hMailServer web-interface redesign
coax
Re: hMailServer web-interface redesign
Post by coax » 2018-08-15 09:07
2018-08-14 23:09
I downloaded the entire 1.4 zip and overwrote all existing files with the contents of the zip
I don't know why is that, sorry.
stephan123 wrote:
2018-08-15 07:50
When sorting the accounts-table by size, then it sorts alphabetically, not numeric.
I noticed that already, but it's linked to the JavaScript plugin tablesorter. If something can be done, or if alternative plugin exists, I'll fix it.
hMailServer web-interface redesign: https://www.hmailserver.com/forum/viewtopic.php?t=30713
Get alert when queue has 100+ messages: https://www.hmailserver.com/forum/viewtopic.php?t=31345
stephan123
Post by stephan123 » 2018-08-15 12:54
coax wrote:
2018-08-15 09:07
stephan123 wrote:
2018-08-15 07:50
Easy fix yould be to left pad some zeros to the numbers (9.4 --> 09.4). Otherwise you could pass the float-numbers in another json-field and sort by them.
coax
Post by coax » 2018-08-20 13:06
stephan123 wrote:
2018-08-15 12:54
Adding zeroes is not a decent solution because it would need many zeroes (not just one) due to quota in gigabytes. I'll fix it with different plugin :)
coax
Post by coax » 2018-08-22 12:19
New version available. Download v1.5
Changelog:
[tweak] changes to config.php
[tweak] Server graph on dashboard displays delivery queue count
[new] DMARC reports in side navigation (thanks to @tunis)
[new] IMAP folders under Account
[tweak] replaced "tablesort" with "stupidtable" plugin
[tweak] added APIPA addresses to regex in geoIp() function
[fix] CSS fix
Post by RvdH » 2018-08-24 09:57
@coax
Something is wrong in ?page=smtp, for example chrome warns about
[DOM] Found 3 elements with non-unique id #HostName:
Changing Max message size (KB) for example does not trigger anything, nothing is saved
Post by RvdH » 2018-08-24 12:18
2018-08-24 09:57
@coax
BTW, i think the reason i cannot save is because the 'bind to ip' is left blank, because of the non-unique id #HostName the wrong validator seems to be triggered
coax
Post by coax » 2018-08-24 21:44
Thanks for the info, will fix.
Edit:
Fixed: https://github.com/coax/hmailserver-web ... m_smtp.php
Post by RvdH » 2018-08-24 22:17
Still refuses to save anything, as 'Bind to local IP address' is required...thats kinda strange as in hmailserver default settings this is not set
Post by RvdH » 2018-08-24 23:15
I found the culprit, in function PrintPropertyEditRow you make anything that has a $checktype required by default, but in this case it is a optional value
if (isset($checktype)) $req = 'req ';
I think you need to change this into something like: (eg: anything that has a $checktype set but with a class 'notreq', make not required)
if (isset($checktype) && $class != 'notreq' ) $req = 'req ';
coax
Post by coax » 2018-08-25 11:53
I've thought of that already, checktype can be null and it will not set required field. I've updated the code again :)
Post by mattg » 2018-08-26 03:19
You tricked me up by adding to the bottom of 'include_versioncheck.php'
I run a custom version (RvdH's excellent vesions) , so I always need to modify this file.
Lately I've just opened in notepad++, updated all files, then saved my 'open in notepad++ version' and that has worked.
Took me a while to find what had changed...
I was getting blank page instead of a login screen, and my PHP logs weren't showing anything.
This code was added
// Actual hMailAdmin version
$hmail_config['version'] = 1.5;
tester02
Post by tester02 » 2018-08-26 08:12
./include/functions.php
// Version check
function Version() {
	$json = file_get_contents("https://raw.githubusercontent.com/coax/hmailserver-webadmin/master/version.txt");
	$parsed = json_decode($json);
	return $parsed;
I use the 64bit 5.7 hMailserver and therefore I have to modify the version, too.
I ran into the blank page too because github wasn't reachable for whatever reason, so I changed the version check within functions to return just "1.5" without doing the lookup.
The only page I found it relevant for was the impressumpage where you would get a notice that a new version is out.
coax
Post by coax » 2018-08-26 12:02
2018-08-26 03:19
This code was added
Github will show all the files that are modified if you click on version, like this: https://github.com/coax/hmailserver-web ... 16ec70b8ee Sorry for the confusion , it needed to be done that way, because config.php is not changed that often.
coax
Post by coax » 2018-08-26 12:07
tester02 wrote:
2018-08-26 08:12
It was added with purpose of easier maintenance:
Of course, you can remove it if you manually want to check for updates.
MrGeneration
Post by MrGeneration » 2018-09-17 13:41
I "just" found your thread here and must say: WOW.
Thanks for this awesome redesign!!!
I implemented it on my instance already love it! :mrgreen:
Live hmail-version: 5.6.5-B2293, with spamd and greylisting enabled
chaser
Post by chaser » 2018-09-28 17:22
Just come across this thread, and thought I'd give hMailAdmin a try. Unfortunately I've not been able to get it working yet, and think it may be to do with my slightly unconventional setup. My hMailServer is running on a windows 2012 server, but I don't have a web server running on this machine. Instead my main web server (Apache) is running on a CentOS box, which is on the same subnet. Is it possible to run hMailAdmin from this Apache server, or does hMailAdmin need to run on the same physical machine as hMailServer?
The reason I ask is that I am just getting a HTTP Error 500 when I try to access it from my web browser.
I'm fairly happy that my Apache virtual host is set up correctly. The URL to hMailAdmin is http://mailadmin.mydomain.com, and I get a message telling me to create a config.php from config-dist.php if I haven't created a copy of the config.php file. I only get the HTTP Error 500 once I've created the config.php file. I've also set:
$hmail_config['rooturl'] = "http://mailadmin.mydomain.com/";
in the config.php file.
Any idea what I might be doing wrong???
coax
Post by coax » 2018-09-29 10:05
chaser wrote:
2018-09-28 17:22
Web admin (either PHPWebAdmin or hMailAdmin, they have the same core) uses hMailServer's COM API and needs access permissions, this might help:
https://www.hmailserver.com/documentati ... hpwebadmin
https://www.hmailserver.com/documentati ... ermissions
Post by SorenR » 2018-09-29 10:25
chaser wrote:
2018-09-28 17:22
hMailAdmin need COM/DCOM, so unless you have some really expensive tools like "J-Integra for COM" or "EntireX DCOM", you will NOT make it run on a 'nix box.
chaser
Post by chaser » 2018-09-29 10:32
Ok. Thanks for the feedback. I think I'll give up with that plan, then. I might try setting IIS on the Windows server box that's also running hMailServer at some point and see if I can get it running from there.
