ClamAV client integration like spamassassin
do you need this feature?
Yes
23
96%
No
1
4%
Total votes: 24
westdam
Post by westdam » 2009-11-12 17:53
as mentioned here http://www.hmailserver.com/forum/viewto ... 516#p96516 , i'd like the idea of a ClamAV client integration like Spamassassin. This should solve most of the trouble related to clamwin and his slowness.
AFAIK could be used 2 clamav for win32 port :
TBB
Gianluigi
both are ok. Also seems from 0.96 verision clamav would provide a win32 native version too. ( 0.96 should be out on feb. 2010 as the roadmap )
This can improve the use of clamav instead clamwin and reduce the trouble with scanning email/hung server due to clamscan.exe bad performance.
The clamwin tabs, in my opinion , should be removed and replaced by this client.
If someone still wants to use clamwin just use the external tools.
what do you think?
hope martin dont bother me if i've create this poll..
Re: ClamAV client integration like spamassassin
Post by mattg » 2009-11-13 10:25
I use ClamAV from the ClamWIN tab by following DFitch's initial post in this thread http://www.hmailserver.com/forum/viewto ... 12&t=13699
westdam
Post by westdam » 2009-11-13 11:14
good to remember mattg.. it's easy to setup :)
BUT on my system wont work!!! :( i think it's something related to the languages&default path ( i'm italian and i ALWAYS use default path )
Post by mattg » 2009-11-15 13:36
Yep, I had to go back to standard path of "C:\Clamav" for freshclam to work properly
(If I recall correctly... :roll: )
westdam
Post by westdam » 2009-11-17 16:12
i'm using default path, clamD.exe is in memory, i've checked and configured hmailserver to use clamDscan.exe ( even with the clamwin tabs configured with clamdscan.exe instead or external scanner too ) but hmailserver wont scan files. i cant see any clamdscan.exe process and hmailserver wont use it.. i think it's something related to the path.
also , after 1 week of clamd.exe becomes larger, larger, larger and then my server crashes.. ( need to reboot!!). i'm using tbb default conf. Tried the SAME configuration on a english win2k3 web edition and , damn, it works!!!
tBB
Post by tBB » 2009-11-17 17:41
westdam wrote:Tried the SAME configuration on a english win2k3 web edition and , damn, it works!!!
Even if this seems to get a bit off-topic now, under which OS and CPU it doesn't work?
Best regards,
Nico
westdam
Post by westdam » 2009-11-17 18:06
os is win2k3 web edition italian version with pentium D dual core
with a win2k3 web edition english version with a core2duo ( cant use same hw ) works. default path.
yep,sorry for the ot
Post by ^DooM^ » 2010-06-18 12:06
Duplicate of http://www.hmailserver.com/forum/viewto ... viewresult
I'll get the votes moved over.
Post by ^DooM^ » 2011-10-31 16:31
Done as of 5.4
