Old log removal script
bladerunner
Post by bladerunner » 2008-05-28 11:24
' note: the awstats log file is not deleted as his date is updated by daily changes :)
Dim Fso
Dim Directory
Dim Modified
Dim Files
strLogFIleSuffix = ".log"
' change following installation...
strPath = "C:\Programmi\hMailServer\Logs"
' how many days to allow...
intDaysOld = 3
Set Fso = CreateObject("Scripting.FileSystemObject")
Set Directory = Fso.GetFolder(strPath)
Set Files = Directory.Files
For Each Modified in Files
If DateDiff("D", Modified.DateLastModified, Now) > intDaysOld and lcase(right(Modified,4))=strLogFIleSuffix Then
' uncomment when sure it works fine ! check before run
' Modified.Delete
WScript.Echo(" Will delete " & Modified.Name)
end if
jbaitz
Re: Old log removal script
Post by jbaitz » 2008-12-10 20:58
Bladerunner...I am not able to get the script to delete the log files. When I uncomment the delete line it no longer displays the list of files to be deleted and doesn't clear any of my log files.
I have changed the path to point to my hmail server logs and I have changes the number of days to 14 which is what we want to keep.
When I run the script with the delete commented out it lists the files I would expect it to however that doesn't occur nor does the delete once I uncomment the delete line.
Justin
Schnurps
Post by Schnurps » 2008-12-10 21:57
To really delete Files the Script has to look like this:
Dim Fso
Dim Directory
Dim Modified
Dim Files
strLogFileSuffix = ".log"
intDaysOld = 30
Modified.Delete
'  WScript.Echo(" Will delete " & Modified.Name)
end if
Hope this helps....
jbaitz
Post by jbaitz » 2008-12-10 23:02
Thanks that made it work.....I hadn't commented out the Wscript line.
Justin
bladerunner
Post by bladerunner » 2008-12-10 23:20
yes sorry, a small type mistake
the delete statement does the deletion....
other is just a prompt, to be removed in a batch safe environment
Caspar
Post by Caspar » 2008-12-12 16:04
what kind of extension do you need to save this script in?
Post by mattg » 2008-12-12 16:57
looks like .vbs to me
bladerunner
Post by bladerunner » 2009-04-05 09:01
obv this script works for version 5.x and 6.x too :)
LesD
Post by LesD » 2009-04-24 13:07
Before using the script I wanted to understand what it does.
There is one thing that foxes me.
The is a decleration for "Modified" and it is then used to control the loop but I cannot see where it is set. What does it represent?
LesD
Post by LesD » 2009-04-24 13:51
Sorry - I was being thick! The For loop sets it. This is not quite the syntax that I am used to.
