Turn DKIM off for Certin Routes
Would this be usefull?
Yes
6
100%
No
0
No votes
Total votes: 6
PeterK2003
Post by PeterK2003 » 2009-06-16 15:30
I have to route some of my mail though my ISP b/c of my dynamic IP(not the best setup i know). For whatever reason my ISP adds a blank line to mail i send which breaks my DKIM sig which in turn causes some of my mail to get tagged as spam. Could there be a featured added to turn DKIM off by routes?
Keep up the good work!
Peter
Re: Turn DKIM off for Certin Routes
Post by martin » 2009-06-16 20:13
In the signing options in the domain settings, what canonicalization methods have you chosen?
Choosing relaxed might solve this specific problem, depending on what the ISP is doing...
PeterK2003
Post by PeterK2003 » 2009-06-16 20:34
pretty sure i have it set to relaxed but i will double check.
PeterK2003
Post by PeterK2003 » 2009-06-16 20:39
yep set to relaxed
westdam
Post by westdam » 2009-10-12 16:35
had my vote, similar to disable graylisting on routes.
i've created a similar request to unique one feature ( disable antispam or antivirus on certain routes)
