Possible Bug in use of Pause/Resume button?
estradis
Post by estradis » 2017-01-11 11:10
Hi there,
we often received this error messages which I had reported last year for the first time.
"Could not notify SMTP deliverer about new message, since SMTP deliverer does not exist. The operation requires the SMTP server to be on."
To find the reason, I started heavy testing on our testlab server and finally I found the reason.
When pressing Pause button while an active transmission is in progress, it seems that the delivery thread in use is killed or crashing and won't be re-created when resuming operation. When repeating pause/resume with active smtp connections more times than workers are configured, hMailserver will throw the error message above. To restart workers, I always had to restart hMailserver service.
This behavior was repeatable on every test on both servers (testlab and production).
I added an anonymized debug log dump from the last test at the end of this report.
This is only a report - I don't need support.
Regards
"DEBUG"	3608	"2017-01-11 09:46:31.249"	"Creating session 38302"
"DEBUG"	3608	"2017-01-11 09:46:31.249"	"Executing event OnClientConnect"
"DEBUG"	3608	"2017-01-11 09:46:31.249"	"Event completed"
"DEBUG"	3608	"2017-01-11 09:46:31.249"	"TCP connection started for session 38296"
"SMTPD"	3608	38296	"2017-01-11 09:46:31.249"	"www.xxx.yyy.zzz"	"SENT: 220 hmailserver.example.com ESMTP"
"SMTPD"	3576	38296	"2017-01-11 09:46:31.264"	"www.xxx.yyy.zzz"	"RECEIVED: EHLO mailout1.augsburg.de"
"SMTPD"	3576	38296	"2017-01-11 09:46:31.264"	"www.xxx.yyy.zzz"	"SENT: 250-hmailserver.example.com[nl]250-SIZE 102400000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	3608	38296	"2017-01-11 09:46:31.296"	"www.xxx.yyy.zzz"	"RECEIVED: MAIL FROM:<some.spammer@some.where> SIZE=5865"
"DEBUG"	3608	"2017-01-11 09:46:31.436"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	3608	"2017-01-11 09:46:31.452"	"Spam test: SpamTestHeloHost, Score: 0"
"DEBUG"	3608	"2017-01-11 09:46:31.483"	"Spam test: SpamTestMXRecords, Score: 0"
"DEBUG"	3608	"2017-01-11 09:46:31.514"	"Spam test: SpamTestSPF, Score: 0"
"DEBUG"	3608	"2017-01-11 09:46:31.514"	"Total spam score: 0"
"SMTPD"	3608	38296	"2017-01-11 09:46:31.530"	"www.xxx.yyy.zzz"	"SENT: 250 OK"
"SMTPD"	3612	38296	"2017-01-11 09:46:31.545"	"www.xxx.yyy.zzz"	"RECEIVED: RCPT TO:<rcpt@example.com>"
"SMTPD"	3612	38296	"2017-01-11 09:46:31.561"	"www.xxx.yyy.zzz"	"SENT: 250 OK"
"SMTPD"	3608	38296	"2017-01-11 09:46:31.576"	"www.xxx.yyy.zzz"	"RECEIVED: DATA"
"DEBUG"	3608	"2017-01-11 09:46:31.576"	"Executing event OnSMTPData"
"DEBUG"	3608	"2017-01-11 09:46:32.606"	"Event completed"
"SMTPD"	3608	38296	"2017-01-11 09:46:32.606"	"www.xxx.yyy.zzz"	"SENT: 354 OK, send."
"DEBUG"	3612	"2017-01-11 09:46:32.809"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	3404	"2017-01-11 09:46:32.809"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	3404	"2017-01-11 09:46:32.809"	"Spam test: SpamTestDKIM, Score: 0"
"DEBUG"	3404	"2017-01-11 09:46:32.824"	"Creating session 38303"
"DEBUG"	3612	"2017-01-11 09:46:32.824"	"TCP connection started for session 38303"
"DEBUG"	3612	"2017-01-11 09:46:32.824"	"Sending message to SpamAssassin. Session 38303, File: C:\Program Files\hMailServer\Data\{5464AA49-2E97-4ECC-8260-834B245C8E70}.eml"
"APPLICATION"	5376	"2017-01-11 09:46:32.871"	"Stopping servers..."
"DEBUG"	5376	"2017-01-11 09:46:32.871"	"Application::StopServers() - Removing server work queue"
"DEBUG"	5376	"2017-01-11 09:46:32.871"	"WorkQueueManager::RemoveQueue - Server queue"
"DEBUG"	5376	"2017-01-11 09:46:32.871"	"Stopping working queue Server queue."
"DEBUG"	5376	"2017-01-11 09:46:32.871"	"Interupt and join threads in working queue Server queue"
"DEBUG"	3440	"2017-01-11 09:46:32.902"	"Worker exited in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:32.918"	"Still 3 remaining threads in queue Server queue. First task: SMTPDeliveryManager"
"DEBUG"	3444	"2017-01-11 09:46:32.918"	"IOService::Stop()"
"DEBUG"	3604	"2017-01-11 09:46:32.918"	"TCP - AcceptEx failed. Error code: 995, Message: Der E/A-Vorgang wurde wegen eines Threadendes oder einer Anwendungsanforderung abgebrochen"
"DEBUG"	3604	"2017-01-11 09:46:32.918"	"Ending session 38302"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"IOService::DoWork() - removing Queue IOCP Queue"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"WorkQueueManager::RemoveQueue - IOCPQueue"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"Stopping working queue IOCPQueue."
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"Interupt and join threads in working queue IOCPQueue"
"DEBUG"	3612	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3608	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3604	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3600	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3592	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3596	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3588	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3584	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3580	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3568	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3572	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3560	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3576	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3556	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3564	"2017-01-11 09:46:32.934"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"All threads are joined in queue IOCPQueue."
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"WorkQueueManager::RemoveQueue - Stopped IOCPQueue"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"WorkQueueManager::RemoveQueue - Erased IOCPQueue"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"IOService::Stop() - Complete"
"DEBUG"	3444	"2017-01-11 09:46:32.934"	"Destructing work queue IOCPQueue"
"DEBUG"	3432	"2017-01-11 09:46:33.183"	"Worker exited in work queue Server queue"
"DEBUG"	3436	"2017-01-11 09:46:33.183"	"Worker exited in work queue Server queue"
"DEBUG"	3444	"2017-01-11 09:46:33.183"	"Worker exited in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.183"	"All threads are joined in queue Server queue."
"DEBUG"	5376	"2017-01-11 09:46:33.183"	"WorkQueueManager::RemoveQueue - Stopped Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.183"	"WorkQueueManager::RemoveQueue - Erased Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.183"	"Destructing work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.183"	"Application::StopServers() - Clearing caches"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Application::StopServers() - Destructing IOCP"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Application::StopServers() - Destructing DeliveryManager"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"WorkQueueManager::RemoveQueue - SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Stopping working queue SMTP delivery queue."
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Interupt and join threads in working queue SMTP delivery queue"
"DEBUG"	3484	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3480	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3476	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3472	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3468	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3464	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3460	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3456	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3452	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3448	"2017-01-11 09:46:33.199"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"All threads are joined in queue SMTP delivery queue."
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"WorkQueueManager::RemoveQueue - Stopped SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"WorkQueueManager::RemoveQueue - Erased SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Destructing work queue SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Application::StopServers() - Destructing FetchManager"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"ExternalFetchManager::~ExternalFetchManager"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"WorkQueueManager::RemoveQueue - External fetch queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Stopping working queue External fetch queue."
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Interupt and join threads in working queue External fetch queue"
"DEBUG"	3492	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3540	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3536	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3532	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3528	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3524	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3520	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3516	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3512	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3508	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3504	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3496	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3500	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3488	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	3544	"2017-01-11 09:46:33.199"	"Worker exited in work queue External fetch queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"All threads are joined in queue External fetch queue."
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"WorkQueueManager::RemoveQueue - Stopped External fetch queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"WorkQueueManager::RemoveQueue - Erased External fetch queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Destructing work queue External fetch queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"ExternalFetchManager::~ExternalFetchManager - Removed queue"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Application::StopServers() - Destructing Scheduler"
"DEBUG"	5376	"2017-01-11 09:46:33.199"	"Application::StopServers() - Destructing Rest"
"DEBUG"	5376	"2017-01-11 09:46:33.214"	"Stopping message indexer."
"APPLICATION"	5376	"2017-01-11 09:46:33.214"	"Servers stopped."
"DEBUG"	3548	"2017-01-11 09:46:33.230"	"Message indexer stopped."
"APPLICATION"	5376	"2017-01-11 09:46:33.620"	"Starting servers..."
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Creating work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Starting work queue Server queue"
"DEBUG"	4136	"2017-01-11 09:46:33.620"	"Running worker in work queue Server queue"
"DEBUG"	5372	"2017-01-11 09:46:33.620"	"Running worker in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Started work queue Server queue"
"DEBUG"	5308	"2017-01-11 09:46:33.620"	"Running worker in work queue Server queue"
"DEBUG"	4308	"2017-01-11 09:46:33.620"	"Running worker in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Adding task Scheduler to work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Adding task IOService to work queue Server queue"
"DEBUG"	4308	"2017-01-11 09:46:33.620"	"Executing task Scheduler in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Creating work queue SMTP delivery queue"
"DEBUG"	5308	"2017-01-11 09:46:33.620"	"Executing task IOService in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Starting work queue SMTP delivery queue"
"DEBUG"	5308	"2017-01-11 09:46:33.620"	"IOService::Start()"
"DEBUG"	996	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	6124	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	5764	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	2096	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	4312	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	4064	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	3136	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	5060	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Started work queue SMTP delivery queue"
"DEBUG"	5276	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	2888	"2017-01-11 09:46:33.620"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	5376	"2017-01-11 09:46:33.620"	"Adding task SMTPDeliveryManager to work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.636"	"Creating work queue External fetch queue"
"DEBUG"	5372	"2017-01-11 09:46:33.636"	"Executing task SMTPDeliveryManager in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.636"	"Starting work queue External fetch queue"
"DEBUG"	5372	"2017-01-11 09:46:33.636"	"SMTPDeliveryManager::Start()"
"DEBUG"	4492	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	2192	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5000	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	3648	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	4780	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5308	"2017-01-11 09:46:33.636"	"Creating session 38304"
"DEBUG"	3916	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	4168	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5084	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	3664	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5572	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5376	"2017-01-11 09:46:33.636"	"Started work queue External fetch queue"
"DEBUG"	1392	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	3656	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	4132	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5280	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	6064	"2017-01-11 09:46:33.636"	"Running worker in work queue External fetch queue"
"DEBUG"	5308	"2017-01-11 09:46:33.636"	"Creating session 38305"
"DEBUG"	5376	"2017-01-11 09:46:33.636"	"Adding task ExternalFetchManager to work queue Server queue"
"DEBUG"	4136	"2017-01-11 09:46:33.636"	"Executing task ExternalFetchManager in work queue Server queue"
"DEBUG"	5376	"2017-01-11 09:46:33.636"	"Starting message indexer..."
"DEBUG"	4136	"2017-01-11 09:46:33.636"	"ExternalFetchManager::Start()"
"APPLICATION"	5376	"2017-01-11 09:46:33.636"	"Servers started."
"DEBUG"	5648	"2017-01-11 09:46:33.636"	"Message indexer started..."
"DEBUG"	5308	"2017-01-11 09:46:33.636"	"Creating session 38306"
"DEBUG"	5308	"2017-01-11 09:46:33.636"	"Creating session 38307"
"DEBUG"	5308	"2017-01-11 09:46:33.636"	"Creating session 38308"
"DEBUG"	5308	"2017-01-11 09:46:33.636"	"Creating session 38309"
"DEBUG"	5308	"2017-01-11 09:46:33.651"	"Creating session 38310"
"DEBUG"	5308	"2017-01-11 09:46:33.651"	"Creating work queue IOCPQueue"
"DEBUG"	5308	"2017-01-11 09:46:33.651"	"Starting work queue IOCPQueue"
"DEBUG"	3328	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	3684	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	1120	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	4792	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	5412	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	4592	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	788	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	5548	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	5972	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	6044	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	5160	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	6120	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	2216	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	4884	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	5308	"2017-01-11 09:46:33.651"	"Started work queue IOCPQueue"
"DEBUG"	5396	"2017-01-11 09:46:33.651"	"Running worker in work queue IOCPQueue"
"DEBUG"	5308	"2017-01-11 09:46:33.651"	"Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG"	5396	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	4884	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	2216	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	6120	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5160	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	6044	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5972	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5548	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	788	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	4592	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5412	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	4792	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	1120	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	3684	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	3328	"2017-01-11 09:46:33.651"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5648	"2017-01-11 09:46:44.368"	"No messages to index."
"DEBUG"	3328	"2017-01-11 09:46:49.423"	"Creating session 38311"
"DEBUG"	3328	"2017-01-11 09:46:49.438"	"Executing event OnClientConnect"
"DEBUG"	3328	"2017-01-11 09:46:49.438"	"Event completed"
"DEBUG"	3328	"2017-01-11 09:46:49.438"	"TCP connection started for session 38306"
"DEBUG"	1120	"2017-01-11 09:46:50.764"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:50.874"	"Ending session 38306"
"DEBUG"	3328	"2017-01-11 09:46:53.401"	"Creating session 38312"
"DEBUG"	3328	"2017-01-11 09:46:53.401"	"Executing event OnClientConnect"
"DEBUG"	3328	"2017-01-11 09:46:53.401"	"Event completed"
"DEBUG"	3328	"2017-01-11 09:46:53.401"	"TCP connection started for session 38311"
"DEBUG"	3328	"2017-01-11 09:46:53.432"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:53.495"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:53.541"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:53.588"	"Reading messages from database."
"DEBUG"	4792	"2017-01-11 09:46:53.651"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:53.697"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:53.744"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:53.838"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:53.885"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:54.009"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:54.056"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:54.228"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:54.321"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:54.368"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:54.415"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:54.462"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:54.524"	"Reading messages from database."
"DEBUG"	4792	"2017-01-11 09:46:54.571"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:54.618"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:54.649"	"Reading messages from database."
"DEBUG"	4792	"2017-01-11 09:46:54.696"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:54.743"	"Reading messages from database."
"DEBUG"	4792	"2017-01-11 09:46:54.789"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:54.836"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:54.883"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:54.930"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:54.977"	"Reading messages from database."
"DEBUG"	4792	"2017-01-11 09:46:55.023"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:55.055"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:55.117"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:55.148"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:55.195"	"Reading messages from database."
"DEBUG"	3684	"2017-01-11 09:46:55.242"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:55.289"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:55.335"	"Reading messages from database."
"DEBUG"	3328	"2017-01-11 09:46:55.585"	"Reading messages from database."
"DEBUG"	1120	"2017-01-11 09:46:55.710"	"Reading messages from database."
Re: Possible Bug in use of Pause/Resume button?
Post by jimimaseye » 2017-01-11 12:04
