Another ASP.net Mail Client
first,English is not my mother tongue,so I try to tell you clear about the system.
It will give you a surprise,it looks nice,and easy to use. It can be able to config,and set up multilangage,and add your Theme.
it's free now and forever. if you have new speciality,fead back to me .
down here: http://mail.pjsz.com/WebMail.rar
Config.xlm file is in the bin floder, Set up Config like this
<ThemeName>Default</ThemeName> you can add more Theme you like.
<LanguageName>简体中文</LanguageName> //you can set as English
<SmtpPort>25</SmtpPort>
<ImapPort>143</ImapPort>
<ImapSSL>false</ImapSSL>
<Domain>pjsz.com</Domain>
<EncryptionKey>Guz(dshj7x89H$yusy0456FtmaT5sfvHUFCy76*h%(HilJ$lhj!y6d(*jkP87jH7</EncryptionKey> // use to Encryption cookie, you can chang it
<DecryptionKey>e4khj*Ghg7!rNIfbo95GUY86GfghUb#er57HBh(u%g6HJ($jhWk7f!hg4ui%$hjk</DecryptionKey>// use to Decryption cookie, you can chang it
some Screenshots below:
login
mailDetail
maillist
writemail
usermanger
Bata4
release note:
fix some bugs.
1. support no title mail view.
2. add user nanger funtion.
more function will coming soon...
login
mailDetail
maillist
writemail
usermanger
Bata4
release note:
fix some bugs.
\Languages
it's easy to add new language.you just translate a copy from english or chinese into your language ,and save as xxxx.txt and put into Languages floder,it is ok! if you want to set it as the default language ,ok, modify the config.xml <LanguageName>简体中文</LanguageName> // to xxxx.
is it easy? any question feed back to me or reply below , try my best to help you up ,hehe
because i catch all exception error , just setup the error information like "Wrong Password" ,maybe i should threw the real error information next release.
make sure Domain config is correct
<Domain>pjsz.com</Domain> chang to your mail Server Domain
if you enter username contain Domain, like huangsj@pjsz.com
then it should be work.
if you chang config.xml <Domain>pjsz.com</Domain> to <Domain>YourDomain.com</Domain> then you can enter your username@YourDomain.com like "username", it will work well. Any question welcome feed back.
<?xml version="1.0" standalone="yes"?>
<dsConfig xmlns="http://tempuri.org/dsConfig.xsd">
<ConfigTable>
<LanguageName>Greek</LanguageName>
<SmtpPort>1225</SmtpPort>
<Domain>mydomain.gr</Domain>
</ConfigTable>
</dsConfig>
When entering username is always at the form username@mydomain.gr
The problem still remains, Wrong Password!
For your information the server is Windows 2000.
hMailServer 4.3.1-B253 with MSSQL2000 - Windows 2000 SP4 - ActivePerl 5.8.8. b819 - ASSP 1.2.6 - RoundCube v0.1-beta2
Sorry , reply back is not in time . i was going on errands last few days. I'm home Now!
The new version is still on developing, so i will add the error log funtion on the new version. when finish developing,i will update . so hold on.
I give you a account to test my mail server.
username: demouser
Password:demouser
address: http://mail.pjsz.com
anyone who want to know it, just look over it.
oh,my OS is win2003,hmailserver 4,mysql.
I will upate download when the new version is finished.
username: demouser
Password:demouser
nikolasd wrote:This is my ConfigData.xml at the bin folder. There is no other config.xml anywhere!Code: Select all
<?xml version="1.0" standalone="yes"?> <dsConfig xmlns="http://tempuri.org/dsConfig.xsd"> <ConfigTable> <ThemeName>Default</ThemeName> <LanguageName>Greek</LanguageName> <SmtpPort>1225</SmtpPort> <ImapPort>143</ImapPort> <ImapSSL>false</ImapSSL> <Domain>mydomain.gr</Domain> <EncryptionKey>Guz(dshj7x89H$yusy0456FtmaT5sfvHUFCy76*h%(HilJ$lhj!y6d(*jkP87jH7</EncryptionKey> <DecryptionKey>e4khj*Ghg7!rNIfbo95GUY86GfghUb#er57HBh(u%g6HJ($jhWk7f!hg4ui%$hjk</DecryptionKey> </ConfigTable> </dsConfig>
Thanks for the demo account. I had the opportunity to test your webmail system, which is great.
I think the problem i get has to do with IMAP folders. Is it checking your system for the existance of the IMAP folders and how it is done this.
Because whenever i disable IMAP on server, i get NO error from your system.
I just thought that this information could help you.
I am waiting for your next release.
oh,yes maybe problem is right that, when the user login,the system will check the imap folders, if do not exist :INBOX,Drafts,Sent,Trash anyone of them,the system will auto create the folders,so maybe your account has no permission to create the floder. another side, you use outlook or other winclient to test the imap port is working ok. I'm not sure your imap port config is ok. in my hMailServer ,i just use the default config. and it work will.
I will publish the new version as soon as i can.
That's what made me consider that my problem has to do with the IMAP folders. I have tried both Thunderbird and Outlook, but had no luck. I get an error message but had no time checking it. I will wait for your new version and check if my permissions are set correctly for the IMAP folders and I'll get back to you.
I have changed completely the user permissions on my server, so that might be the problem.
Hi pjack,
Are you planning to continue developing your webmail solution or have you stopped?
I have translated to greek if you are interested
My problem with the IMAP folders is resolved. I had to enable IMAP on my IP Ranges!
the project will be continue
the taiwang earthquake break up FDDI internet,so i can't access there for a while . don't warry the project will be continue. but that have something realy puzzle me. i hope to make out the webmailclient and then webmange at the same time.but someone is do some work that, and sometimes to work with c++ api is not easy. i contact with http://www.lumisoft.ee/ the guy develop MailServer in C#,and it is open souce . need i make it supper it?...to make it as a universal for mailserver?need i to develop a new mailserver webmanger for hmailserver? could somebody tell me the answer? i will make a decide . oh,,your translate ,i need it. send to me , i will incloud it in next relase.
oh,my mail:huangsj@pjsz.com,or contact me with msn :jackking178@hotmail.com
Oh! My...! Are you living in Taiwan?!
Just to know there is already a running ASP.NET 2.0 web based administration project for hMailServer (hASPmin) here. I would reccomend not to get involved in creating another one web based administration for hMailServer. You could on the other hand just cooperate with the guy that started the first one (Florian).
As for the MailServer in C#, I cannot help you, since i already use hMailServer and I think is in a more working state than MailServer. But if I had to reccomend something I would reccomend to make webmail universal for both mail servers.
I will post you the translation file ASAP.
I'm living in shenzhen china, maybe take two week,i will bring up a new version. since Microsoft ASP.NET 2.0 AJAX Extensions has released ,so i want to replace magicajax to this one. and it will come up with a embeddatabase to save user information like address,rss...and ui may change to more easyer to use. i work hard at it.
Oh thats nice, but I heard not the best comments for the MS AJAX, but I haven't tried it yet. After all MagicAJAX is a greek project, that's why I strongly support it
As for the embedded DB, what are you thinking of using? I would reccomend either XML or just good old known MSSQL2000
But you are the project master, you decide what is best!
(My little Chinese knowledge : ni hao ma )
That would be nice! Have you concluded on the AJAX library you will use?
Also, here is the Greek Translation file .
Other chinese i know: xi nian kuai le! I think it is in a few days?
Trying to translate: wo hai hao = "I am very good" or "I am fine". I am not sure for "ni ne?"pjack wrote:another chinese : wo hai hao. ni ne? do you what it's mean?hehe
To nikolasd :
Thank you for Translation !
and you know chinese well. "ni ne?" = " How about you?" . Just like say hi to you. MagciAjax still have bugs and update very slowly, other way " http://ajax.asp.net/ajaxtoolkit/ " will realse a lot of very useful controls . if you ware me ,you will do the same choice. this time change a lot , i work hard don't want to delay. thank for "xi nian kuai le" and Chinese New Year is coming soon , so say "xi nian kuai le" to me is early. i'm very curious where you learn chinese from?
To Slug:
i'm great to make a new friend here. maybe we can meet some day,hehe .
To Slug:
I was practicing wu shu (ying zhao, chan quan, sao lin quan, nan quan and some hung gar) for 4 years and my shi fu is a beijing university master holder in Chinese Gymnastics. He was living in beijing for 2 years and goes to China every year to meet his wushu branch father and brothers. He has become a brother for the whole family of his wushu teacher and has gotten a chinese name as well (something called Bai Shi ceremony).pjack wrote:i'm very curious where you learn chinese from?
While practicing wushu i was able to take some chinese lessons by a chinese greek teacher (A Chinese who studied Greek Culture and Literature and Ancient Greek in China and got her master in Greece) Her father is a well know respected academic in China (something like a Dean in the Beijing university).
I also helped to create the web site for the specific style that my shi fu represents and since one language is in Chinese, I had to learn to write in pin yin! (checkout the website at http://www.eagleclaw.gr/)
I adore the Chinese culture since I found out about Marco Polo (a long time ago in my early youth). I wish I could learn to speak Chinese fluently, but had no time since then. I also owe my self a long trip to China (Shangai, Hong Kong as well), but is very difficult from Greece (have to change 3 planes!!!)
this vision need MS ajaxt lib so you can down here.
http://www.microsoft.com/downloads/deta ... laylang=en
Now getting an Error
I installed the web client a week ago, and was testing it out. It looked very good with the one issue I mentioned before, that I would like an English Language default.
But now, after I login, and click on the Inbox link, I get the menu buttons for the inbox, but then get the Error :
Object Reference not set to an instance of an Object
Any Suggestions?
David
Any Suggestions?
David
"Object Reference not set to an instance of an Object " , i have find it. it is the bug in the LumiSoft.Net.dll, it can't parse some mail like nomailbody...,i work at it ,hope can fix it up.
my Suggestions is use a winmail client to download the mail. and it will work again. i hope to fix it up in the next version.
Now it is running OK...
After failing to be able to check mail with this email client with the object not set error that I mentioned earlier, the problem has gone away and I can again use it....
I made no changes other than the config change suggested to make the default language English which worked fine. (My apologies for actually missing that instruction on the first page of your posting)
But now it allows me to check the acount that was failing before...
I am getting used to it, and like it better all of the time.
David
David
Tested mail.pjsz.com today.
1. Could you check it in alternative browsers. For example, you are using xhtml and standard compliance rendering mode. Firefox rendering differs from IE.
2. Unsanitized javascript in message subject and html body. Insecure remote images.
3. English translation uses "Send" button, when in fact button does "Compose".
4. Can't view email if subject is empty
To dzekas :
thank you for your test! fot the problems that you listed, i can deal with it like this:
1. yes i do not test it on Firefox, but i test just now. it is a hard problem to fix it out, becuse the problem come from MS ajax lib or AJAX Control Toolkit . it do not support Firefox well. i will try to fix in the 1.5 version.
2. i find it before. it will collide with the ajax, when message subject or html body include "<" or ">". i have report it the AJAX Control Toolkit project group. hope i can fix it in the future.
3、4 it will be fix ! how about accept -->"Get Mail" and send-->"Write Mail".
thanks again.
thanks again.
I like the look of this app but I can not get it to talk to hamil. I have tried various options for the <domain></domain> setting but when I view IMAP loggs I can not see it even try to connect. I so want a non PHP webmail to run in IIS that looks descent and is skinable. This looks like it if I can get it to login.
Any one offer any suggestions?
Any updates on this mail client??
I am looking forward to seeing what Pjack has been doing on this app??
Any word yet on updates?
David
David
- Hosters.at
- New user
- Contact:
username: demouser
Password:demouser
was given in one of theearlier posts...
Did you try it?
David
Password:demouser
Did you try it?
David
i will left shenzhen about one week for work, new version you can download from top topic.
if some one find new bugs or want new function ,please post here,i will fix or add it at soon as i can.
because MS Ajax do not realse the new version in time, so i hide some function in this version .
every version i release shall be steady, so every version come up slowly,for more time to text it by myself.
jack
jack
hi pjack, i download http://mail.pjsz.com/WebMail.rar and find that not all files are included in this package.
