help documentation formatting
How would you like to see help doc improvements in formatting?
Yes, it can be a little difficult to read. Some little tweaks help a lot.
2
67%
No, It's fine. I remember the days when docs were all in ASCII text and I downloaded them on my 1200 baud Hayes. Get off my lawn!!
0
No votes
I know it all and don't use any help documentation! Let them work on the core.
1
33%
Total votes: 3
kipp
Post by kipp » 2014-04-30 08:44
I find the documentation very difficult to read.
With a minimal amount of css changes it could be much easier to read.
I made a sample change only adding style codes for api_method_name and api_description.
My request is for some small changes such as the example here.
BEFORE
AFTER
Re: help documentation formatting
Post by Bill48105 » 2014-04-30 09:24
Are you volunteering? :D
I'd have to ask martin but I think there is a story behind the formatting or lack of. Either the site was converted or imported or restored or something. Surely there is a logical explanation.
Post by percepts » 2014-04-30 14:11
I agree that the com api reference is not easy to find anything if you are trying to find functions or properties.
But there is a better way to find out about whats available in the way of COM API functions.
Anyone writing scripts should have some windows development tool or script editor with an Object Browser in it.
You can load "hMailserver Type Library" into your object browser and its then real easy to to find all the objects, properties and functions available in the COM API
Perhaps just a quick note in documentation that you can do this would help as an interim solution.
kipp
Post by kipp » 2014-05-02 06:35
I am just using notepad++ for everything... maybe there is a plugin object browser. I'll have to check. I'm probably not the only unsophisticated programmer around so I am volunteering to update the the object reference pages. I can grab the online files and send them back when updated.
Post by percepts » 2014-05-02 22:26
if you have a copy of MS Office that used to come with a script editor which has object browser. You would need to install the scripting option of MS Office.
And Visual Studio express which is free has it too.
kipp
Post by kipp » 2014-05-06 19:53
Ok thanks. I will load express and check that out. Thanks.
Post by martin » 2014-08-16 10:21
I've done some small tweaks to it and it's not pretty but it's better. :)
https://hmailserver.com/documentation/l ... t_accounts
The css for the API is here:
https://hmailserver.com/documentation/api-styles.css
If someone has any suggestions on further improvements, please share.
Post by mattg » 2014-08-16 14:35
Particularly in the COM API section of the docs, I'd like to see a set of branch links at the top of each page, like
Main | Other | COM API | Accounts object
All being links, and the 'Domains object' being listed between 'COM API' and 'Accounts object', and so attachments would look like
Main | Other | COM API | Domains Object | Accounts object | IMAP folders object | Messages object | Attachments object
with each of them being links
