 "2018-09-13 11:09:32.904" "Event completed"
"SMTPD" 2416 3714 "2018-09-13 11:09:32.904" "x.x.x.x" "SENT: 354 OK, send."
Yes I get that in the hMailserver logs too
I meant Sub OnSMTPData, not your added Sub OnHELO. Your OnHelo works as expected
I have this code in my Eventhandlers.vbs
My Port25 log looks like this
As you can see sub OnSMTPData gives a null EHLO until after the STartTLS
'included hMailserver event
'uses globals:
Dim TempString,i
TempString = " Authenticated SMTP user is '" & CStr(oClient.Username) & "'"
TempString = " Further Details for IP Address = " & oClient.IPAddress & " Helo sent was '" & CStr(oClient.helo) & "'"
TempString = " Message FROM = '" & omessage.FromAddress & "' and has " & OMessage.Recipients.Count & " Message Recipients"
TempString = " Message Recipient number " & i+1 & " is '" & omessage.Recipients.Item(i).Address & "'"
Next 'i
2018-09-13 19:49:49.148 Port Number = 25 IP Address = 24.220.46.94 Helo = ''
2018-09-13 19:50:26.585 Further Details for IP Address = 24.220.46.94 Helo sent was 'ic3.org'
2018-09-13 19:50:26.617 Message FROM = 'no-reply@ic3.org' and has 1 Message Recipients
2018-09-13 19:50:26.648 Message Recipient number 1 is ***REMOVED ****
2018-09-13 19:57:06.507 Port Number = 25 IP Address = 66.220.155.153 Helo = ''
2018-09-13 19:57:34.039 Further Details for IP Address = 66.220.155.153 Helo sent was 'mx-out.facebook.com'
2018-09-13 19:57:34.070 Message FROM = 'notification@facebookmail.com' and has 1 Message Recipients
2018-09-13 19:57:34.101 Message Recipient number 1 is ***REMOVED ****
2018-09-13 20:02:17.539 Port Number = 25 IP Address = 209.85.215.173 Helo = ''
2018-09-13 20:02:44.445 Further Details for IP Address = 209.85.215.173 Helo sent was 'mail-pg1-f173.google.com'
2018-09-13 20:02:44.460 Message FROM = 'datavation.tools@gmail.com' and has 1 Message Recipients
2018-09-13 20:02:44.492 Message Recipient number 1 is ***REMOVED ****
2018-09-13 20:27:31.882 Port Number = 25 IP Address = 13.210.188.175 Helo = ''
2018-09-13 20:28:05.039 Further Details for IP Address = 13.210.188.175 Helo sent was 'mg-aaus-zeta.mailguard.com.au'
2018-09-13 20:28:05.070 Message FROM = ***REMOVED **** and has 1 Message Recipients
2018-09-13 20:28:05.101 Message Recipient number 1 is ***REMOVED ****
2018-09-13 21:01:59.148 Port Number = 25 IP Address = 103.8.195.34 Helo = ''
2018-09-13 21:02:27.804 Further Details for IP Address = 103.8.195.34 Helo sent was 'sportoptions.com'
2018-09-13 21:02:27.835 Message FROM = 'Finnvai@sportoptions.com' and has 1 Message Recipients
2018-09-13 21:02:27.867 Message Recipient number 1 is ***REMOVED ****
2018-09-13 21:06:22.429 Port Number = 25 IP Address = 172.93.138.134 Helo = ''
2018-09-13 21:06:49.992 Further Details for IP Address = 172.93.138.134 Helo sent was 'thunder1.stoneyap.biz'
2018-09-13 21:06:50.023 Message FROM = 'steve@stoneyap.biz' and has 1 Message Recipients
2018-09-13 21:06:50.054 Message Recipient number 1 is ***REMOVED ****
I don't have empty oClient.HELO entries in OnSMTPData.... with or without STARTTLS
Btw, why the CStr(oClient.HELO) ? ....oClient.HELO always is a string
I would say the error is in the part where you build the lines like: "Port Number = 25 IP Address = 13.210.188.175 Helo = ''", are you 100% sure you pass oClient.HELO value there?
Simply write EventLog.Write(oClient.HELO) in Sub OnSMTPData to verify
So, where is the line "Port Number = 25 IP Address = 24.220.46.94 Helo = '' written ?? Sub OnHELO() or Sub OnClientConnect() ?mattg wrote: ↑2018-09-13 13:50Yes I get that in the hMailserver logs too
I have this code in my Eventhandlers.vbsMy Port25 log looks like thisCode: Select all
Sub OnSMTPData(oClient, oMessage) 'included hMailserver event 'uses functions: CustomMonthlyLog 'uses globals: Dim TempString,i If oClient.Username <> "" Then TempString = " Authenticated SMTP user is '" & CStr(oClient.Username) & "'" Call CustomMonthlyLog(TempString, "Port" & oClient.port) Else TempString = " Further Details for IP Address = " & oClient.IPAddress & " Helo sent was '" & CStr(oClient.helo) & "'" Call CustomMonthlyLog(TempString, "Port" & oClient.port) End If TempString = " Message FROM = '" & omessage.FromAddress & "' and has " & OMessage.Recipients.Count & " Message Recipients" Call CustomMonthlyLog(TempString, "Port" & oClient.port) For i = 0 To oMessage.Recipients.Count-1 TempString = " Message Recipient number " & i+1 & " is '" & omessage.Recipients.Item(i).Address & "'" Call CustomMonthlyLog(TempString, "Port" & oClient.port) Next 'i End Sub
As you can see sub OnSMTPData gives a null EHLO until after the STartTLSCode: Select all
2018-09-13 19:49:49.148 Port Number = 25 IP Address = 24.220.46.94 Helo = '' 2018-09-13 19:50:26.585 Further Details for IP Address = 24.220.46.94 Helo sent was 'ic3.org' 2018-09-13 19:50:26.617 Message FROM = 'no-reply@ic3.org' and has 1 Message Recipients 2018-09-13 19:50:26.648 Message Recipient number 1 is ***REMOVED **** 2018-09-13 19:57:06.507 Port Number = 25 IP Address = 66.220.155.153 Helo = '' 2018-09-13 19:57:34.039 Further Details for IP Address = 66.220.155.153 Helo sent was 'mx-out.facebook.com' 2018-09-13 19:57:34.070 Message FROM = 'notification@facebookmail.com' and has 1 Message Recipients 2018-09-13 19:57:34.101 Message Recipient number 1 is ***REMOVED **** 2018-09-13 20:02:17.539 Port Number = 25 IP Address = 209.85.215.173 Helo = '' 2018-09-13 20:02:44.445 Further Details for IP Address = 209.85.215.173 Helo sent was 'mail-pg1-f173.google.com' 2018-09-13 20:02:44.460 Message FROM = 'datavation.tools@gmail.com' and has 1 Message Recipients 2018-09-13 20:02:44.492 Message Recipient number 1 is ***REMOVED **** 2018-09-13 20:27:31.882 Port Number = 25 IP Address = 13.210.188.175 Helo = '' 2018-09-13 20:28:05.039 Further Details for IP Address = 13.210.188.175 Helo sent was 'mg-aaus-zeta.mailguard.com.au' 2018-09-13 20:28:05.070 Message FROM = ***REMOVED **** and has 1 Message Recipients 2018-09-13 20:28:05.101 Message Recipient number 1 is ***REMOVED **** 2018-09-13 21:01:59.148 Port Number = 25 IP Address = 103.8.195.34 Helo = '' 2018-09-13 21:02:27.804 Further Details for IP Address = 103.8.195.34 Helo sent was 'sportoptions.com' 2018-09-13 21:02:27.835 Message FROM = 'Finnvai@sportoptions.com' and has 1 Message Recipients 2018-09-13 21:02:27.867 Message Recipient number 1 is ***REMOVED **** 2018-09-13 21:06:22.429 Port Number = 25 IP Address = 172.93.138.134 Helo = '' 2018-09-13 21:06:49.992 Further Details for IP Address = 172.93.138.134 Helo sent was 'thunder1.stoneyap.biz' 2018-09-13 21:06:50.023 Message FROM = 'steve@stoneyap.biz' and has 1 Message Recipients 2018-09-13 21:06:50.054 Message Recipient number 1 is ***REMOVED ****
That is what i was thinking
I'm going to test Matt's logging scheme, minus the top line...
' Custom logging of SMTP port
Dim EventLogX : Set EventLogX = New LogWriter
EventLogX.LogType = "D" ' Default is "M"onth
EventLogX.LogDir = "c:\hmailserver\temp\mattlog\" ' Default is hMailServer logs directory
EventLogX.LogFile = "port" & oClient.port
EventLogX.Write( " Authenticated SMTP user is '" & oClient.Username & "'" )
EventLogX.Write( " Further Details for IP Address = " & oClient.IPAddress & " Helo sent was '" & oClient.HELO & "'" )
EventLogX.Write( " Message FROM = '" & omessage.FromAddress & "' and has " & OMessage.Recipients.Count & " Message Recipients" )
EventLogX.Write( " Message Recipient number " & i+1 & " is '" & omessage.Recipients.Item(i).Address & "'" )
I have tested oClient.HELO in OnSMTPData() for a few hours now....none empty entries as far, so i suspect, like you suggested he makes that other logline in OnClientConnect() where the oClient.HELO value is not populated
If that is the case that will be a big, 'duh' moment for mattg
Thanks for an extensive list of your virtues; please find mine on http://www.gelbukh.com.I can sew a zipper in a pair of pants
But back to the point. This thread is not about debugging OnHELO and not about whether greylisting may be unsuitable for some types of users in some situations. Those users can disable it.
(My own feeling about greylisting is that it is the worst form of spam blocking, except for all the others. But my feelings are off-topic here.)
This thread is about a specific proposal to make greylisting work with server farms.
Nope. I just re-read the documentation: it works by triples IP-from-to. So this will only unblock those spammers on the /24 subnet who happen to use the same from address as legitimate messages. No good (in theory there might possibly be some chance for this to happen), but better than disabling greylisting at all. And if this happens, there is a blacklist for those IPs, too.If an ISP has their own servers on say 4 IP addresses, and own two thirds of a /24 IP range block, and all other of their own IPs are provided to users, then once you allow the /24 block through grey listing, then almost anybody could be the next to send from that /24 block
So far, no convincing argument against an option for greylisting (for those of us who use it) to be able to deal with server farms in the way I proposed.
I think I can make it...but what is your fee?
Just kidding....it shouldn't be that hard....but on the other hand there are ways to bypass your issue...so why changing something that works?
.. sorry, i don't get a lot of mail originating form University of Chilpansingo i guess
As usual you guys are correctRvdH wrote: ↑2018-09-13 16:16I have tested oClient.HELO in OnSMTPData() for a few hours now....none empty entries as far, so i suspect, like you suggested he makes that other logline in OnClientConnect() where the oClient.HELO value is not populated
That is exactly what I do
@gelbukh
Read this thread for an earlier discussion on this topic >> viewtopic.php?f=21&t=29238
Yes I know how greylisting works, I was offering a reason why your idea /24 block whitelisting won't work.gelbukh wrote: ↑2018-09-13 23:11But back to the point. This thread is not about debugging OnHELO and not about whether greylisting may be unsuitable for some types of users in some situations. Those users can disable it.
I'll be happy to a see (and use) a solution from RvdH / SorenR if one is forthcoming.
The discussion about OnHelo and OnSMTPData is about finding a solution to the problem that you identify and that we have discussed for many years.
And while you/we are one it...viewtopic.php?f=9&t=32375
@mattg, we all from time to time have bad days, weeks, months or whatever
Great, now it sounds more to the pointI think I can make it...but what is your fee?
Me neither, but when one arrives once in a year and is lost, it may be a very important one. I had had such cases, with a university uning a server farm (but not gmail).i don't get a lot of mail originating form University of Chilpansingo
My usage scenario (a small department server with a handful of users, professors and students):
- no time-critical tasks: a delay of half an hour is OK;
- often mission-critical tasks: losing a message can be very bad;
- messages from many "third-party" servers, such as other university servers, not only large providers: some of them are legitimate but misconfigured;
- lots of spam, because publishers put our addresses all over Internet (you can find hunreds of mentions of mine): even after keyword-based filtering, it takes me hours every day to go through my mail, after which I am too tired to even respond to the real ones;
- need to concentrate: typically my inbox has some 300+ messages a day, many of them spam, and I cannot quickly grasp the important ones.
Because it doesn't. Nowadays a technique that blocks server farms doesn't "work".why changing something that works?
Sadly, from this discussion none looks as an adequate replacement for greylisting. The closest is the delay, but I would not risk to mess with it my production environment.but on the other hand there are ways to bypass your issue...
You say it works for you? How do you know? Because nobody so far told you "Hey, I tried sending you a message but you don't reply?" Even if they did, they would have no way to tell you this. In my case, an official from the ministry will not even bother calling me on phone -- she sends me one message, and if I don't act by the deadline, she cuts my funding or rejects my application. I will never know what happened. And no, I can't whitelist all (unknown to me) officials from all relevant ministries all over the world. Properly configured greylisting will surely work, whereas all the tricks proposed on this page don't sound too reliable.
The very fact that we discuss them here indicates that they are doubtful. If the delay were a solid proven technique while greylisting a silly idea, HMS (and others) will include a prominent option of a delay on OnHELO in its settings, and would have no traces of greylisting. If delay were a solid proven technique, you would not have given me your scripts here, you would just have pointed me to the Wikipedia page on the Antispam Delay. The very fact that you have to implement your solution to a such a very common and long-standing problem as spam filtering with some kitchen-made scripts in a still-in-alfa event hook clearly hints on that it is not an obviously right thing to do.
Yes, I've read it before opening mine. The techniques discussed there have the same fundamental flaws that we have already discussed:Read this thread for an earlier discussion on this topic >> viewtopic.php?f=21&t=29238
- they rely on the server's self-description in HELO, which is trivial to fake at no cost for the spammer,
- they whitelist only a predefined set of providers, which does not solve the problem (though alleviates it, I agree).
Thank you, but you only showed that it might have false negatives (= allow some spam) in an (I believe) quite rare situations. This is much better than false positives (= lost legitimate messages) from which all other techniques suffer (including keyword filtering, whitelisting known providers, and arguably delays), or than disabling any protection at all.I was offering a reason why your idea /24 block whitelisting won't work.
Well... The war on SPAM. It's not ideology or religion that controls SPAM - It's MONEY!gelbukh wrote: ↑2018-09-14 02:03You say it works for you? How do you know? Because nobody so far told you "Hey, I tried sending you a message but you don't reply?" Even if they did, they would have no way to tell you this. In my case, an official from the ministry will not even bother calling me on phone -- she sends me one message, and if I don't act by the deadline, she cuts my funding or rejects my application. I will never know what happened. And no, I can't whitelist all (unknown to me) officials from all relevant ministries all over the world. Properly configured greylisting will surely work, whereas all the tricks proposed on this page don't sound too reliable.
Whenever you think you have won - you loose, and it's not the person that read the most books who wins, it the person who gets his hands dirty in the trenches and who still have an ounce of imagination left that don't loose as much as the others.
I pity people living outside Europe, in EU we own our personal data by law and with GDPR we can fight back.
By the way, I have taken precautions on my server not to loose any mails whatsoever. I engage an offsite backup-mx for those occations where the sender gives up on my server and move on to the next MX record in DNS. Since I moved away from GreyListing the backup-mx is utilized less and less.
An other issue is, by rejecting emails you loose a big chunk of statistical data that can be used to classify SPAM. I know a few of us here reclassify SPAM in two groups; "light SPAM" that is "safe" to pass on to the user and "The Rest" that is only suitable for training SpamAssassin.
With your knowledge in AI you should easily be able to whip something up for SpamAssassin that can give us World Peace.
Oh by the way...
https://antispam.byteplant.com/products ... ilter.html
http://articles.marco.org/238
https://www.tldp.org/HOWTO/Spam-Filteri ... elays.html
http://altlasten.lutz.donnerhacke.de/mi ... be.en.html
I think you would allow much spam, not 'some spam', and I don't believe this would be a rare situation, but rather a very common one. Only a real life test would show.gelbukh wrote: ↑2018-09-14 02:14Thank you, but you only showed that it might have false negatives (= allow some spam) in an (I believe) quite rare situations. This is much better than false positives (= lost legitimate messages) from which all other techniques suffer (including keyword filtering, whitelisting known providers, and arguably delays), or than disabling any protection at all.I was offering a reason why your idea /24 block whitelisting won't work.
If you are happy to get 'some spam' then disable greylisting, and use other spam measures. Essentially that's what we have all done here.
On each pointgelbukh wrote: ↑2018-09-14 02:14The techniques discussed there have the same fundamental flaws that we have already discussed:
#1 not if we can somehow check the IP being used to send and compare that to the allowed sender list ie spf.gmail.com
#2 this is the point of greylisting, protecting you from unknown senders / providers. Surely the 'predefined set' will grow and change over time, and be different on all servers.
In general terms of beating SPAM, I'd like to have DMARC and DANE implemented into hMailserver, and to have more control over SPF testing
In some businesses it's inevitable to have your address spread. Say, it's a European publisher Springer who requires email to be indicated on every published paper or book, by "the policy of the company." I tried to complain, but they have their rules. And it's Europe. (BTW, in all other respects the publisher that I enjoy most working with!)I pity people living outside Europe, in EU we own our personal data by law and with GDPR we can fight back.
Not quite feasible.With your knowledge in AI you should easily be able to whip something up for SpamAssassin that can give us World Peace.
First, I am involved in other battles (publish or perish) and fighting spam is not my main occupation.
Second, big guys like Microsoft and Google are on it already. The bad side of the AI techniques is that they don't offer as low false positives as greylisting, which in some scenarios is unacceptable -- imagine a biochemist eagerly waiting for an acceptance decision on his paper on effects of viagra on the cardiovascular system. From my own experience, I've missed an invitation for giving a keynote lecture at the XXX International Conference on Computer Science, you guess why.
And third, the spammers will fight back with AI, too (I've got invitations from spam-sending companies for such projects).
If you have a good dataset, my students and I can try doing something reasonable on it. Though I cannot imagine a scenario of working on this topic outside a large email provider like Google. Say, you cannot reasonably share a dataset, for privacy reasons: you cannot share negative (= legitimate) examples. We have had this problem in medical research.
Nope. Greylisting does not involve any predefined lists. The point of greylisting is in allowing servers to self-whitelist at a cost (without pre-existing knowledge at the side of the receiver).#2 this is the point of greylisting, protecting you from unknown senders / providers. Surely the 'predefined set' will grow and change over time, and be different on all servers.
There are other varieties of the idea of imposing a cost on sending messages (the delay discussed here is one of them; there are cryptographic proposals to impose the CPU cost), but they all so far have some problems (discussing which is off-topic in this thread, but we can open a new thread for it), such as relying on capabilities of the sender that are not guaranteed.
Maybe you are right. I have no hard data to support my feeling of that it is unlikely that a spammer on the same subnet will figure out the from address recently used from the legitimate server. But as you say, we can test it and see. I admit that in the end stats may show that you were right and I was not.I think you would allow much spam, not 'some spam', and I don't believe this would be a rare situation, but rather a very common one. Only a real life test would show.
Or, some users may find it useful and some may not, depending on the from addresses they typically expect.
Re: Greylisting by subnetwork
So if a server can self whitelist, won't the spammers be doing that?gelbukh wrote: ↑2018-09-14 04:00Nope. Greylisting does not involve any predefined lists. The point of greylisting is in allowing servers to self-whitelist at a cost (without pre-existing knowledge at the side of the receiver).#2 this is the point of greylisting, protecting you from unknown senders / providers. Surely the 'predefined set' will grow and change over time, and be different on all servers.
There is only one way to find out... Even weeks = greylisting and odd weeks = delays.gelbukh wrote: ↑2018-09-14 04:00Nope. Greylisting does not involve any predefined lists. The point of greylisting is in allowing servers to self-whitelist at a cost (without pre-existing knowledge at the side of the receiver).#2 this is the point of greylisting, protecting you from unknown senders / providers. Surely the 'predefined set' will grow and change over time, and be different on all servers.
Nope. The key here is the cost: self-whitelisting has a cost that spammers cannot afford (namely, the logistics of a second attempt).So if a server can self whitelist, won't the spammers be doing that?
What differentiates a legitimate server from a spammer is the willingness to pay a cost (in terms of logistics, delays, CPU, etc.), and greylisting exploits this difference. Other techniques such as AI miss it. Cryptographic techniques address it directly: they challenge the sender with spending considerable CPU resources per each message, which a spammer, again, cannot afford.
I can do it. For this, you (or somebody) need to implement the feature in question, in order to see if it passes too much spam.There is only one way to find out... Even weeks = greylisting and odd weeks = delays.
So far I think my personal server blocks about 100 messages a day with greylisting (excluding those that pass after some attemts), and passes probably 300, of which some 30-50 are real; I have not analyzed this carefully. In any case not impressive, but still 25% less work for me to sort my mail. If I disable it (which I have to, unless it properly handles server farms), I will have to filter manually 100 messages more every day, apart from my main work.
BTW (though off-topic here), I did not understand why the delay you use should be applied in OnHELO and not in any other event before actual delivery? I would rather apply it after getting all the data, when I can analyze even the contents of the message to decide if I want to pass this message unconditionally (say, if it mentions words relevant for my organization, such as "conference" or "professor" in my case). Any delay at any stage would break communication with a spammer and thus prevent delivery, no?
Ah, and the same applies to greylisting and all other antispam tests, including blacklists. But this is too much to ask for, if a simple /24 masking took us 49 messages to discussI would rather apply it after getting all the data, when I can analyze even the contents of the message to decide if I want to pass this message unconditionally
There's no problem with 50 posts per topic - discussion is good.
I see a difference in what you are saying now.
You still want to greylist big senders.
I want to bypass greylisting for big senders, because I trust that if it is genuinely from one of their servers that they have already performed some spam mitigation, and that coupled with my other spam tests (especially including SpamAssassin) will detect most spam.
Also, I normally only apply delays to those message that look suspicious. If they pass all of my tests initially they get through. If they are a little off they get delayed a little, if they are a lot off they get delayed a lot and also autobanned, so they can't try again. (and a few steps in between)
I don't care of big senders. If things work correctly, they work correctly for all, and there is no reason for special tweaks for big senders. (You may want to treat them specially for the sake of efficiency; in my case I don't care about efficiency, I only care about correctness.)You still want to greylist big senders.
Another difference is that you seem to care mostly about false negatives (= spam that passes), while I care more about false positives (= lost legitimate messages). With this, you seem to feel OK while big senders are well-attended, and for you small ones are all potential spammers not deserving attention; I care more about treating correctly legitimate small senders (then big ones will enjoy the same correct treatment, too).
Bad news is that nowadays "small" senders also use server farms, so I would have to treat them with the same precautions for the server farms, but unlike big ones, I don't have a complete list of their names. Maybe the third difference is that you consider server farm problem as specific to big senders that you can count by the fingers of one hand, while I consider it a common problem not solvable by a predefined whitelist.
I don't like missed legitimate mail, and don't believe that I've ever missed any (but of course, how would I know for sure?)
In fact, to get around the proliferation of large senders, and the ineffectiveness of greylisting at this point in time because of these large senders, I (and many others) have simply turned greylisting off.
At present, I reject lots of spam (and tell the sender that their mail was rejected), and I accept some spam, but send that to an IMAP folder where it is managed, always looking for what you call 'false positives'.
I don't really have favorites of either large or small senders. As long as they play nice and by the established rules (spf ending in -all, DKIM, DMARC) then I'm happy enough. Although fighting SPAM is nearly a full time job.
- jimimaseye
- Moderator
SCENARIO:
GREYLISTING is on
Someone sends in an email
Server farm attempts delivery from ip a.b.c.d
Hits greylist.
Server reattempts delivery from j.k.l.m
Hits greylist
Server reattempts delivery from w.x.y.z
How does this proposed solution help the above situation?
The point is that your proposed solution is a non-standard tweak to the standard greylist practice and you are trying to compensate for only a portion of inadequacies of greylisting. Its only half a job and doesnt cater for all inadequacies and doesnt deal with the problem fully.
Greylist has its problems when reputable email server (admins) do not WANT to acknowledge the standards and work with them (like gnail et al). But as an admin that is something you have to accept when you choose to use Greylisting. Sure, RvdH can create a version for you as you requested, but it doesnt stop you having problems with Greylisting. Turn it on and accept that some senders will be delayed or turn it off for full confidence it will not cause occasionally problems and use alternative methods that will apply to all servers (such as the proven VERY effective 20 second delay).
And given that google servers are used more and more for businesses as their service provider its something you REALLY need to think about (its effectively making greylisting a nuisance for large scale users).
This is why you need to care about big senders.
It seems to me that people legitimately working with Viagra, etc must know that there is an issue with spam and have already worked up solutions to circumvent getting trapped by spamassassin. Otherwise they wouldn't be able to use email at all!
See, this is why we are loosing the fight against SPAM ... No imagination ... No ingenuity ... No sense of adventure.gelbukh wrote: ↑2018-09-14 07:53I don't care of big senders. If things work correctly, they work correctly for all, and there is no reason for special tweaks for big senders. (You may want to treat them specially for the sake of efficiency; in my case I don't care about efficiency, I only care about correctness.)
Aaron Poffenberger: Fighting Spam at the Frontline -- BSDCan 2018 (1 hour, so secure coffee and popcorn in advance)
https://www.youtube.com/watch?v=PKY6rSpzTIQ
viewtopic.php?p=202139#p202139
This guy is actually doing something interesting and RvdH picked up on it with his version of SPF based Whitelist Greylist of my dynamic EHLO based dynamic Whitelist Greylist... It does not need to be Greylist, it can be the deciding faktor whether the connection is to be delayed or not.
Part of fighting SPAM is using blacklists and I have found that the Snowshoe list is quite effective. DNS blacklist "sbl.spamhaus.org" and look for "127.0.0.3". Kill the connection on sight
' System Scripting Runtime COM object ("SScripting.IPNetwork")
' http://www.netal.com/ssr.htm
' Binary -> http://www.netal.com/software/ssr15.zip
Function IsSnowShoe(strIP) : IsSnowShoe = False
Dim a
a = Split(strIP, ".")
strIP = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".sbl.spamhaus.org")
If (strIP = "127.0.0.3") Then IsSnowShoe = True
' SnowShoe SPAM detection
Result.Value = 1
Exit Sub
If they are working on Viagra they probably have other priorities on their mind or they would call it "sildenafil citrate" or "UK-92,480".
Stumbled over this today: https://dmarcian.com/spf-survey/
"google.com" ... 25 netblocks or 322.816 individual IPv4 addresses
"outlook.com" ... 82 netblocks or 654.455 individual IPv4 addresses
"facebook.com" ... 8 netblocks or 1.281 individual IPv4 addresses
"twitter.com" ... 49 netblocks or 330.296 individual IPv4 addresses
"instagram.com" ... 17 netblocks or 20.068 individual IPv4 addresses
That's 181 netblocks or 1.328.916 individual IPv4 addresses and that's only covering social media.
Damn... I forgot to check the remaining 55 Social Networking sites including Tumbl, Snapchat, Pinterest etc. etc. https://makeawebsitehub.com/social-media-sites/
- jimimaseye
- Moderator
I don't want to distract from the point you are making but why do you consider Google and outlook as social media servers? They are services (email providers and hosting) whilst the others exist only and are dedicated to the core for providing social media.
Still even without that 976k, with the other social media providers yet to be included it's still a lot of servers for feeding this social media nonsense.
What a world. People really have too much time to waste.
Google+, MSN and Skype ?? What do I know I'm still debating myself if I should kill my Facebook and Google+ accounts and just settle for Linkedin, Skype, Twitter, Instagram and Snapchat. ICQ closed my account (69108473) some years ago due to inactivity and Yahoo Messenger went the same way.jimimaseye wrote: ↑2018-09-14 22:28I don't want to distract from the point you are making but why do you consider Google and outlook as social media servers? They are services (email providers and hosting) whilst the others exist only and are dedicated to the core for providing social media.
