OpenSSL Security Advisory [25 March 2021]
Meister
Post by Meister » 2021-03-25 17:45
https://www.openssl.org/news/secadv/20210325.txt
What do you think? Should somebody build a new beta version? And may it be a non-beta? For users, who do not want tu use beta software?
Re: OpenSSL Security Advisory [25 March 2021]
Post by mattg » 2021-03-26 00:28
Certificate validation is hardly used in hMailserver, even when the 'validate certificates' switch is selected
It is only used for outgoing mail cover by SMTP routes, and POP3 external download
It is not used for ANY normal outgoing mail, or for any incoming SMTP connections
Additionally, that security advisory says in part
In order to be affected, an application must explicitly set the X509_V_FLAG_X509_STRICT verification flag and either not set a purpose for the certificate verification or, in the case of TLS client or server applications, override the default purpose.
hMailserver would need to override deliberately the OpenSSL defaults
I'm not sure that this is a big issue for us
Post by RvdH » 2021-03-26 10:17
@Meister
Next time you better open a github issue for security/vulnerability related questions
https://github.com/hmailserver/hmailserver/issues/352
Meister
Post by Meister » 2021-03-30 11:47
Oh, ok, sorry.
Post by RvdH » 2021-03-30 12:38
Meister wrote:
2021-03-30 11:47
Oh, ok, sorry.
Not a big issue....but martin (author) isn't a frequent visitor of the forums and when doing it thru github he gets a notification of github issue automatically
5.6.8 - Build 2538 (BETA) is updated with OpenSSL 1.1.1k
andreasRu
Post by andreasRu » 2021-03-30 13:28
@RvdH
We are currently migrating to hmailserver and I've absolutely no experience in hmailservers build/release policy, so please excuse me in case this question is unfortunate. I'm posting my question here and to you, because primarily my issue is also related to the "OpenSSL Security Advisory" , and secondly you seem to be very experienced with hmailserver and this forum.
There have been plenty of new beta builds since latest stable version for production 5.6.7 - Build 2425 2017-12-14, being the latest beta the build that fixes the above mentioned security issue with the OpenSSL 1.1.1k upgrade (dated 2021-03-28). It's great to see that the author Martin gets very quickly active by updating the core, merging the build and deploying the builds as beta to the download archive.
Now my question: I know these latest builds are offically beta and NOT released for stable production. But what is your experience? What would you and other experienced htmailserver admins usually do in such cases envolving OpenSSL security fixes? Do they tend to install these latest beta over stable because of OpenSSL security implications? Are these beta builds too risky to use for production? Or would you tend to say: "no prob, I'd use it in production, watchout the debug logs carefully and downgrade if necessary"?
Thanks for any insights,
Post by RvdH » 2021-03-30 14:02
I have no idea why 5.6.7 - Build 2425 2017-12-14 is still listed as the actual version, this version differs from the latest 5.6.8 release as in this build SSL 3.0 is removed completely and TLS 1.2 is added
Many (most) of us use 5.6.8 without issues
andreasRu
Post by andreasRu » 2021-03-30 14:39
That was what I thought and that is what hmailserver commit history at github reflects. Going to upgrade to latest 5.6.8. build. Thank you!!! Really appreciate you taking your time for your help.
Meister
Post by Meister » 2021-03-30 14:58
I have been using the latest beta from years without any issue.
Bob.Dig
Post by Bob.Dig » 2021-04-06 16:58
So it is fixed for the "beta" but still not for 5.7 "development"?
Because of this I downgraded to 5.6.8 but it is only 32 bits and stuff..
Post by SorenR » 2021-04-06 17:51
Bob.Dig wrote:
2021-04-06 16:58
If you want a 5.6.8 release with the same features as 5.7 (only 32-bit) you need to use RvdH's version of 5.6.8-B2538.
viewtopic.php?p=228140#p228140
Bob.Dig
Post by Bob.Dig » 2021-04-06 19:45
2021-04-06 17:51
Actually I would have preferred to have 5.7 with the OpenSSL fix.
So we are back at "TeamCity" I guess. Is there a version of 5.7 with the fix?
Bob.Dig
Post by Bob.Dig » 2021-04-06 20:35
Now I noticed that the old version was probably not running correctly with my export, although the built-in test had all green lights.
So I installed the newest from "TeamCity", hoping it has the fix and imported my export again, loosing one day.
Post by SorenR » 2021-04-06 22:17
Bob.Dig wrote:
2021-04-06 20:35
The B2555 is no different from B2538 execpt some changes in the systems test procedures that you don't get to see anyways so you could have stayed with the B2538 from the download page.
What I am referring to are all the enhancements to 5.7 like event "OnHELO" and some 22 other fixes that was moved from RvdH's version 5.6.8 to the official 5.7.
Bob.Dig
Post by Bob.Dig » 2021-04-06 22:24
2021-04-06 22:17
I was at 5.7 all the time, but it looks like there is no OpenSSL Fix for that. Because of that I downgraded to B2538, which is 5.6.8, to later find out that it was not compatible with my export and so on.
Post by SorenR » 2021-04-06 22:58
Bob.Dig wrote:
2021-04-06 22:24
2021-04-06 22:17
These are the (MySQL) database changes from 5601 to 5700.
insert into hm_settings (settingname, settingstring, settinginteger) values ('ImapMasterUser', '', 0);
insert into hm_settings (settingname, settingstring, settinginteger) values ('ImapAuthAllowPlainText', '', 0);
insert into hm_settings (settingname, settingstring, settinginteger) values ('EnableImapSASLPlain', '', 0);
insert into hm_settings (settingname, settingstring, settinginteger) values ('EnableImapSASLInitialResponse', '', 0);
update hm_dbversion set value = 5700;
I would claim that the only showstopper is this:
The other changes do not affect 5.6.8 in any way.
On a 5.6.8 system this is true:
update hm_dbversion set value = 5601;
I don't have a spare 64-bit system to try a downgrade from 5.7 to 5.6.8 so I can't verify it can be done or not.
Post by jimimaseye » 2021-04-06 23:25
I remember installing 5.6.x over the top of experimental 5.7 (which we have already identified as creating the SASL related tables) and it was without problem.
Post by mattg » 2021-04-07 00:39
Bob.Dig wrote:
2021-04-06 20:35
Yes, there is a new teamCity version for 5.7, build number #2556
My database version is 5700
(You can view this in the hmailserver admin GUI, under status)
Bob.Dig
Post by Bob.Dig » 2021-04-07 09:12
2021-04-07 00:39
But does it have this fix? I can't see this by just reading the "changes" there.
@jimimaseye I really have no intend to run an older version then 5.7, but I did because I couldn't find the OpenSSL Fix for it. Anyhow, I backed up my complete config from 5.7, uninstalled it, installed 5.6.8, restored backup.
First looked fine, but later I noticed in my pfSense, that email from this forum couldn't reach me, because sending IP got blocked cause of being listed in dnsbl-3.uceprotect.net. What then normally happens, it would be sent to my backup mx, which is the instance I had downgraded, which has no pfsense in front and that would send me the mail with some time gap, because of grey-listing. But it didn't. This instance only has routes configured, no "Domains". So that is when I noticed, it is not running correctly.
But again, I don't want to run it, I want 5.7 with the latest OpenSSl Fix.
Post by SorenR » 2021-04-07 09:50
Bob.Dig wrote:
2021-04-07 09:12
2021-04-07 00:39
If by "the fix" you mean OpenSSL 1.1.1k then all you need to do is go to .\hMailServer\bin and right-click on "libssl-1_1.dll", select "properties" and then "details" ... It will tell you product version and build date.
Bob.Dig
Post by Bob.Dig » 2021-04-07 10:02
2021-04-07 09:50
Thank you Soren, now I can sleep well! :wink:
Post by RvdH » 2021-04-07 10:19
Bob.Dig wrote:
2021-04-07 09:12
Just don't come whining here if something does not work as expected, 5.7 is ALPHA and not offically ready to be used in production environments
Bob.Dig
Post by Bob.Dig » 2021-04-07 11:20
2021-04-07 10:19
I run it all the time without problems, but I will whine here, if I find a bug/problem. And if no one comes back at me, I now know why.
Thanks guys!
Post by katip » 2021-04-10 20:07
after a few VM snapshots and returns...
how to fall back from x64 build to 32 bit recent beta (with MySQL/MariaDB):
run HMS backup in full (incl. messages)
uninstall HMS
copy 32 bit libmysql.dll to \bin
install HMS recent beta
run hMailserver Database Setup and create a new database
restore HMS backup in full
restart service
it seems this is the only path to follow.
backup/restore HMS config only and run DDS or restore from an SQL dump doesn't work.
to get back config and messages, HMS backup/restore must be in full incl. messages.
may be unpleasant for larger setups but appearantly there is no other way.
HMS 5.7.0, MariaDB 10.4.10, SA 3.4.2, ClamAV 0.103.2
Post by SorenR » 2021-04-10 20:48
katip wrote:
2021-04-10 20:07
uninstall HMS
restart service
What if you change hm_dbversion to 5601 and install 5.6.8 over the existing? With a 32-bit database driver...
Post by katip » 2021-04-10 22:52
2021-04-10 20:48
uninstall
change libmysql.dll in \bin
clean 32bit install
it worked! :idea:
Post by SorenR » 2021-04-10 23:44
katip wrote:
2021-04-10 22:52
2021-04-10 20:48
uninstall
clean 32bit install
it worked! :idea:
I guess it only works if hmailserver.ini is not deleted.
Post by katip » 2021-04-11 01:17
2021-04-10 23:44
katip wrote:
2021-04-10 22:52
2021-04-10 20:48
uninstall
clean 32bit install
it worked! :idea:
Yes of course, forgot to mention. Uninstall keeps it anyway.
Thanks for the tip about 5601 btw..
Post by SorenR » 2021-04-11 01:36
katip wrote:
2021-04-11 01:17
2021-04-10 23:44
katip wrote:
2021-04-10 22:52
uninstall
clean 32bit install
it worked! :idea:
I have 3 ground rulez in life ... 1: Shortcut ... 2: Hack it ... 3: Hard work ... which ever is using the least calories :mrgreen:
Post by mattg » 2021-04-11 06:31
Bob.Dig wrote:
2021-04-07 09:12
2021-04-07 00:39
But does it have this fix? I can't see this by just reading the "changes" there....
Assuming that you want the latest version of OpenSSL
looking at the full build log on Teamcity, I can see that 5.7 is built on openSSL v1.1.1k, which matches the advisory notice
https://build.hmailserver.com/downloadB ... ildId=1234
Bob.Dig
Post by Bob.Dig » 2021-04-11 09:59
2021-04-11 06:31
Interesting, another way to find out what is used, thank you.
2021-04-07 10:19
Got you wrong first time. I will not come whining but just file a bug report.
Thank you for enriching this nice software.
