Exception from autoban for webmail IP (whitelist)
micha
Post by micha » 2015-04-30 11:42
hi there,
it would be a nice feature if there could be an exception defined from autoban. For example, we could whitelist the webmail IP address.
If necessary, the webmailservice could be protected by a captcha, but will no longer be blocked on user or scripting failures.
Micha
Re: Exception from autoban for webmail IP (whitelist)
Post by mattg » 2015-04-30 11:46
https://www.hmailserver.com/documentati ... ce_autoban
To solve this problem, you can whitelist the webmail system. A workaround to this problem is to add a new IP range matching the shared IP address and give this IP range higher priority than any IP range added by the auto-ban functionality. The IP ranges added by auto-ban is given the priority 20, so if your own IP range has priority 25 it will take precedence.
Post by SorenR » 2015-04-30 12:50
micha wrote:hi there,
Micha
http://lmgtfy.com/?q=auto-ban+webmail+s ... server.com
It's really amazing how much Google know about stuff...
By the way ... I use this https://github.com/stalks/roundcube-defense with my Webmail to make up for the bypassed Auto-ban.
micha
Post by micha » 2015-04-30 14:28
OMG, reading helps.... :-)
