Sub OnHELO(oClient) progress?
Kelden
Re: Sub OnHELO(oClient) progress?
Post by Kelden » 2021-04-03 01:04
@RvdH
I like most improvements, what I still miss is a whitelist for domains that ignore graylisting.
e.g. *.outbound.protection.outlook.com
There are some scripts, but it's not a nice solution.
Could you add such an option?
Post by RvdH » 2021-04-03 11:57
Kelden wrote:
2021-04-03 01:04
@RvdH
It sounds like you would like to greylistwhitelist connection based on HELO/EHLO *.outbound.protection.outlook.com?
You do know spammers do fake HELO/EHLO headers, right?
So you either have to verify the IP is actually allowed to send from *.outbound.protection.outlook.com using the SPF record or that the PTR matches for that IP (i believe SorenR uses the later, right?)
As there are script solutions available i do not feel the need to incorporate such functionality, not to mention the difficulty incorporating this would involve
The (script) approach below does not only verify the SPF check but it also verifies the received header so it matches the domain it supposed to be arriving from.
As mail arrives from *.outbound.protection.outlook.com is always send using STARTTLS:
On the first event OnHELO (red) the server (might) not be whitelisted, so we check the IP against SPF for the HEL0/EHLO header and whitelist it as needed
On the second event OnHELO (green) after STARTTLS command is inquired the server should be whitelisted from greylisting
the flow is like this:
"TCPIP" 8864 "2021-04-01 09:21:11.235" "TCP - 40.92.89.36 connected to 192.168.2.2:25."
"DEBUG" 8864 "2021-04-01 09:21:11.235" "Executing event OnClientConnect"
"DEBUG" 8864 "2021-04-01 09:21:11.370" "Event completed"
"DEBUG" 8864 "2021-04-01 09:21:11.370" "TCP connection started for session 7"
"SMTPD" 8864 7 "2021-04-01 09:21:11.370" "40.92.89.36" "SENT: 220 mail.server.com ESMTP"
"SMTPD" 7808 7 "2021-04-01 09:21:11.386" "40.92.89.36" "RECEIVED: EHLO EUR05-DB8-obe.outbound.protection.outlook.com"
"DEBUG" 7808 "2021-04-01 09:21:11.386" "Executing event OnHELO"
"DEBUG" 7808 "2021-04-01 09:21:14.039" "Event completed"
"SMTPD" 7808 7 "2021-04-01 09:21:14.039" "40.92.89.36" "SENT: 250-mail.server.com[nl]250-SIZE 51200000[nl]250-STARTTLS[nl]250 HELP"
"SMTPD" 4592 7 "2021-04-01 09:21:14.070" "40.92.89.36" "RECEIVED: STARTTLS"
"SMTPD" 4592 7 "2021-04-01 09:21:14.070" "40.92.89.36" "SENT: 220 Ready to start TLS"
"DEBUG" 8864 "2021-04-01 09:21:14.070" "Performing SSL/TLS handshake for session 7. Verify certificate: False"
"TCPIP" 8864 "2021-04-01 09:21:14.195" "TCPConnection - TLS/SSL handshake completed. Session Id: 7, Remote IP: 40.92.89.36, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"SMTPD" 8864 7 "2021-04-01 09:21:14.211" "40.92.89.36" "RECEIVED: EHLO EUR05-DB8-obe.outbound.protection.outlook.com"
"DEBUG" 8864 "2021-04-01 09:21:14.211" "Executing event OnHELO"
"DEBUG" 8864 "2021-04-01 09:21:14.304" "Event completed"
"SMTPD" 8864 7 "2021-04-01 09:21:14.304" "40.92.89.36" "SENT: 250-mail.server.com[nl]250-SIZE 51200000[nl]250 HELP"
"SMTPD" 7808 7 "2021-04-01 09:21:14.320" "40.92.89.36" "RECEIVED: MAIL FROM:<*@outlook.com> SIZE=12374"
"DEBUG" 7808 "2021-04-01 09:21:14.461" "Spam test: SpamTestHeloHost, Score: 1"
"DEBUG" 7808 "2021-04-01 09:21:14.476" "Spam test: SpamTestMXRecords, Score: 0"
"DEBUG" 7808 "2021-04-01 09:21:14.492" "Spam test: SpamTestSPF, Result: Pass"
"DEBUG" 7808 "2021-04-01 09:21:14.492" "Spam test: SpamTestSPF, Score: 0"
"DEBUG" 7808 "2021-04-01 09:21:14.492" "Total spam score: 1"
"SMTPD" 7808 7 "2021-04-01 09:21:14.492" "40.92.89.36" "SENT: 250 OK"
"SMTPD" 4592 7 "2021-04-01 09:21:14.508" "40.92.89.36" "RECEIVED: RCPT TO:<*@server.com>"
"SMTPD" 4592 7 "2021-04-01 09:21:14.523" "40.92.89.36" "SENT: 250 OK"
"SMTPD" 8864 7 "2021-04-01 09:21:14.539" "40.92.89.36" "RECEIVED: DATA"
"DEBUG" 8864 "2021-04-01 09:21:14.539" "Executing event OnSMTPData"
"DEBUG" 8864 "2021-04-01 09:21:14.570" "Event completed"
"SMTPD" 8864 7 "2021-04-01 09:21:14.570" "40.92.89.36" "SENT: 354 OK, send."
spfverify.exe ipaddress host
spfverify.exe 40.92.89.36 outlook.com
IP address matches SPF record(s) ip range for domain (ExitCode 0)
You need a hmailserver build with Sub OnHELO(oClient) support though
Mail send from Office 365 users always is received from one of outlook servers, you could match the received header with a simple regex
^([a-z]{3}[\d]{2}\-[a-z]{2}[\d]\-)(obe\.outbound\.protection\.outlook\.com)$
Dim oRegEx
oRegEx.IgnoreCase = True
oRegEx.Global = False
oRegEx.Pattern= "^([a-z]{3}[\d]{2}\-[a-z]{2}[\d]\-)(obe\.outbound\.protection\.outlook\.com)$"
If oRegEx.Test(oClient.HELO) Then
	Call AddGreyList(oClient.IPAddress, oClient.HELO)
	Result.Value = 0
	Exit Sub
Set oRegEx = Nothing
Sub AddGreyList(ByVal strIP, ByVal strHELO)
	dim iReturn : iReturn = 2
	dim hostname : hostname = getDomainName(strHELO)
	Dim oApp
	Call oApp.Authenticate("Administrator", sAdminPassword)
	With LockFile("C:\Program Files (x86)\hMailServer\Temp\greylistwhite.lck")
		On Error Resume Next
		oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Refresh
		If oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP) Is Nothing Then
				iReturn = .Run("""C:\Program Files (x86)\hMailServer\Events\spfverify.exe"" " & strIP & " " & hostname & "", 0, True)
			if iReturn = 0 Then
				EventLog.Write("spfverify.exe " & strIP & " passed for: " & hostname)
				With oApp.Settings.AntiSpam.GreyListingWhiteAddresses.Add
					.Description = Date & " Auto-Added '" & strHELO & "'"
					.IPAddress = strIP
					.Save
			ElseIf iReturn = 1 Then
				EventLog.Write("spfverify.exe " & strIP & " failed for: " & hostname)
				EventLog.Write("spfverify.exe command error, spfverify.exe " & strIP & " failed for: " & hostname)
			End if
			With oApp.Settings.AntiSpam.GreyListingWhiteAddresses.ItemByName(strIP)
				.Save
		On Error Goto 0
		.Close '// Close LockFile
	Set oApp = Nothing
Function getDomainName(byVal strHELO)
	dim aryDomain, str2ndLevel, strTopLevel
	getDomainName = Null
	If Len(strHELO) > 0 Then
		aryDomain = Split(strHELO,".")
		If uBound(aryDomain) >= 1 Then
			str2ndLevel = aryDomain(uBound(aryDomain)-1)
			strTopLevel = aryDomain(uBound(aryDomain))
			getDomainName = str2ndLevel & "." & strTopLevel
Function LockFile(strPath)
	Const Append = 8
	Const Unicode = -1
		Dim oFile, i
		For i = 0 To 30
			If (Not Err.Number = 70) Then
				Set LockFile = oFile
				On Error Goto 0
				Exit For
			On Error Goto 0
			Wait(1)
	Set oFile = Nothing
	If (Err.Number = 70) Then
		Err.Clear
	ElseIf (Err.Number <> 0) Then
		Err.Clear
Function Wait(sec)
		.Run "timeout /NOBREAK /T " & Int(sec), 0, True
		' REM .Run "sleep -m " & Int(sec * 1000), 0, True
		' REM .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True
More info/download of spfverify.exe
GreyListingWhiteAddressesCleanup.vbs (run from task scheduler to remove whiltelistedgreylisting entries after x days)
'Force error on undeclared variables
Option Explicit
' Cleanup of GreyListingWhiteAddresses
Dim oApp
Dim oGreyListingWhiteAddresses
Dim Days : Days = 90
Dim WLDate
Dim oEventLog
Call oApp.Authenticate("Administrator",PASSWORD) ' set your administrator password in this line
Set oEventlog = CreateObject("hMailServer.EventLog")
Set oGreyListingWhiteAddresses = oApp.Settings.AntiSpam.GreyListingWhiteAddresses
	For oGreyListingWhiteAddress = oGreyListingWhiteAddresses.Count-1 to 0 Step -1
		If (InStr(1, oGreyListingWhiteAddresses(oGreyListingWhiteAddress).Description, "Auto-Added", 1) > 0) Then
			WLDate = Mid(oGreyListingWhiteAddresses(oGreyListingWhiteAddress).Description,1,(inStr(1, oGreyListingWhiteAddresses(oGreyListingWhiteAddress).Description, " " , 1)-1))
			If DateDiff("d", WLDate, Date) > Days then
				oEventLog.Write("GreyListing WhiteAddress Delete: " & oGreyListingWhiteAddresses(oGreyListingWhiteAddress).IPAddress & " - " & oGreyListingWhiteAddresses(oGreyListingWhiteAddress).Description)
				oGreyListingWhiteAddresses(oGreyListingWhiteAddress).Delete
	On Error Goto 0
oGreyListingWhiteAddresses.Refresh
Set oGreyListingWhiteAddresses = nothing
Set oEventlog = nothing
set oApp = nothing
	Const Append = 8
	Const Unicode = -1
		Dim oFile, i
		For i = 0 To 30
				On Error Goto 0
				Exit For
			On Error Goto 0
			Wait(1)
			Set oFile = Nothing
		Err.Clear
		Err.Clear
Function Wait(sec)
Post by SorenR » 2021-04-03 14:12
This works with the HELO/EHLO greeting BUT... It COULD be modified to work with the resolved IP Address thus it can be run on servers pre-OnHELO.
viewtopic.php?p=205049#p205049
        strLookup = .PTR(strIP)
Post by RvdH » 2021-04-03 15:11
2021-04-03 14:12
Yes, and that basically is what the OP is asking for
Mine above, is a enhanced version of yours, as it verifies the IP address the mail comes from is defined as being allowed to send from that domain using the SPF-record published by the domain
I have not experienced any issues with 'big ones', like outlook, gmail, twitter, facebook, linkedin....
The only one that seems to fail from time to time is mail arriving from Apple. But that is simply because their SPF record is incomplete and missing some IP's they are sending from, example:
HELO/EHLO: rn2-msbadger06105.apple.com
IP: 17.179.250.100
spfverify.exe 17.179.250.100 apple.com
IP address does not match SPF record(s) ip range for domain (ExitCode 1)
2021-04-03 14:12
I thought i have seen a post you used the above to verify the HELO/EHLO domain....but i might be mistaken, i can't find it anymore
@Kelden,
So you have options as you see, and these are very "nice" solutions and exactly why the HELO/EHLO event trigger is added in the first place...but yeah it's needs some scripting skills and effort
Post by SorenR » 2021-04-03 17:04
2021-04-03 15:11
2021-04-03 14:12
Nope, I only verify that the HELO/EHLO follow the RFC.
    '   Validate HELO/EHLO greeting
    If Not Lookup(strRegEx, oClient.HELO) Then
        Result.Message = "5.3.0 [BAD HELO] Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
        Result.Value = 2
        If AutoBan(oClient.IPAddress, "BAD HELO " & oClient.HELO, 7, "d") Then EventLogX.Write( LPad("BAD HELO", 15, " ") & vbTab & LPad(oClient.IPAddress, 16, " ") & vbTab & LPad(" ", 3, " ") & vbTab & LPad(" ", 16, " ") & vbTab & oClient.HELO )
        EventLogX.Write( LPad("REJECT", 15, " ") & vbTab & LPad(oClient.IPAddress, 16, " ") & vbTab & Result.Message )
        ' Disconnect(oClient.IPAddress)
        Set EventLogX = Nothing
        Exit Sub
