Rainer
- Normal user
Post
by Rainer » 2010-02-22 11:32
Hello HMS-Users!
I'm using a lot of IP-Ranges to block all the permanet spamming-fools!
Here is a improvement proposal for entering IP-Ranges!
After copy in field Lower-IP, examine whether a hyphen is present, then separate entry in Lower-IP and Upper-IP.
Kind regards
Rainer Noa
