suggestion: messagefilename in database
Locked
stephan123
Post by stephan123 » 2010-03-25 12:45
I have a suggestion which could solve issues with moving data-folder around and could even save a lot of disk space for tables due to removing redundancies.
As I followed some of the discussions, moving data folder from one location to another is a frequently done job, especially when migrating from one server to a new one.
My suggestion is to not save the complete path to the database like
E:\hMailServer\Data\#Public\23\{238FE437-FAB3-47C3-8FAE-C4ECC8B8448E}.eml
but to strip down any redundant part and have only
in the tables.
This should not be too hard to implement because the path is saved in the ini-file. So instead of fetching the complete path from the database, the only thing to do is to prepend the path from the ini.
So, in my case, I could save 20 bytes Diskspace per Mail and I could easily move data folder around by simply changing the ini-file which is necessary anyway. This will work as long as the sructure within \Data\ remains unchanged.
What do you think? Wouldn't that be possible?
Stephan
Re: suggestion: messagefilename in database
Post by ^DooM^ » 2010-03-25 13:06
This has already been implemented in the next major version.
Please search the forum before making feature requests.
stephan123
Post by stephan123 » 2010-03-25 13:52
^DooM^ wrote:This has already been implemented in the next major version.
Wups, sorry for the noise.
Locked
