5.7.0 Diagnose: here test local connect
tester02
Post by tester02 » 2016-05-27 20:34
since its an upcoming feature in the alpha version (5.7.0-B2366) I couldn't find an explanation in the current documenation. When I do the diagnostic with a selected domain it gives me this error:
Test local connect
Connecting to TCP/IP address in MX records for local domain domain somename.domain....
Trying to connect to host mail.somename.domain...
Trying to connect to TCP/IP address XXX.XXX.XXX.XXX on port 25.
ERROR: It was not possible to connect. Error: Could not connect to XXX.XXX.XXX.XXX on port 25 since this would mean connecting to myself..
ERROR: Failed to connect to all servers.
What's intended with this feature? Because it's called "test local connect" and when the domain is local it gives the error?
Best regards
Re: 5.7.0 Diagnose: here test local connect
Post by jimimaseye » 2016-05-27 20:47
I guess that depends on what the super-secret ip address is. :roll:
IS it a local LAN address (and if so why have you hidden it) or...?
tester02
Post by tester02 » 2016-05-27 20:53
Nope, thats the public IP-address. Here is the full diagnose protocol
Test: Server details
hMailServer version: 5.7.0-B2366
Version architecture: x64
Processor architecture: x64
Logical processors: 4
System memory: 8190 MB
Database type: MySQL
Test: Test IPv6
Test: Test outbound port
Trying to connect to TCP/IP address 46.163.109.39 on port 25.
Connected successfully.
Test: Test backup directory
Backup directory C:\MailBackup is writable.
Test: Test MX records
Trying to resolve MX records for eckgold.eu...
Host name found: mail.eckgold.eu
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain eckgold.eu...
Trying to connect to host mail.eckgold.eu...
Trying to connect to TCP/IP address 85.214.126.1 on port 25.
ERROR: It was not possible to connect. Error: Could not connect to 85.214.126.1 on port 25 since this would mean connecting to myself..
Test: Error logs
There are no error logs in the log directory.
Post by jimimaseye » 2016-05-27 21:01
It is a strange message. Do you have some HOST file or local loopback set in your modem?
I have tested that address for you and it connects ok:
Trying to connect to host eckgold.eu...
(out of interest, do you get the same if you are using HMS 5.6.x)?
tester02
Post by tester02 » 2016-05-27 21:06
Diagnose from the 5.6.5
Test: Collect server details
hMailServer version: hMailServer 5.6.5-B2360
Database type: MSSQL Compact
Test: Test IPv6
Received: 220 mail.eckgold.eu ESMTP.
Since it's the same maschine and configuration and therefore I came up with my initial question.
Post by jimimaseye » 2016-05-27 21:30
Fair enough.
So definite change between 5.6.5 and 5.7.
As 5.7 isnt even released as a beta it will be difficult to answer.
Perhaps try a direct email to Martin and ask him (but remember, given it is unreleased, he might not be in a hurry to answer). You never know.
Post by jimimaseye » 2016-05-27 21:44
tester02
Post by tester02 » 2016-05-27 22:13
Thanks for the report!
Since this error is not hampering in any kind I won't bother Martin with this issue and wait.
In addition now everybody else using a HMS alpha knows that there is an error and not a fault in their configuration.
Post by mattg » 2016-05-28 00:57
Normally the first part of that is caused (in current and earlier versions) by the router not doing loopback.
One work around is to create a 'C:\windows\system32\drivers\etc\hosts' file entry for that IP address.
Is it possible that the machine with current version has such a hosts entry and the machine with the ALPHA version doesn't have that hosts entry??
ALSO, do you have a 'bind to local IP address' set in SMTP Advanced settings on the Alpha machine?
Post by jimimaseye » 2016-05-28 08:22
I'm hoping he says none to all of the above. I asked him this already and he said that the working 5.6.5 and non-working 5.7 are the same machine and configuration (concluding it's a software difference).
tester02
Post by tester02 » 2016-05-28 15:31
mattg wrote:Is it possible that the machine with current version has such a hosts entry and the machine with the ALPHA version doesn't have that hosts entry??
My hostfile has no entries.
mattg wrote:ALSO, do you have a 'bind to local IP address' set in SMTP Advanced settings on the Alpha machine?
Nope, this field is left blank in both cases.
After jimimaseye asked about the diagnose of the 5.6.5 I did the following steps:
- saved settings and domains via the backup function in the 5.7
- stopped hMailServer service
- renamed hMailServer service to NewhMailServer
- installed the 5.6.5 with internal db
- restored settings and domains from the 5.7 backup -> restore
- run diagnostic
Therefore I said its the same maschine and configuration
