Minutes Between The Sending For IP Warming Up
nghuyphong
Post by nghuyphong » 2018-05-18 22:11
It would be great if hMailserver has a feature that we can set the time between every sending attempt for warming up an IP. The example is when I send an email with 100 recipients and want hMailserver to send out 10 times with 10 recipients at a time, and with a delay (for example 10 minutes) between them.
Re: Minutes Between The Sending For IP Warming Up
Post by mattg » 2018-05-19 05:59
Why would this be useful?
I understand what you want, I'm just not sure why?
nghuyphong
Post by nghuyphong » 2018-05-21 09:26
Hi mattg,
Thank you for your comment. The reason for this is if you run hMailserver with a new dedicated IP your IP will be likely blacklisted if you send more emails than it is recommended by best practice. So you need to warm up an IP to build the reputation. The requested feature is also good for splitting the large list into smaller list and send them out with preset delay time in between. This will reduce the chance of your IP is marked as spam and blacklisted. hMailserver already has "Maximum Number of Recipients In Batch" in Settings/Protocols/SMTP/Advanced. Now it will be great if there is a feature something like "Minutes Between Batch". Then you can set it to Zero if no delay needed
Example of IP warming up can be found here in Sendgrid: https://sendgrid.com/docs/User_Guide/Se ... armup.html
EduardoFoltran
Post by EduardoFoltran » 2018-08-03 17:19
Hi!
Indeed! This is a very useful feature for those who want to use HMS to send spam. One is not blacklisted just for sending emails, but for sending lots of emails to spam traps. As my main goal for the last 8 months has being to fight spammers, I am very concerned about their behaviour and this implementation looks like one a spammer would love.
Moreover, you can use a script to limit the amount of e-mails your users send every day. Look at:
viewtopic.php?t=25092
Eduardo
