How to get HmailServer API for C#
tester
Post by tester » 2018-10-16 08:26
Am New to hmailserver . i didn't download and install the Hmailserver Software in my PC because of my storage issue. So what my question is how to use/get/work with Hmailserver API for my c# application without install that. is there any option available?
Re: How to get HmailServer API for C#
Post by mattg » 2018-10-16 09:08
no, not really
But why would you want to?
The API will only work with a local hMailserver
tester
Post by tester » 2018-10-16 12:33
2018-10-16 09:08
no, not really
Ok sir. Now i managed my storage and installed Hmailserver. how to connect hmailserver with my c# application? I have added interop.hmailserver , AutoresponderPlugin ,HmailServerDomainPlugin and ChangePasswordPlugin references into my project.
My basic c# code which helps authenticate the hMailServer user and returns an instance of the application
hMailServer.ApplicationClass application = new hMailServer.ApplicationClass();
hMailServer.Application hMailApp = Authenticate(userName, password);
hMailServer.Domain domain = hMailApp.Domains.Add();
domain.Name = domainName;
domain.Save();
what is my username and Password here?
tunis
Post by tunis » 2018-10-16 16:32
tester wrote:
2018-10-16 12:33
Your admin username and password you login to hMailserver with.
HMS 5.6.8 B2494.24 on Windows Server 2019 Core VM.
Post by Dravion » 2018-11-22 09:32
This should help to get you starting with c# and hMail
1) Download and unzip the Archive
2) Open and run it in Visual Studio
viewtopic.php?f=21&t=31507
