Sub OnHELO(oClient) progress?
estradis
Re: Sub OnHELO(oClient) progress?
Post by estradis » 2019-05-13 20:03
estradis wrote:
2019-04-26 09:34
... the executive board will probably decide to replace hms.
... and they did!
https://www.hmailserver.com/forum/viewt ... =7&t=33995
Post by RvdH » 2019-06-02 02:37
Install the latest production and/or beta version from the URL below, then copy and overwrite files in this archive in hmailserver '/bin' directory
https://build.hmailserver.com/repositor ... -B2437.exe
  1. Supports Sub OnHELO(oClient) event, issue #153
  2. Fixed Incorrect DEBUG logging for event 'OnDeliverMessage', issue #181
  3. Include HTMLBody into IMAP TEXT search, pull #193
  4. Fixed implicit conversion: "int" to "unsigned char" pull #204
  5. Faulty: SMTP 'Disconnect client after too many invalid commands' pull issue #160
  6. SMTP server error "550 Unsupported ESMTP extension" on MAIL FROM:... AUTH=<> [with fix] issue #164
  7. Removed warning if backup was more than 1,5GB and 15GB limit. There's no longer a recommended max-size - the time will vary with the installation size. issue #69
  8. Speed up 'update hm_messages set messageflags' issue #221
  9. Treat authenticated users as localsender if the sender is authenticated and AuthUserIsLocal=1 INI setting Office 2016 Bug
  10. Add Return-Path header as topmost header before sending the message to SA (+ delete Return-Path header after the SA check completes) issue #116
  11. Experimental eventhandler OnClientLogon(oClient), New ClientInfo property oClient.Authenticated (Boolean)
  12. Handling of long UIDL response lists was too slow. issue #93
  13. When calling SpamAssassin and there was a connection failure, sometimes temporary files were left behind issue #100
  14. SURBL detection properly fails to detect url's ending with a query string issue #108
  15. If a route is set up, but the recipient does not match an address in the route address list, the domain catch-all should be used if specified. issue #74
  16. Fix ExternalFetcher DELE when no RETR, pull pull #254
  17. SMTP multiply max message size with 1024 issue #267
  18. Add email address variable to SignatureAdder.cpp pull #265
  19. DKIM on acccount-rule 'reply' not applied #172 issue #172
  20. preserve RewriteEnvelopeFromWhenForwarding setting when forwarding from account rule
+ OpenSSL 1.0.2s (released may 28, 2019)
https://d-fault.nl/files/5.6.8-B2437.20 ... _1.0.2s.7z
Post by jimimaseye » 2019-06-02 09:48
First post on page 1 now points to the latest release as it became difficult finding the updates as the thread progresses. (I will edit and update it whenever a new one is posted).
That should help.
insomniac2k2
Post by insomniac2k2 » 2019-06-02 15:27
Thank you for your contribution. I will update my servers as soon as i get a few free minutes :)
2019-06-02 02:37
nitro
Post by nitro » 2019-06-04 09:25
2019-06-02 02:37
Approximately 24 hours ago I updated my production server with this new version.
One of my clients uses the "damn" version of Outlook 2016, I have correctly configured the .ini for "RECEIVED: MAIL FROM: <>".
I have only detected these errors in the log as strange or different.
"ERROR"	9928	"2019-06-03 18:59:30.767"	"Severity: 3 (Medium), Code: HM5310, Source: DKIM::SignHash_, Description: Unable to parse the private key file."
"ERROR"	9928	"2019-06-03 18:59:30.767"	"Severity: 3 (Medium), Code: HM5308, Source: DKIM::Sign, Description: Failed to create siganture."
"ERROR"	9928	"2019-06-03 18:59:30.767"	"Severity: 3 (Medium), Code: HM5306, Source: DKIMSigner::Sign, Description: Message signing using DKIM failed."
I understand that it has realation with:
Is it because of a bad configuration in the DKIM?
To this day I have not suffered that error.
Thank you very much for your work and your help to keep hmailserver alive.
Update
Scenario:
1, DKIM signing setup and enabled - Sending an email with email client signs the email correctly (with the usual "dkim-signature:" header).
[b]2, Set up an Account Rule with a "REPLY (email)" as an action (all fields filled correctly).[/b]
BUT the received reply email (sent by the rule) does not get DKIM signed.
Could it be the problem?
Post by RvdH » 2019-06-04 11:37
The account address this account rule is assigned to and the address defined in the From field are the same?
Addendum: And only emails to external accounts get signed by DKIM
nitro
Post by nitro » 2019-06-04 11:52
2019-06-04 11:37
No, it is a forwarding over the same domain but not on the same account.
Post by RvdH » 2019-06-04 11:57
Forwarding? Settings in that Tab, have literally nothing to do with an Account Reply rule, or what am i missing here?
nitro
Post by nitro » 2019-06-04 12:02
2019-06-04 11:57
There is no rule defined for those accounts, I do not know if the forwarding behaves internally as if it were a rule.
That domain and those accounts do not have any other special configuration.
From the moment of the error, more than 1000 emails have already been processed and the error has not been repeated.
Post by RvdH » 2019-06-04 12:25
nitro wrote:
2019-06-04 12:02
No :!:
Do you use?
But yes, also here note that only mails to external recipients are dkim signed, if you forward from a local account to local account it never gets signed
nitro
Post by nitro » 2019-06-04 12:37
Do not pay attention to me, it's just a blank space in the DKIM chain of dns.
I have reconfigured, this time correctly and the error no longer appears when receiving an email from an external account.
From what I see, it must have been configured for a long time but with the previous versions it did not show an error in the log.
I feel the discomfort, and thanks for your help.
Post by RvdH » 2019-06-04 12:38
Glad you got it resolved :wink:
estradis
Post by estradis » 2019-06-06 09:55
Please check your certificate. It's expired.
Post by RvdH » 2019-06-06 13:28
It is not mine ;)
Post by RvdH » 2019-07-08 08:08
  21. The logical flow should be to disregard "Require SMTP authentication" if "Allow deliveries from" is unselected issue #287
https://d-fault.nl/files/5.6.8-B2437.21 ... _1.0.2s.7z
nitro
Post by nitro » 2019-07-08 10:28
I'll update to see how it works, so I see it's a minor update. Thanks for your job.
Post by mattg » 2019-07-08 13:18
Thanks from me too
Already installed and in use
ras07
Post by ras07 » 2019-07-08 17:17
Installed and using, no problems so far - thanks!
ras07
Post by ras07 » 2019-12-23 23:04
Is 5.6.8-B2437.21 still the latest?
Is OnHelo in the current main beta yet? (build 2494)
Post by mattg » 2019-12-24 00:30
no sorry, although OnHelo is in the 5.7 Alpha
I've been using it for months
https://build.hmailserver.com/ (use your forum login details)
Check in artifacts for 5.7 and you will see the latest .exe
ras07
Post by ras07 » 2019-12-24 01:36
Not yet comfortable running the alpha in production (I do accept the risk of running the beta (specifically RvDH's builds) in production).
Is there a later RvDH build that's recommended?
Post by SorenR » 2019-12-24 01:40
ras07 wrote:
2019-12-23 23:04
5.6.8-B2489.22
Last extra commit (INI setting) is to overrule 'Host name' set in SMTP settings as domain part of the NDR address, which in real world scenarios would be the PTR DNS records of you IP address. This can be usefull in cases where, for example if your PTR is assigned by your ISP and you have no control over it. Or you simply like another domain to be used as NDR address
You can set the 'DaemonAddressDomain' in the INI under [Settings]
[Settings]
DaemonAddressDomain=example.com
the resulting NDR address will become mailer-daemon@example.com
Post by palinka » 2019-12-24 01:42
The only issue I've run across is the autoban score changed from 20 to 100, and when I upgraded I was not informed about it and my other IP Range priorities remained the same. Therefore, autoban took priority over my other ranges and that screwed me up until I figured it out. Easy fix - you just need to be aware.
Otherwise, its been milk and honey since installing a few months ago.
