HMailserver HIDDEN settings
Post by jimimaseye » 2017-02-03 01:44
Published: 2nd February 2017
Over the years and starting at version 5.4, with the aid of public input, some hidden functionality was added to Hmailserver that is not official, documented or available from within the GUI. The main contributor to these changes, 'Bill', made a list of his changes (found here) and some of those changes have been retained (undocumented) up to current production build (5.6.6 - Build 2383). This functionality is enabled or set by the means of adding entries to the Hmailserver.ini file under a subsection "[Settings]" (add to the bottom of the INI file if not already present).
WARNING: These functions are not official in current build (5.6.6) and so no guarantee is being offered and you use these functions at your own risk. (However, many have been used and tested with feedback given to Bill in the original thread at the time. This could lead to assume that if the functionality remains then it has been cleared as ok by those users when used in the correct circumstances).
Some of the functions/modifications undertook by inclusion of the settings is obvious from the narratives given below, others are not. DO NOT APPLY ANY SETTINGS without guidance from experienced users on this forum (especially in the case of absent explanation narrative). You will receive little sympathy if you destroy your production email server by implementing these settings without testing its effectiveness.
NOTE: Although currently they have still been retained since being introduced at 5.4, any of these hidden settings may be removed/deactivated at any time by the author in any official release of Hmailserver. There are no guarantees that these settings are still active from any production release forwards on from current build (at time of writing) 5.6.6 - Build 2383. Those that are interested and able can self-check for their inclusion in later releases by reviewing the source code.
The list below is a replication of the list containing all remaining settings.
hMailServer/bin/hMailServer.INI
[Settings]
SepSvcLogs=1
; This key tells hmailserver to split SMTP/IMAP/POP into their own log files such as
; hmailserver_SMTP_2010-10-24.log, hmailserver_IMAP_2010-10-24.log, hmailserver_POP3_2010-10-24.log
LogLevel=9
;1=lowest/least 9=highest/most
;NOTE: Not really functional at this point except a few specific places
;Default=9 if not defined.
MaxLogLineLen=300
; This key causes log lines to be neatly truncated at specified # of characters to reduce log sizes.
; Example: "POP3D" 3952 2 "2010-10-24 15:18:59.924" "127.0.0.1" "SENT: 1 756[nl]2 ... 350[nl]1973 371[nl]."
; This defaults to disabled if key doesn't exist or LogLevel > 2 or if debug logging is enabled
QuickRetries=5
QuickRetriesMinutes=7
; Defines # of minutes to delay for each retry if QuickRetries is enabled otherwise normal delivery schedule
; is used
; Defaults to 6 if QuickRetries is enabled otherwise ignored
QueueRandomnessMinutes=3
; This key defines how many minutes to use for 'QuickRetries' that over-rides the default retry schedule.
; This does not apply to NEW messages as they are still queued for immediate delivery as before.
; This defaults to 0 or disabled
MXTriesFactor=2
; This key defines a multiplier to determine how many MX/A server results to try per retry.
; For example: If set to 2 & the recipient has 11 servers, on 1st try, 1 x MXTriesFactor or 2 are tried.
; On 2nd try, 2 x MXTriesFactor or 4 are tried. On 3rd 6 are tried & so on. Eventually all 11
; would be tried if the message was not successively delivered enough times.
; This defaults to disabled if not defined
ArchiveDir=C:\MailArchive
; Folder where copies of every email get stored. Default or undefined disables archiving. A copy of all inbound and sent emails appear in a single folder under each domain named subfolder within nominated the archive folder. (Like MIRRORING without the need of SMTP delivery to an email address). eg, inbound: "{F4917B04-F8AB-4FE2-8B11-603659BF48B5}.eml" and outbound file: "Sent-{F4917B04-F8AB-4FE2-8B11-603659BF48B5}.eml".
ArchiveHardLinks=1
; Enables use of NTFS Hardlinks. (NOT FAT/FAT32!) Default or 0 disables & forces normal Copy
POP3DMinTimeout=30
; 10 seconds is default which becomes 15 internally
POP3DMaxTimeout=90
; 600 seconds is default
SMTPDMinTimeout=90
SMTPDMaxTimeout=300
; 1800 seconds is default
POP3CMinTimeout=30
; 30 seconds is default
POP3CMaxTimeout=90
; 900 seconds is default
SMTPCMinTimeout=90
SMTPCMaxTimeout=300
SAMinTimeout=45
SAMaxTimeout=90
; 90 seconds is default
ClamMinTimeout=45
; 15 seconds is default
ClamMaxTimeout=90
SAMoveVsCopy=1
; Tells hmail to use move vs copy+delete. Defaults to 0 which means use "copy"
AuthUserReplacementIP=127.0.0.1
; Tells hmail to replace AUTH'd sender's IP with this value (to help when sender IP is on public blacklist).
; X-header is added instead.
; Default is blank or use sender's real IP
AddXAuthUserIP=1
; Default is 1 or enabled. If set to 0 X-AuthUserIP header with user's IP will not be added.
IndexerFullMinutes=720
; How often a FULL meta data index is done/forced if enabled in Performance Message Indexing
; Defaults to 720 if not defined
IndexerFullLimit=25000
; Maximum # of records returned to have meta data indexed if enabled in Performance Message Indexing
; Defaults to 25000 if not defined
IndexerQuickLimit=1000
; Maximum # of records returned to have meta data QUICK indexed if enabled in Performance Message Indexing
; Defaults to 1000 if not defined
LoadHeaderReadSize=4000
; Amount in bytes of file to be read in at a time when loading headers from messages
; Defaults to 4000 if not defined
LoadBodyReadSize=4000
; Amount in bytes of file to be read in at a time when loading messages
BlockedIPHoldSeconds=10
; Number of seconds to wait before dropping the connection of an IP range banned IP
; Default is 0 or disabled if not defined
BackupMessagesDBOnly=0
; Defaults to 0 or disabled. When set to 1 backups & restores with 'messages' selected will backup ONLY database info for
; messages & NOT the actual Data folder.
; WARNING!! Until finished this is truly experimental feature. Understand even set to 1 doing a restore WILL ERASE DATA TREE! To get around
; that rename Data folder BEFORE restoring then rename it back when restore is complete. YOU'VE BEEN WARNED!!! (This will be fixed eventually)
; It is HIGHLY recommended you have another complete backup before restoring just in case..
DisableAUTHList=25,587
; Comma delimited list of SMTP ports to disable AUTH EHLO response banner & command
; Default if not defined is SMTP AUTH enabled on all SMTP ports
; NOTE: Disables AUTH Plain as well.
; Particularly effective on blocking all attempted authentication attempts on the stated ports.
; Recommend applying it to port 25 and setting all clients to connect and authenticate on port 587.
; This will rewrite the FROM envelope of an email message when forwarding it on to another address.
; The default is to retain the original FROM address (potentially causing SPF checking failures by the forward address server).
Kelden
Re: HMailserver HIDDEN settings
Post by Kelden » 2017-02-05 22:58
DisableAUTHList is great. I already wanted to write a script to disable auth logins on port 25.
Post by mattg » 2017-02-06 00:01
I think that DisableAuthList has come from Martin - but either way it is great
These are what I have as being from Martin - The top few aren't on the list above
;INI settings from Martin
DNSBLChecksAfterMailFrom=1
; DNSBLChecksAfterMailFrom now works. It was removed during the re-design of the spam protection but have been added again.
GreylistingEnabledDuringRecordExpiration=true
GreylistingRecordExpirationInterval=240
; Anti spam: Using two new ini file settings
; it's now possible to configure how often expired greylisting records should be cleared from the database
; and whether or not greylisting should be active during this period.
; The new settings are named GreylistingEnabledDuringRecordExpiration and GreylistingRecordExpirationInterval.
; When performing forwarding, hMailServer now keeps the original From address rather than changing to that of the forwarding account.
; This change was made to reduce risk of message delivery failures.
; To force the previous behavior, set RewriteEnvelopeFromWhenForwarding=1
DisableAUTHList=25
