Domain setting "Plus addressing", multiple choice
danielHalan
Post by danielHalan » 2018-02-09 11:48
It would be nice if would be possible to define support for multiple email separators (plus addressing) for a Email Domain, i.e. both "+" and "-".
The rule could still be that only one of them are allowed within one email.
That is that at the same time these two emails would be accepted.
box+123@domain.com
box-123@domain.com
Best regards,
Daniel Halan
Re: Domain setting "Plus addressing", multiple choice
Post by jimimaseye » 2018-02-09 13:41
viewtopic.php?f=20&t=29306
That allows all addresses (replacing plus-addressing functionality) with the ability for you to control what NOT to allow.
danielHalan
Post by danielHalan » 2018-02-10 19:17
Thanks! that does the trick.
Post by jimimaseye » 2018-02-10 22:17
Cheers. Personally i think it's a great feature - very useful worth obvious benefits.
claw
Post by claw » 2018-12-10 10:57
It would be awesome if we could use multiple delimiters (maybe custom?). I have had a few sites in the past where a plus character is marked as invalid. Some can get worked around if I disable JavaScript whilst registering, but some also do server side validation with the same restrictions (yay!). I also don't want disposable addresses as I want to receive mails to these addresses. Switching the delimiter is impossible as it's invalidating all previously registered eMail addresses, so now I don't have a chance to use plus addressing in a few websites.
Using forwarding accounts is cumbersome as I need to create a forwarder for every single "plus addressing account". I recently switched to using a single account and use plus addressing with aliases to forward to this account, so I am much more flexible as I only need to receive mails from one account.
A big push from me for this feature as it would avoid such stupid restrictions for "invalid" characters in an eMail address in 2018+.
Post by jimimaseye » 2018-12-10 12:06
claw wrote:
2018-12-10 10:57
They are not rfc compliant sites then. + signs and others are allowed according to rfc and should be accepted.
claw wrote:
2018-12-10 10:57
The script I referred to above will allow you. You can use or ignore the 'randomness' of disposable addresses as you wish but otherwise, with careful rule setup looking or for specific key word (ie 'user1alias'), you can achieve exactly what you want and it will not care what delimiter you used.
E.g. I could always have a keyword such as 'jim' and register addresses like
Jim+shopping@
Jim-ebay@
Etc
Then have rules that look for 'jim' at the start and forward accordingly.
