Just upgraded from B248 to B250. In Admin, under SpamProtection, Greylisting, the two tabs on the left have been 'General' and 'Whitelist'. Now I only see General and second tab, very small without a name (label).
Anyone else getting this??
with best regards,
Chuck
4.3 B250 Whitelist tab blank (& very small)
hMailServer 4.4.1-B273 Built-in MySQL
3 ea prod mx servers on XP Home, 1 ea on Win2k
I get the same. Will fix it for the next beta build. This problem is not only true for the greylisting settings but for a bunch of other strings as well.
For an immediate solution, add the following lines to the end of \Translations\English.ini.
String_463=As soon as possible
String_464=Delivering now...
String_465=Use SQL Server authentication
String_466=Use Windows authentication
String_467=Database name
String_468=Authentication
String_469=White listing
String_470=TCP/IP ports
String_471=Protocol
String_472=Signature
String_473=Plain text signature
String_474=HTML signature
String_475=Use signature if none has been specified in sender's account
String_476=Overwrite account signature
String_477=Append to account signature
String_478=Enable signatures
String_479=Add signatures to replies
String_480=Add signatures to local email
String_481=Enable domain signature
String_482=hMailServer administration password
String_483=Last logon time
String_484=Max number of accounts
String_485=Max number of aliases
String_486=Max number of distribution lists
String_487=The account could not be added since the maximum number of accounts for this domain has been reached.
String_488=The alias could not be added since the maximum number of aliases for this domain has been reached.
String_489=The distribution list could not be added since the maximum number of distribution lists for this domain has been reached.
String_490=Limits
String_491=Max size of accounts (MB)
