Bandwidth Logging
Do you need this feature?
Yes
40
87%
No
6
13%
Total votes: 46
tocpcs
Bandwidth Logging
Post by tocpcs » 2008-03-08 10:07
Logging bandwidth usage for each email account for SMTP and POP3 access.
I think this would be handy so that it can be seen what bandwidth is attributed to email account usage.
And it could have an 'other' view, so that emails that aren't delivered (or brute forcing, etc) can be placed in a seperate counter to be tallied.
Bandwidth logging, please?
tocpcs
Post by tocpcs » 2008-03-15 11:37
Anyone else interested in bandwidth logging?
It could simply be logging the data size of each message in or out from a user, and maintaining that for each email address?
mvanniek
Re: Bandwidth Logging
Post by mvanniek » 2008-11-14 13:58
Absolutely!
maggiore81
Post by maggiore81 » 2009-04-22 10:50
I have implemented awstats to log the hmailserver activity
Mr. Spadoni
Network Administrator
Spadhausen ISP
admin (at) spadhausen . com
pepsi
Post by pepsi » 2009-04-22 15:51
AWstats is great 1 problem.
if i send a message to 10 recipients in 2 domains. it will count the bandwith of the message times 10. instead of times 2
black zero
Post by black zero » 2009-04-26 12:41
Voted yes.
I am more than happy to do that. :D
Post by ^DooM^ » 2009-07-22 01:21
This would come under SNMP support.
Shiloh
Post by Shiloh » 2009-07-24 17:25
I would love an easy way to track bandwidth per mailbox and per domain. That would be awesome. It would really help us monitor for abuse. It would terrific if there were a few fields in the DB for tracking these things and some methods in the COM object for accessing the tracking metrics on a per user and per domain level.
Additionally, SNMP support for tracking server level metrics would be handy. We would not need per mailbox things exposed to SNMP, though.
Post by martin » 2009-07-24 17:42
It's hard for hMailServer to measure it's own bandwidth properly. It would be possible to measure the amount of data transmitted, but Windows will add data on top of that (routing information, checksums, source/destination info etc). And hMailServer doesn't know how Windows splits up the data it sends into individual packets and I don't think there's a way to detect it without some sort of coding which would be outside the scope of hMailServer. (Plus, the amount of data will differ depending on whether IPv4/v6 is used.)
Also, what if an external person sends a message to two internal users. Should those two pay for half of those bytes each?
pepsi
Post by pepsi » 2009-07-24 19:12
I would be happy if instead off bandwith the message size would be used to specific hosts
Post by ^DooM^ » 2009-07-24 19:35
I think an approximate value would suffice to be honest. Do it in octets just to confuse people ;)
Shiloh
Post by Shiloh » 2009-07-26 19:06
Just use the message size to tally bandwidth. The bandwidth total would not be an exact representation of the actual bandwidth used, but it would definitely be close enough.
On a message sent from an external person to two internal addresses, use the message size to apply to both internal addresses. You don't need to split the number. If a message is 10k and two people received it, add 10k to the inbound bandwidth total for both users.
The main reason I want this feature is to track abuse. Even if the numbers are not perfect measurements of actual bandwidth usage, we would still be able to spot abuse quickly. This makes it possible for me to close accounts that are violating TOS, and charge some users more who are legitimately using more resources.
Here are the metrics that I would like to see:
1) Bandwidth in per user
2) Bandwidth out per user
3) Number of messages received per user
4) Number of messages sent per user
5) Bandwidth in per domain
6) Bandwidth out per domain
7) Number of messages received per domain
8) Number of messages sent per domain
The per domain metrics would not need to be tracked. The per domain metrics could simply be generated using the per user metrics. Additionally, there could be a few different time periods to track for. Maybe daily, monthly, etc.
Post by martin » 2009-07-27 18:08
I don't agree that that is close enough. If you're using IMAP, the bandwidth just for the IMAP protocol may be comparable with the size of the messages the user receives. Sure, if your only goal is to track abuse than it won't be good enough. But I'm not going to implement a bandwidth meter which guesstimates bandwidth which may be 50% less than the actual used...
luci
Post by luci » 2009-09-17 11:06
So It would be hard to sum the length of data flowing to the socket connection for each user/domain ?
Radical Image Optimization Tool developer
Project Manager at CRIOSWEB
sheffters
Post by sheffters » 2009-09-17 12:58
http://hmaillive.ianbradshaw.co.uk/traffic.cgi
does some basic logging ... it has the problems listed above (re multiple mails and the like) ... but maybe a start without having to actually log network traffic.
S.
luci
Post by luci » 2009-09-17 14:08
It is very good. Will you publish it?
sheffters
Post by sheffters » 2009-09-17 14:19
I've open sourced it.
You can get it from http://forum.ianbradshaw.co.uk
I run it on hmail 5.1.2, but people have it working with later versions without change, just I haven't tested it yet.
Needs Perl and a few modules, so check the pre-requisits on there.
S.
luci
Post by luci » 2009-09-17 18:50
thanks for making this public :)
