hMailServer web-interface redesign
coax
Re: hMailServer web-interface redesign
Post by coax » 2018-08-15 09:07
2018-08-14 23:09
I downloaded the entire 1.4 zip and overwrote all existing files with the contents of the zip
I don't know why is that, sorry.
stephan123 wrote:
2018-08-15 07:50
When sorting the accounts-table by size, then it sorts alphabetically, not numeric.
I noticed that already, but it's linked to the JavaScript plugin tablesorter. If something can be done, or if alternative plugin exists, I'll fix it.
hMailServer web-interface redesign: https://www.hmailserver.com/forum/viewtopic.php?t=30713
Get alert when queue has 100+ messages: https://www.hmailserver.com/forum/viewtopic.php?t=31345
stephan123
Post by stephan123 » 2018-08-15 12:54
coax wrote:
2018-08-15 09:07
stephan123 wrote:
2018-08-15 07:50
Easy fix yould be to left pad some zeros to the numbers (9.4 --> 09.4). Otherwise you could pass the float-numbers in another json-field and sort by them.
coax
Post by coax » 2018-08-20 13:06
stephan123 wrote:
2018-08-15 12:54
Adding zeroes is not a decent solution because it would need many zeroes (not just one) due to quota in gigabytes. I'll fix it with different plugin :)
coax
Post by coax » 2018-08-22 12:19
New version available. Download v1.5
Changelog:
[tweak] changes to config.php
[tweak] Server graph on dashboard displays delivery queue count
[new] DMARC reports in side navigation (thanks to @tunis)
[new] IMAP folders under Account
[tweak] replaced "tablesort" with "stupidtable" plugin
[tweak] added APIPA addresses to regex in geoIp() function
[fix] CSS fix
Post by RvdH » 2018-08-24 09:57
@coax
Something is wrong in ?page=smtp, for example chrome warns about
[DOM] Found 3 elements with non-unique id #HostName:
Changing Max message size (KB) for example does not trigger anything, nothing is saved
Post by RvdH » 2018-08-24 12:18
2018-08-24 09:57
@coax
BTW, i think the reason i cannot save is because the 'bind to ip' is left blank, because of the non-unique id #HostName the wrong validator seems to be triggered
coax
Post by coax » 2018-08-24 21:44
Thanks for the info, will fix.
Edit:
Fixed: https://github.com/coax/hmailserver-web ... m_smtp.php
Post by RvdH » 2018-08-24 22:17
Still refuses to save anything, as 'Bind to local IP address' is required...thats kinda strange as in hmailserver default settings this is not set
Post by RvdH » 2018-08-24 23:15
I found the culprit, in function PrintPropertyEditRow you make anything that has a $checktype required by default, but in this case it is a optional value
if (isset($checktype)) $req = 'req ';
I think you need to change this into something like: (eg: anything that has a $checktype set but with a class 'notreq', make not required)
if (isset($checktype) && $class != 'notreq' ) $req = 'req ';
coax
Post by coax » 2018-08-25 11:53
I've thought of that already, checktype can be null and it will not set required field. I've updated the code again :)
Post by mattg » 2018-08-26 03:19
You tricked me up by adding to the bottom of 'include_versioncheck.php'
I run a custom version (RvdH's excellent vesions) , so I always need to modify this file.
Lately I've just opened in notepad++, updated all files, then saved my 'open in notepad++ version' and that has worked.
Took me a while to find what had changed...
I was getting blank page instead of a login screen, and my PHP logs weren't showing anything.
This code was added
// Actual hMailAdmin version
$hmail_config['version'] = 1.5;
tester02
Post by tester02 » 2018-08-26 08:12
./include/functions.php
// Version check
function Version() {
	$json = file_get_contents("https://raw.githubusercontent.com/coax/hmailserver-webadmin/master/version.txt");
	$parsed = json_decode($json);
	return $parsed;
I use the 64bit 5.7 hMailserver and therefore I have to modify the version, too.
I ran into the blank page too because github wasn't reachable for whatever reason, so I changed the version check within functions to return just "1.5" without doing the lookup.
The only page I found it relevant for was the impressumpage where you would get a notice that a new version is out.
coax
Post by coax » 2018-08-26 12:02
2018-08-26 03:19
This code was added
Github will show all the files that are modified if you click on version, like this: https://github.com/coax/hmailserver-web ... 16ec70b8ee Sorry for the confusion , it needed to be done that way, because config.php is not changed that often.
coax
Post by coax » 2018-08-26 12:07
tester02 wrote:
2018-08-26 08:12
It was added with purpose of easier maintenance:
Of course, you can remove it if you manually want to check for updates.
MrGeneration
Post by MrGeneration » 2018-09-17 13:41
I "just" found your thread here and must say: WOW.
Thanks for this awesome redesign!!!
I implemented it on my instance already love it! :mrgreen:
Live hmail-version: 5.6.5-B2293, with spamd and greylisting enabled
chaser
Post by chaser » 2018-09-28 17:22
Just come across this thread, and thought I'd give hMailAdmin a try. Unfortunately I've not been able to get it working yet, and think it may be to do with my slightly unconventional setup. My hMailServer is running on a windows 2012 server, but I don't have a web server running on this machine. Instead my main web server (Apache) is running on a CentOS box, which is on the same subnet. Is it possible to run hMailAdmin from this Apache server, or does hMailAdmin need to run on the same physical machine as hMailServer?
The reason I ask is that I am just getting a HTTP Error 500 when I try to access it from my web browser.
I'm fairly happy that my Apache virtual host is set up correctly. The URL to hMailAdmin is http://mailadmin.mydomain.com, and I get a message telling me to create a config.php from config-dist.php if I haven't created a copy of the config.php file. I only get the HTTP Error 500 once I've created the config.php file. I've also set:
$hmail_config['rooturl'] = "http://mailadmin.mydomain.com/";
in the config.php file.
Any idea what I might be doing wrong???
coax
Post by coax » 2018-09-29 10:05
chaser wrote:
2018-09-28 17:22
Web admin (either PHPWebAdmin or hMailAdmin, they have the same core) uses hMailServer's COM API and needs access permissions, this might help:
https://www.hmailserver.com/documentati ... hpwebadmin
https://www.hmailserver.com/documentati ... ermissions
Post by SorenR » 2018-09-29 10:25
chaser wrote:
2018-09-28 17:22
hMailAdmin need COM/DCOM, so unless you have some really expensive tools like "J-Integra for COM" or "EntireX DCOM", you will NOT make it run on a 'nix box.
chaser
Post by chaser » 2018-09-29 10:32
Ok. Thanks for the feedback. I think I'll give up with that plan, then. I might try setting IIS on the Windows server box that's also running hMailServer at some point and see if I can get it running from there.
Giuseppe_R
Post by Giuseppe_R » 2019-01-10 13:03
Good morning,
I have a hmail server ver 5.6.8B2431 on Windows 2008R2 and Trend ServerProtect antivirus.
When the antivirus engine finds a virus, it simply delete the message, and the hmail log file contains the row "554 Rejected - No data saved"
It would be great if the graph "processed messages" would show these events as virus...
Thanks in advance.
G
coax
Post by coax » 2019-01-10 14:16
Giuseppe_R wrote:
2019-01-10 13:03
This is related to hMailServer core and cannot be changed in web admin, because web is using COM API which simply reads these: https://www.hmailserver.com/documentati ... ect_status
Giuseppe_R
Post by Giuseppe_R » 2019-01-10 21:34
coax wrote:
2019-01-10 14:16
Giuseppe_R wrote:
2019-01-10 13:03
Okay, thanks for your reply.
Good evening.
digim
Post by digim » 2019-02-06 23:05
i've posted this already in main feature request thread and want to copy here (this is especially to coax cause i love your webadmin so much :) )
one more huge request:
please add ability to display active directory login next to the mail account name in the main accounts list window (it feels so empty with those two columns now)
this will significantly decrease time to search right account to work with!
will be a relief if this will be implemented in webadmin :roll:
Kriztan
Post by Kriztan » 2019-02-22 21:51
Hi coax,
thanks for your nice webinterface. I'm unsing this since some weeks and noticed, that version 1.5 creates duplicate rule actions. Can anybody confirm this?
tester02
Post by tester02 » 2019-02-23 13:50
For me it works just fine...sorry I'm no help.
Post by jimimaseye » 2019-02-23 17:01
Kriztan wrote:
2019-02-22 21:51
Hi coax,
When you say duplicates do you mean it creates duplicate rule actions or it just displays the existing rule actions in duplicate?
Kriztan
Post by Kriztan » 2019-02-26 21:29
Sorry for my late response. I've tested it again and created a new rule with one criteria and one action. Not only the action is created twice, also the new rule was created twice. I've checked it with hmailadmin on the server, not via the remote webadmin.
I've recognized another strange thing: the first rule, which was created by the webadmin, has no critia and no action, but the second rule has twice of them.
coax
Post by coax » 2019-03-31 14:50
Kriztan wrote:
2019-02-26 21:29
I've tried to reproduce your issue but I couldn't, it might be something wrong with your installation. Also, you mention "hmailadmin on the server" and "remote webadmin" - which is which? There is "hMailServer Administrator" (GUI executable on server), there is "PHPWebAdmin" (stock web admin) and "hMailAdmin" (this project).
mibyge
Post by mibyge » 2019-04-03 19:18
Hello.
I've been using your fantastic redesign for a long time, but I've been unable to use it for a while now because I get an "Invalid CSRF token." error when I try to log in.
I've tried multiple browsers from multiple devices (including the server), but it's the same error every time.
I suspect that it might have started after a PHP upgrade at one point, but I'm not sure.
The server is a Windows Server 2016 with PHP Version 7.2.16, hMailServer 5.6.7 - Build 2425 and version 1.5 of hMailAdmin.
Any suggestions?
Thanks in advance.
coax
Post by coax » 2019-04-03 20:22
Check rooturl in your config and make sure you're logging in from the same URL (double check for missing www or https in your URL where you try to log in).
mibyge
Post by mibyge » 2019-04-05 22:25
coax wrote:
2019-04-03 20:22
They match. I've even tried to copy/paste the URL from the config file directly into the browser to be completely sure.
coax
Post by coax » 2019-04-06 11:27
In hMailAdmin we left all the core coding (including CSRF validation) same as PHPWebAdmin, so try to log in to PHPWebAdmin to see if you get the same error.
mibyge
Post by mibyge » 2019-04-07 18:48
coax wrote:
2019-04-06 11:27
I get the same error with the default PHPWebAdmin.
I'll try asking the question in the general forum then.
Thanks.
Kriztan
Post by Kriztan » 2019-04-08 21:29
coax wrote:
2019-03-31 14:50
Thanks for your reply, I've replaced all local from your hMailAdmin with that one from github and the "bug" is gone.
hmbaer
Post by hmbaer » 2019-05-01 14:41
Great interface!
But i can type in the wrong password as many times as i want and there is no lock (if i do NOT have an active directory link for the user). Are there any solutions?
Thank you.
hmbaer
Post by hmbaer » 2019-05-11 11:36
No idea? :-)
coax
Post by coax » 2019-05-11 11:47
hmbaer wrote:
2019-05-01 14:41
Great interface!
Thank you.
Has nothing to do with this redesign. Try asking in different sub.
hmbaer
Post by hmbaer » 2019-05-11 11:55
Your new design is nice.
But i think it should be in your interest that the login is secure, too. But i got your point.
coax
Post by coax » 2019-05-11 22:14
hmbaer wrote:
2019-05-11 11:55
We left all the original coding of PHPWebAdmin + some modifications which were possible. This would probably need changes to COM API therefore impossible to implement.
hmbaer
Post by hmbaer » 2019-05-13 06:22
Ok. I only wanted to tell that there is a security issue (irrespective what the technical reason is). Maybe it is possible to implement a php-based ip-check (e.g. text file based if changes to the database are not possible). But i think the best solution would be to ban failed logins by using the hMailServer-module that is used.
Post by palinka » 2019-05-13 14:01
Hi. I may be using an older version and this was already addressed, but i noticed today that the geoip is broken:
Country
OPERATION FAILED
Description: file_get_contents(http://geoip.nekudo.com/api/41.190.130.194): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found
Line: 339
Script: functions.php
It appears that nekudo got bought by someone and the api is no longer available. I made a change to include/functions.php and it's working.
// IP 2 Country
function GeoIp($ip) {
	global $obLanguage;
	if ($ip === '0.0.0.0') return Translate('Unknown');
	$regex = '/(127\.0\.0\.1)|^(10\.)|^(192\.168\.)|^(169\.254\.)|^(172\.(1[6-9]|2[0-9]|3[0-1]))/';
	if (preg_match($regex, $ip)) return Translate('Local IP range');
	$json = file_get_contents('http://ip-api.com/json/' . $ip);
	if(!$parsed->countryCode) return Translate('Unknown');
	return '<p><img src="flags/' . $parsed->countryCode . '.gif" style="margin-right:5px;">' . $parsed->country . '</p>';
coax
Post by coax » 2019-05-13 14:04
2019-05-13 14:01
You're using old version. This was addressed and fixed in latest version.
Post by palinka » 2019-05-13 14:12
coax wrote:
2019-05-13 14:04
2019-05-13 14:01
Ok cool. :mrgreen:
tester02
Post by tester02 » 2019-12-14 19:26
Since this is the most active topic on the php-webadmin code I post here.
With php version 7.4.0 the function get_magic_quotes_gpc is DEPRECATED and therefore returns an error.
I found it only in --> include / functions.php / line 26
26 if (get_magic_quotes_gpc())
27 $retval = stripslashes($retval);
Deleting the line works but I'm not sure if I run now into some unwanted inputs...
Hedsteem
Post by Hedsteem » 2020-01-16 20:39
Need to Remove the SSL3 and add TLS1.3 Under the SSL/TLS Section, It Blows errors on the Latest Beta, I removed all the SSL 3.0 Entries in the hm_ssltls.php file.
BlackJub
Post by BlackJub » 2020-01-18 08:46
Could you please be more precise on the "SSL/TLS" section, please?
Which PHP file are you talking about? I see no SSL3 reference in the "hm_ssltls.php" file, and TLS 1.3 is already there.
(I get some SSL errors too in the bottom left pane when I log in...)
Thanks in advance!
