Routes / Delivery enhancements
Do you need this feature?
Yes
20
91%
No
2
9%
Total votes: 22
Vilo
Post by Vilo » 2008-10-16 10:32
Hi all,
I know that a request for such a feature has already been made, but I can't find any infos about this feature beeing under development or not.
So here it is :
In its current stable version, hMailServer is able to deliver emails :
- directly via MX lookup
XOR
- indirectly via unique SMTP relay (ISP SMTP server)
Each method has drawbacks ...
- Direct delivery may fail for blacklisting issues (private SMTP servers are not allowed by several Cie)
- ISP SMTP relaying is slower than direct delivery, and can lead to big trouble in case of mass mailing.
My request :
Enhance the routes managment to allow (for a given domain) :
1. Direct delivery
2. In case of failure => indirect delivery via SmartHost n°1
3. In case of failure => indirect delivery via SmartHost n°2
etc ...
For each route, user should be able to set :
- Number of tries and timings
- Failure conditions (for example, if direct delivery fails with message "unknow recipient", then it is not necessary to continue direct delivering nor trying indirect delivering).
Thanks ;-)
Re: Routes / Delivery enhancements
Post by ^DooM^ » 2008-10-16 10:35
A nice idea.
Vilo
Post by Vilo » 2008-10-30 09:51
Well, not too many replies ...
Maybe a much simpler solution (that would be easier to implement I guess), would be to add in "SMTP delivery" the possibility to try direct delivery before sending to relay.
It is the solution that is implemented by a very large number of mail servers.
By the way, could it be possible to know if hMailServer is going to have such a feature in a near future ?
Thanks a lot ;-)
plive
Post by plive » 2009-02-25 21:17
Well I would be interested if you had an option to specify the number of thread for a particular route.
Post by martin » 2009-05-29 22:21
In 5.2 you will be able to accomplish this.
There's already a rule action called "Deliver using route" which allows you to specify which route a specific message should be delivered via (if the delivery is external)
In 5.2, there will be a new rule criteria which allows you to check the current number of delivery attempts.
Using these two in combination you should be allow to specify that first delivery should be made direct to recipients server, second deliver via route, third via other route, fourth using direct delivery, and so on.
sckramer2
Post by sckramer2 » 2009-08-06 18:12
very nice martin...
in the smtp route for the isp's relayer, what should these be set to?
When sender matches......
local or external?
When recipient matches.....
local or external?
Post by martin » 2009-08-09 14:41
Have you read the documentation? It tries to explain this.
Caspar
Post by Caspar » 2010-06-22 11:42
I forgot this feature request was there, now that I see it again, I remember that this could be an handy thing.
Post by martin » 2010-06-22 21:53
I'll move this to the archive, since the two rule actions and criterias I mentioned below is now implemented.
By combining the criteria Delivery attempts with the action Send using route, you can accomplish this behavior.
