use specific smtp-rela for each account
Would you like such a feature?
Yes
1
100%
No
0
No votes
Total votes: 1
Neo.P5
Post by Neo.P5 » 2009-12-07 15:05
if using hmailserver to collect external pop3 accounts it would be good to have the possibility to send your email via the corresponding smtp-relay. even if you have multible domains running.
like this situation:
i have some different pop3 accounts on my isp (1and1), a some google-mail account and some private hostet servers and i am using external-account-setting to collect my mails from these. if you are running hmail via dyndns (like me) it difficult to send outgoing email via the corresponding smtp-account cause there is some trouble to connect to different external smtp´s. also if the mx-entry is (and can not set) to your ip.
a definable smtp-relay for each account would solve this problem.
by the way: with this hmail can also be used as a kind of mail-proxy...
i have no such feature found in documentation...
who is also interested in this feature?
Re: use specific smtp-rela for each account
Post by ^DooM^ » 2009-12-07 15:56
lookup ip range external to external for mail proxy answer.
Neo.P5
Post by Neo.P5 » 2009-12-07 20:56
thanks for the tip,
but that not actually what i´m looking for.
a short example:
i have two pop3 mailboxes and each has a smtp-relay.
EMail: user1@xy.de
Pop3Box: pop.xy.de
Smtp-Relay: smtp.xy.de
User: user1
Password: Pass1
Email2: foobar@blablablasomthing.com
pop3Box: pop.blalbalbasomething.com
smtp-relay: smtp.blablablasomething.com
User: foobar
Password: Pass2
User and password are both the same for pop and smtp!
both pop3 boxes are fetched by external option to my local hmail-server.
if i send now a message from user1@xy.de it should be delivered through the smtp-relay smtp.xy.de; the same with foobar@blablablasomething.com / smtp.blablablasomething.com.
so you see, in this case hmail server is acting like a mail-proxy and passes the local-mail to this (specially configured) external smtp-relay (for each account an other one!).
is it now clear what i mean? (sorry my english is not the best ;)
Post by mattg » 2009-12-08 02:01
Neo.P5
Post by Neo.P5 » 2009-12-08 07:41
ok, seems to work!
Thank you for your knowledge and for sharing it.
it´s always good to learn ;)
@admin: please close and/or delete this thread!
