New, Private Testbuilds x64/32-Bit avaiable
Postby Dravion » 2017-07-21 12:27
Version 5.6.7 - from the active Dev Branch released on Github
64-Bit Version (with correct builtin MSSQLCE 64-Bit support as well)
https://github.com/Dravion/hmailserver/ ... A.-x64.exe
*OpenSSL 1.0.2l (latest version as of 7/21/2017)
*Full optimized binaries with all Codegeneration switches for AMD64 CPU enabled
*Boost Framework version 1.63 - 64-Bit
*Innosetup Installer is: 32-Bit, but installs 64-Bit binaries
*Codesigned (all my installers are digitally signed)
32-Bit Version (with correct builtin MSSQLCE 32-Bit support as well)
https://github.com/Dravion/hmailserver/ ... A.-x86.exe
*Boost Framework version 1.63 32-Bit
*Full optimized binaries with Enhanced SSE2 Instructionset activated, full Code optimization switches
*NASM Assembler highly optimized OpenSSL version for performance
Systemrequirements:
Blank install of Windows 7 Core/Home 32 or 64-Bit + SP1
*Tested: MSSQLCE for 32 and 64-Bit.
*Plans: Integrating OpenSSL 1.1.x new Mainline integration.
Markings:
You can allways indentify my builds if you goto hMailServerAdmin and click in the Help menue "About"
Happy testing.
My experimental builds of hMailserver 32/64-Bit+Unicode
https://github.com/Dravion/hmailserver/releases
HMSInfo 32/64-Bit
https://github.com/Dravion/HMSInfo/releases
Return to “Development & alpha discussions”
Who is online
