Delete messages after 30 days from INBOX.spam
aty154
Post by aty154 » 2009-11-13 11:09
' DelOldSpam.vbs - Scott MacLean - v1.1 - 07/11/2008
' Some Edits made by Chris Dixon - 09/08/2008 using some scripting found in forum
Dim AdminUser
Dim AdminPass
Dim FromEmail
Dim ReportToEmail
Dim DaysOfSpam
Dim DaysAfterSpam ' Added by Chris Dixon
AdminUser = "xxxxxx" ' Replace this with your administrator username
AdminPass = "xxxxxxx"  ' Replace this with your administrator password
FromEmail = "xxxx@xxxx.com" ' Replace this with the email address you want the report to come "from"
ReportToEmail = "xxxx@xxxx.com" ' Replace this with the email address you want the report to be sent to
DaysOfSpam = 7 ' Replace this with the number of days spam is kept before being deleted
DaysAfterSpam = 2 ' Replace this with the number of days future date spam is kept before deleted - Added by Chris Dixon
SendSpamReport = True ' If true, each user gets an email listing all emails in their spam folder, if false, no email is sent
Dim App
Dim Domains
Dim Domain
Dim Accounts
Dim Account
Dim IMAPFolders
Dim IMAPFolder
Dim Messages
Dim oMessages ' Added by Chris Dixon
Dim Message
Dim oMessage ' Added by Chris Dixon
Dim vbDate ' Added by Chris Dixon
Dim DomainNum
Dim AccountNum
Dim IMAPFolderNum
Dim MessageNum
Dim oMessageNum ' Added by Chris Dixon
Dim FoundSpamFolder
Dim OutputMsg
Dim NumMsgs
Dim AccountSize
Dim NumSpams
Dim NumDeleted
Dim TotalAccounts
Dim TotalNumMsgs
Dim TotalAccountSize
Dim TotalNumSpams
Dim TotalNumDeleted
Set App = CreateObject("hMailServer.Application")
Call App.Authenticate(AdminUser, AdminPass)
TotalNumMsgs = 0
TotalAccountSize = 0
TotalNumSpams = 0
TotalNumDeleted = 0
Set Domains = App.Domains
For DomainNum = 1 To Domains.Count
  Set Domain = Domains.Item(DomainNum - 1)
  If Domain.Active Then
    Set Accounts = Domain.Accounts
    NumMsgs = 0
    AccountSize = 0
    NumSpams = 0
    NumDeleted = 0
    For AccountNum = 1 To Accounts.Count
      Set Account = Accounts.Item(AccountNum - 1)
      If Account.Active Then
        Set IMAPFolders = Account.IMAPFolders
        FoundSpamFolder = False
        For IMAPFolderNum = 1 To IMAPFolders.Count
          Set IMAPFolder = IMAPFolders.Item(IMAPFolderNum - 1)
          If LCase(IMAPFolder.Name) = "spam" Then
            FoundSpamFolder = True
            Exit For
        If Not FoundSpamFolder Then Set IMAPFolder = IMAPFolders.Add("spam")
          Set Messages = IMAPFolder.Messages
          If UCase(IMAPFolder.Name) = "spam" Then
            NumSpams = NumSpams + Messages.Count
            TotalNumSpams = TotalNumSpams + Messages.Count
          NumMsgs = NumMsgs + Messages.Count
          TotalNumMsgs = TotalNumMsgs + Messages.Count
          For MessageNum = Messages.Count To 1 Step -1
            Set Message = Messages.Item(MessageNum - 1)
            AccountSize = AccountSize + Message.Size
            TotalAccountSize = TotalAccountSize + Message.Size
              If DateAdd("d", DaysOfSpam, Message.InternalDate) < Now Then
                NumDeleted = NumDeleted + 1
                TotalNumDeleted = TotalNumDeleted + 1
                Messages.DeleteByDBID Message.ID
          ' Start of Added Code by Chris Dixon
          Set oMessages  = Account.IMAPFolders.ItemByName("spam").Messages
          For oMessageNum = oMessages.Count To 1 Step -1
            Set oMessage = oMessages.Item(oMessageNum - 1)
            If (vbDate > CDate(Now + DaysAfterSpam)) Then
              oMessages.DeleteByDBID(oMessage.ID)
          ' End of Added Code by Chris Dixon
          If UCase(IMAPFolder.Name) = "spam" And SendSpamReport Then
            If Messages.Count > 0 Then
              SpamMsg = "<font face=""Arial""><p>The following " & Messages.Count & " messages are currently being held in your Spam mail folder. "
              SpamMsg = SpamMsg & "Any messages older than " & DaysOfSpam & " days will be deleted.</p>" & vbCrLf
              SpamMsg = SpamMsg & "<table border=""1""><tr><td><b>From</b></td><td><b>Date</b></td><td><b>Subject</b></td></tr>" & vbCrLf
                SpamMsg = SpamMsg & "<tr><td>" & BReplace(Message.From) & "</td><td>"
                SpamMsg = SpamMsg & FormatDateTime(Message.InternalDate,vbShortDate) & " " & FormatDateTime(Message.InternalDate,vbLongTime) & "</td>"
                SpamMsg = SpamMsg & "<td>" & BReplace(Message.Subject) & "</td></tr>" & vbCrLf
              SpamMsg = SpamMsg & "</table></font>"
              Set Message = CreateObject("hMailServer.Message")
              Message.From = "Spam Deletion Daemon <" & FromEmail & ">"
              Message.FromAddress = FromEmail
              Message.AddRecipient "DixonVision Network User", Account.Address
              Message.Subject = "Daily Spam Folder Report"
              Message.HTMLBody = SpamMsg
              Message.Save
    TotalAccounts = TotalAccounts + Accounts.Count
    OutputMsg = OutputMsg & "<tr><td>" & Domain.Name & "</td>"
    OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(Accounts.Count, 0, True, False, True) & "</td>"
    OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(AccountSize, 0, True, False, True) & "K</td>"
    OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(NumMsgs, 0, True, False, True) & "</td>"
    OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(NumSpams, 0, True, False, True) & "</td>"
    OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(NumDeleted, 0, True, False, True) & "</td></tr>" & vbCrLf
OutputMsg = "<font face=""Arial""><table border=""1""><tr><td><b>Domain</b></td><td align=""right""><b>Users</b></td><td align=""right""><b>Size</b></td><td align=""right""><b>Messages</b></td><td align=""right""><b>Spam</b></td><td align=""right""><b>Deleted</b></td></tr>" & vbCrLf & OutputMsg
OutputMsg = OutputMsg & "<tr><td><b>Total</b></td>"
OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(TotalAccounts, 0, True, False, True) & "</td>"
OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(TotalAccountSize, 0, True, False, True) & "K</td>"
OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(TotalNumMsgs, 0, True, False, True) & "</td>"
OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(TotalNumSpams, 0, True, False, True) & "</td>"
OutputMsg = OutputMsg & "<td align=""right"">" & FormatNumber(TotalNumDeleted, 0, True, False, True) & "</td></tr>" & vbCrLf
OutputMsg = OutputMsg & "</table></font>" & vbCrLf
Message.AddRecipient "System Administrator", ReportToEmail
Message.Subject = "Daily spam deletion report"
Message.HTMLBody = OutputMsg
Message.Save
Function BReplace(InputString)
  BReplace = Replace(Replace(InputString, "<", "<"), ">", ">")
I run above script on my hmailserver version 4.4-B270 with mysql 4 on windows server 2003. Script didn't show any error or messages but not able to detect emails in spam folder and delete them.
I have difference in my hmailserver setup like spam emails are moved into IMAP folder "INBOX.spam" word "spam" is in small cap and secondly spam folder contains 6-7 months older emails which need to be deleted.
Please help me run this script.
Re: Delete messages after 30 days from INBOX.spam
Post by ^DooM^ » 2009-11-13 11:10
That script is written around the default spam mailbox that is setup on the root of the server not placed in the inbox. I suggest you move spam to this new folder or pay someone to change it for you to support sub folders.
Also if you want to empty inbox.spam login with an email client or webmail like squirrelmail and delete it.
