hMailServer 4.3, build 227
Since being on B229, haven't had the problem with SMTP lockups. I believe Martin's already fixed the problem, but if you stll have the logs, could you please forward that error log to me?GlenC wrote:oops... you are correct, there were error logs too. If you still need them let me know and I will send those also.
It was happening so often and caused me so much grief and energy, I would love to see why.
Thanks,
Chuck
hMailServer 4.4.1-B273 Built-in MySQL
3 ea prod mx servers on XP Home, 1 ea on Win2k
Well, I hadn´t looked at them too closely before, but it´s strange because there really isn´t anything at the time that my SMTP started failing (Which was around 22:30) Here they are anyway:
"ERROR" 3444 "2006-08-12 09:42:29.310" "Source: Socket::Disconnect(), Code: HM4363, Description: shutdown() failed. Session ID: 1, Socket ID: 1204, Winsock error: 10057."
"ERROR" 3444 "2006-08-12 09:42:29.310" "Source: Socket::Disconnect(), Code: HM4363, Description: shutdown() failed. Session ID: 2, Socket ID: 1280, Winsock error: 10057."
"ERROR" 3040 "2006-08-12 10:22:17.464" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 3040 "2006-08-12 10:22:17.564" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 3040 "2006-08-12 10:22:17.764" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 3040 "2006-08-12 10:22:17.774" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 1940 "2006-08-12 21:36:04.186" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 636 "2006-08-13 11:29:42.200" "Source: IOCPServer::_CreateListenSocket, Code: HM4316, Description: Call to bind() failed. Error: 10048. Is another server is already using this port (25)?"
"ERROR" 636 "2006-08-13 11:29:42.210" "Source: IOCPServer::DoWork(), Code: HM4323, Description: _CreateListeningSockets() failed. Error: 183"
"ERROR" 5140 "2006-08-13 12:24:08.447" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 5140 "2006-08-13 12:24:30.479" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
"ERROR" 5140 "2006-08-13 12:25:06.931" "Source: IOCPOperationParser::ParseOperation, Code: HM4367, A client has failed to connect."
