Add Reply-To header for Distribution List
cristiano
Post by cristiano » 2005-07-28 16:25
For 4.1 or up versions only
 If InStr(oMessage.To, "distrlist@domain.com") Then
  oMessage.HeaderValue("Reply-To") = "distrlist@domain.com"
  oMessage.Save()
peter_mcc
Re: Add Reply-To header for Distribution List
Post by peter_mcc » 2006-07-24 15:31
And if you want to change the subject to show it was from a list you can do that easily too!
I added the "LCase()" conversion - is it needed?
 If InStr(LCase(oMessage.To), "distrlist@domain.com") Then
  If Not (InStr(lcase(oMessage.Subject), LCase("[List prefix]")) > 0) then
    oMessage.Subject = "[List prefix]" & oMessage.Subject
  end if
  oMessage.Save()
Peter
(edited later a couple of times)
Post by ^DooM^ » 2006-07-24 20:22
If InStr(LCase(oMessage.To, "distrlist@domain.com") Then
You are missing a matching brace.
If InStr(LCase(oMessage.To, "distrlist@domain.com")) Then
-Jon
peter_mcc
Post by peter_mcc » 2006-07-24 23:43
OOops. I actually meant to type
ie convert the "to" field to lower case before doing the check.
Peter
gsmaclean
Post by gsmaclean » 2008-04-16 18:45
Instr has a case-insensitive compare. You can write it as such:
If InStr(1, oMessage.To, "distrlist@domain.com", vbTextCompare) Then
HOWEVER - as I discovered today, this can have unintended consequences if not watched carefully. If you have a user "jsmith@domain.com", and a list "smith@domain.com", it will incorrectly identify mail to "jsmith@domain.com" as being a list mail, because it contains the string "smith@domain.com".
There is no real perfect solution, but this is what I ended up using:
  If IsMessageToList(oMessage, "list1@domain.com") Then
    oMessage.HeaderValue("Reply-To") = "list1@domain.com"
  If IsMessageToList(oMessage, "list2@domain.com") Then
    oMessage.HeaderValue("Reply-To") = "list2@domain.com"
Function IsMessageToList(oMessage, sList)
  IsMessageToList = False
  If LCase(oMessage.To) = LCase(sList) Then IsMessageToList = True
  If LCase(oMessage.CC) = LCase(sList) Then IsMessageToList = True
  If InStr(1, oMessage.To, "<" & sList & ">", vbTextCompare) Then IsMessageToList = True
  If InStr(1, oMessage.CC, "<" & sList & ">", vbTextCompare) Then IsMessageToList = True
andyp
Post by andyp » 2009-01-24 18:51
I have a script doing the same. But be aware if you have an email to more than one distribution list, this won't work. I duplicate the msg and change it for every recipient.
