Global Blacklist
Do you need this feature?
Yes
24
86%
No
4
14%
Total votes: 28
rodolfor
Global Blacklist
Post by rodolfor » 2006-12-30 12:06
Hi Martin.
The whitelist in 4.4 is fantastic.
Why not to ADD A GLOBAL BLACKLIST, with the same features of the whitelist except that a message matching the blacklist is rejected (with a message) ?
thanks.
Hmailserver [lastversion] + MSSQL
Slug
Post by Slug » 2006-12-30 12:25
This is just my 2 cents, but any list that has to be manually maintained is never good for the long term, as things change and people forget to update these lists. Some stage in the future legitimate email will be issued with a blacklisted IP and then this person will never get through.
It might be helpful to some people but not me.
Michael
rodolfor
Post by rodolfor » 2006-12-30 12:33
Well.
Infact I think to a short-term function.
If I need to block immediately an IP/domain/address, now I can use only a rule wich is not simple and I think is slow.
The black and white list are methods to correct the other systems (black/grey/surbl list) and to do a "fliyng" operation.
Slug
Post by Slug » 2006-12-30 12:45
rodolfor wrote: If I need to block immediately an IP/domain/address, now I can use only a rule wich is not simple and I think is slow.
I can see what you mean here. :)
Michael
yinrunning
Post by yinrunning » 2007-01-05 22:42
What about a list with a set-able "timer"?
IP: _________ Days to Keep in BL: ______ ( 0 for infinite )
There's several IP's I'd like to Black Out for a couple weeks or so.
RaindogTwo
Post by RaindogTwo » 2007-01-10 01:11
I like yinrunning's idea of a time period. Though would like to add that is should ban the blacklisted IP from all mail traffic (SMTP/POP/IMAP).
My issue is with script kiddies trying to gain access to pop acounts.
~20,000 attempts in a 45 min span today!
BOOZy
Post by BOOZy » 2007-02-05 15:13
I'd really like to see this feature.
And if Jon could add this to his grey-list viewer, it would be easy to block IP addresses of known bot-net nodes.
I'm not worried about missing out on legitimate mail that way, as the source IPs will never become legitimate mail servers.
Link to grey-list viewer: http://www.hmailserver.com/forum/viewtopic.php?t=6698
Post by ^DooM^ » 2007-02-05 18:46
That would be easily added to my script if the blacklist was ever implemented. However there is still the issue of cached whitelist and most likely blacklist entries in hmail that would mean hmail needs to be stopped and started to make use of my script as I place entries directly into DB.
The only other option would be to script it with COM API access required as well which I was trying to avoid.
BOOZy
Post by BOOZy » 2007-02-05 22:50
Feature request for a flush-flag?
Post by ^DooM^ » 2007-02-06 02:50
Now that is a nice idea..
Added a poll here http://www.hmailserver.com/forum/viewtopic.php?t=7638
ikshadow
Post by ikshadow » 2007-05-08 17:25
I hope there will be global black list its very good idea, there is a bunch of IPs that i would like to block (not blocked in black lists )
p.s. Mybe for global black list you could have auto reply option blocked by %host% contact admin etc.. in case there is some mistake etc...
hMailServer 5.4-B1950
MySQL 5.1.73
Domains: 32, Accounts: 1000+ , Messages: 1000.000+, Data size: 200GB+
Running since 18.7.2006 (hMailServer 4.2.2 - Build 199)
DjGL
Post by DjGL » 2007-05-08 17:56
Oh yes a blacklist would be fine and with the possibility (yinrunning's idea) of adding a time for whitelist and blacklist this would be almost perfect!
Post by ^DooM^ » 2007-05-08 19:05
If a blacklist was implemented a bounce message would need to be optional per ip address / range added so as not to cause more spam.
