do not replace new lines in error message
terifo
Post by terifo » 2014-09-03 12:31
I am suffering to make our bounce management working and found out that the original hMailServer bounce management is not sufficient.
The problem is that it does not include original headers in the body of the mailer daemon message - more specifically Message-ID header.
I found this script viewtopic.php?f=20&t=18029 that is fixing this problem.
However, before hMailServer calls this script, it damages the error message content, which is done by this code in hmailserver\source\Server\Common\Scripting\Events.cpp:
         if (sScriptLanguage == _T("VBScript"))
            sRecipientCopy.Replace(_T("\""), _T(""));
            sErrorMessageCopy.Replace(_T("\""), _T(""));
            sErrorMessageCopy.Replace(_T("\r"), _T(""));
            sErrorMessageCopy.Replace(_T("\n"), _T(""));
            sErrorMessageCopy.TrimLeft();
            sErrorMessageCopy.TrimRight();
            sEventCaller.Format(_T("OnDeliveryFailed(HMAILSERVER_MESSAGE, \"%s\", \"%s\")"), sRecipientCopy, sErrorMessageCopy);
This removes formating of the error message - it removes new lines and thus in VBS script we have only a one liner from which the original error message is impossible to restore.
Those lines remove \r and \n are the problem.
Re: do not replace new lines in error message
Post by percepts » 2014-09-03 12:47
enhancement requests should now be placed in Github at:
https://github.com/hmailserver/hmailser ... =is%3Aopen
terifo
Post by terifo » 2014-09-03 16:25
ok, will try to post it there, thanks
Post by martin » 2014-10-10 12:53
Implemented in 5.6.
Martin Knafve
martin@hmailserver.com
https://twitter.com/knafve
