make plain text from HTML
Post by mattg » 2008-05-08 14:28
Been playing with this for a while.
I have a unusual localised industry specific e-mail client, that doesn't handle HTML only e-mails.
This script modifies the HTML into plain text, and removes the HTMLBody of the e-mail.
This script works for my unusual client, but doesn't make an e-mail that displays in Outlook 2003. This suits me, but it may need to be modified slightly for others.
Modify at will, use at own risk, etc.
	dim counter, aMessage
	for counter = 0 to oMessage.recipients.count -1
		if oMessage.recipients(counter).address = "[b]youruser@yourdomain.com[/b]" then
			aMessage = StripHTML(oMessage.HTMLBody)
			omessage.htmlbody = ""
			oMessage.body = aMessage
		end if
	next	'counter
	Result.Value = 0
function StripHTML(oSource)
dim Result_Text, breaks, tab, i
	Result_text = ReplaceText(oSource," ( )+"," ")
	Result_text = Replace(Result_text,"=" & vbcrlf,"")
	Result_text = Replace(Result_text,";" & vblrcf,"")
	'add more lines as above where needed
'	Result_text = Replace(Result_text,"=" & vblrcf,"")
	' Remove the header (prepare first by clearing attributes)
	Result_text = ReplaceText(Result_text,"<( )*head([^>])*>","<head>")
	Result_text = ReplaceText(Result_text,"(<( )*(/)( )*head( )*>)","</head>")
	Result_text = ReplaceText(Result_text,"(<head>)[\s\S]*(</head>)","")
	' remove all scripts (prepare first by clearing attributes)
	Result_text = ReplaceText(Result_text,"<( )*script([^>])*?>","<script>")
	Result_text = ReplaceText(Result_text,"(<( )*(/)( )*?script()*>)","</script>")
	Result_text = ReplaceText(Result_text,"(<script>)([^(<script>\.</script>)])*?(</script>)","")
	Result_text = ReplaceText(Result_text,"(<script>)[\s\S]*?(</script>)","")
	' remove all styles (prepare first by clearing attributes)
	Result_text = ReplaceText(Result_text,"<( )*style([^>])*?>","<style>")
	Result_text = ReplaceText(Result_text,"(<( )*(/)( )*?style( )*>)","</style>")
	Result_text = ReplaceText(Result_text,"(<style>)[\s\S]*?(</style>)","")
	' prepare spans by first clearing attributes
	Result_text = ReplaceText(Result_text,"<( )*span([^>])*?>","<span>")
	Result_text = ReplaceText(Result_text,"(<( )*(/)( )*?span( )*>)","</span>")
	' insert tabs in spaces of <td> tags
	Result_text = ReplaceText(Result_text,"<( )*td([^>])*>","\t")
	' insert line breaks in places of <BR> and <LI> tags
	Result_text = ReplaceText(Result_text,"<( )*br( )*>","\r\r")
	Result_text = ReplaceText(Result_text,"<( )*li( )*>","\r\r")
	' insert line paragraphs (double line breaks) in place if <P>, <DIV> and <TR> tags
	Result_text = ReplaceText(Result_text,"<( )*div([^>])*>","\r\r")
	Result_text = ReplaceText(Result_text,"<( )*tr([^>])*>","\r\r")
	Result_text = ReplaceText(Result_text,"<( )*p([^>])*>","\r\r")
	' Remove remaining tags like <a>, links, images, comments etc - anything thats enclosed inside < >
	Result_text = ReplaceText(Result_text,"<[\s\S]*?>","")
        ' replace special characters:
	Result_text = ReplaceText(Result_text,"&bull;"," * ")
	Result_text = ReplaceText(Result_text,"&lsaquo;","<")
	Result_text = ReplaceText(Result_text,"&rsaquo;",">")
	Result_text = ReplaceText(Result_text,"&trade;","(tm)")
	Result_text = ReplaceText(Result_text,"&frasl;","/")
	Result_text = ReplaceText(Result_text,"<","<")
	Result_text = ReplaceText(Result_text,">",">")
	Result_text = ReplaceText(Result_text,"&copy;","(c)")
	Result_text = ReplaceText(Result_text,"&reg;","(r)")
	' make line breaking consistent
	Result_text = Replace(Result_text,"\n","\r")
	' Remove extra line breaks and tabs:
	' Prepare first to remove any whitespaces inbetween
	' the escaped characters and remove redundant tabs inbetween linebreaks
	Result_text = ReplaceText(Result_text,"(\r)( )+(\r)","\r\r")
	Result_text = ReplaceText(Result_text,"(\t)( )+(\t)","\t\t")
	Result_text = ReplaceText(Result_text,"(\t)( )+(\r)","\t\r")
	Result_text = ReplaceText(Result_text,"(\r)( )+(\t)","\r\t")
	' Remove redundant tabs
	Result_text = ReplaceText(Result_text,"(\r)(\t)+(\r)","\r\r")
	' Remove multible tabs followind a linebreak with just one tab
	Result_text = ReplaceText(Result_text,"(\r)(\t)+","\r\t")
	' Initial replacement target string for linebreaks
	breaks = "\r\r"
	' Initial replacement target string for tabs
	tabs = "\t\t\t"
	for i=0 to 5
		Result_text = Replace(Result_text, breaks, vbcrlf)
		Result_text = Replace(Result_text, tabs, "")
		Result_text = Replace(Result_text, vbcrlf & vbcrlf & vbcrlf, vbcrlf & vbcrlf)
	next 'i
	Result_text = Replace(Result_text, "&nbsp", "")
        ' Thats it.
      	StripHTML = Result_Text
Function ReplaceText(str1, patrn, replStr)
	Dim regEx
	Set regEx = New RegExp
	with regEx
		.Pattern = patrn
		.IgnoreCase = True
		.Global = True
	end with
	ReplaceText = regEx.Replace(str1, replStr)
Re: make plain text from HTML
Post by Bill48105 » 2012-07-27 02:48
Hey Matt!
Old thread but wanted to say THANKS for this. Saved me having to write it myself. :D Few minor tweaks for my needs & had it stripping HTML for UPS email alerts sent to my cell text messages in just a couple minutes.
One thing I needed was to set the HTML to the plain version instead of empty like:
oMessage.htmlbody = aMessage
Seems hmail doesn't remove the html MIME part & some email clients show blank email if set to "". Of course the choice would depend on email client.
Post by mattg » 2012-07-27 04:08
no worries mate
dzekas
Post by dzekas » 2012-07-27 06:53
how about replacing all tags that need convertion to line feed first and then removing all tags.
list of special characters is a bit longer.
dzekas
Post by dzekas » 2012-07-27 19:20
Bill48105 wrote:I wasn't attempting to critique or improve his script
Maybe there is some language barrier. It looks like simple suggestions are interpreted as critique here. :)
Post by mattg » 2012-07-28 09:05
It's 'all good' Dzekas.
You input is always valuable. You have a far higher technical skill than I. I always learn from what you say.
atahir
Post by atahir » 2016-10-19 00:01
Sorry to necro post.
Is there a way to modify the above so that the lines are maintained.
Currently the script will strip everything out and put everything in to one line, can it be made to keep the text in multiple lines?
Thanks in advance for any help
Post by mattg » 2016-10-19 16:03
sure, just remove the regex lines that replace line endings with an empty string
atahir
Post by atahir » 2016-10-19 22:50
Thanks for the reply Matt, much appreciated.
atahir
Post by atahir » 2016-10-20 03:59
Not having much luck your suggestion, pretty sure I'm doing it wrong.
Don't suppose you're able to provide an example of the modification you mention?
Post by mattg » 2016-10-20 05:23
      end if
   next   'counter
   Result.Value = 0
  ' Result_text = ReplaceText(Result_text,"(\r)(\t)+","\r\t")                                     Probably just commenting out this line will do what you need.
   breaks = "\r\r"
   tabs = "\t\t\t"
   for i=0 to 5
   next 'i
        ' Thats it.
   Dim regEx
   with regEx
      .Pattern = patrn
      .IgnoreCase = True
      .Global = True
   end with
All of the VBCRLFs should be swapping HTML new line characters for VB new line commands. there should be heaps of new lines created
Just commenting out that one line I detail should add more line endings.
If not please post an example of the HTML you'd like fixed...
atahir
Post by atahir » 2016-10-21 04:59
Hi Matt,
Still having an issue, here is some further info:
Original Email sent as:
<html dir=3D"ltr"><head><title></title></head><body>From: XX To: =
00000000000 </body></html><br /><br /><span style=3D>------------=
-----------------------------<br />Service Record #146974<br />Su=
mmary: Alert: Agent Status on User-PC is Failed -- <br />Company:=
 Test Company<br />Contact: Test User<br />Phone:   000000000=
00<br /></span>
Renders as:
To: 61000000000
Service Record #144177
Summary: Alert: Agent Status on User-PC is Normal --
Company: Test Company
Contact: Test User
Phone: 61000000000
After Script is applied:
This is a multi-part message.
--__=_Part_Boundary_001_012927.014982
Content-Type: text/plain; charset="us-ascii"
From: XXTo: 61000000000-----------------------------------------Service Record #146962Summary: Alert: Agent Status on User-PC is Normal -- Company: Test CompanyContact: Test ContactPhone: 61000000000
Content-Type: text/html; charset="us-ascii"
--__=_Part_Boundary_001_012927.014982--
Appears as:
Ideally just trying to get the Text and different lines happening so that it looks like:
To: 61000000000
Contact: Test User
Phone: 61000000000
Thanks a bunch
Post by mattg » 2016-10-24 00:52
Just as a matter of interest, do you have SMTP >> RFC Compliance >> 'Allow incorrectly formatted line endings' selected??
What you want changed is not in the HTML text, but in the Message source.
Looking at some messages on my system, The longest line is typically about 80 characters..
I'm wondering if you allow incorrectly formatted line endings, if hMailsevrer will just sort this out for you automatically
