hMail Administrative interface modifications
maggiore81
Post by maggiore81 » 2009-10-07 10:51
Hello
I would like to ask the forum's people about this:
I open the admin interface and then I open the log window. I resize the column according to my screen resolution.
If now I go to a different part of the admin panel, the real-time log window stops and the columns need to be resized.
I think that it would be better if I go to the realtime log window, set the column and press START, but the log remain active till the admin interface is open. So I could go for example to the IP RANGES settings, then back to the log and the log is there running, and with the right sized columns.
Mr. Spadoni
Network Administrator
Spadhausen ISP
admin (at) spadhausen . com
Re: hMail Administrative interface modifications
Post by ^DooM^ » 2009-10-07 12:27
This has been requested before. The reason it stops when you move away is to prevent it from being left on and grinding hMail to a slow crawl. There have been many suggestions but it's not really a priority. My guess it will be updated when Martin gets around to adding all the small things.
pepsi
Post by pepsi » 2009-10-07 13:01
Correct me if i'm wrong but this was the topic for it:
http://www.hmailserver.com/forum/viewto ... =2&t=15762
sckramer2
Post by sckramer2 » 2009-10-07 20:24
i like how it works now... also it is nice how it lets you sneak over to the queue with out stopping
westdam
Post by westdam » 2009-10-09 09:39
maggiore81 i'm using wintail to have the log in real time and i've not to open hmail admin.
maggiore81
Post by maggiore81 » 2009-10-09 09:41
westdam wrote:maggiore81 i'm using wintail to have the log in real time and i've not to open hmail admin.
Thank you, I will check it out!
Mr. Spadoni
Spadhausen ISP
