Maximum message size
Post by martin » 2005-07-27 14:40
This script lets you define a server-wide maximum message size. To change the maximum message size, change the value 1024 to something else.
Requirements
hMailServer 4. Works fine in 4.1 as well, but in that version it's better and easier to use the built-in functionality to limit the message size. (The built-in functionality requires less CPU resources)
  Dim iMaximumMessageSizeKB
  iMaximumMessageSizeKB = 1024
  If oMessage.Size > iMaximumMessageSizeKB Then
     ' Reject the message since it's larger than
     ' the maximum message size.
     Result.Message = "This message is to big. Maximum message size is " & iMaximumMessageSizeKB & " KB"
     Result.Value = 2
     ' Accept the message
     Result.Value = 0
