hMailServer 5.6.7 x64 B2425 Jan 2019 LTS Release
Post by Dravion » 2019-01-31 03:48
This is the vanilla 2425 built which is allmost identical to the official 32-Bit version of hMailServer 2425
Updates:
*OpenSSL 1.0.2q
*License and some hMailAdmin Windows showing the LTS Text Hint
*This is a x64 Bit Release only, there will be no 32-Bit Release avaiable
*LTS Releases will not get new features, only small fixes and Header/Lib Updates if possible
Download:
https://github.com/Dravion/hMailServer/releases
Checked against Virustotal:
See:
SHA-256 f57800cf0f1a7541f1af2bbc5bdc4403c51f4de68a94329c3e94ad6b1b0247db
Scanresults:
https://www.virustotal.com/#/file/f5780 ... db/details
Re: hMailServer 5.6.7 x64 B2425 Jan 2019 LTS Release
Post by Dravion » 2019-01-31 13:41
Added Releases:
+2426 -
*Addded PostgreSQL 10 and 11 compatibility and TLSv1.2 Support (libpg.dll and helpeder DLL's now included)
*Addded MySQL 8.x and Legacy compatibility and TLSv1.2 Support (libmysql.dll now included)
+2427
* Changed Connectionstring for MS-SQL 2008 SP4 upto SQL-Server 2017 (Windows and Linux) with TLSv1.2 Connectivity.
(Requires speperate OLDEDB Version 18 x64 Pre-Installation)
Alle new releases will include the fixes of the previes releases.
mic.max
Post by mic.max » 2019-02-08 13:44
I tried this version to replace the x86 version that works regularly, but I detect the same problems mentioned in the post viewtopic.php?f=7&t=33376
