Different encondings in log files?
estradis
Post by estradis » 2015-08-12 16:20
Hi there,
hMailserver logs are written daily in separate (ERROR_)?hMailserver_YYYY_MM_DD.log files, encoded by UTF-8 without BOM.
The eventlog is always written in the same file (hMailserver_Events.log) without rotation, encoded by UCS-2 Little Endian. If I try to pre-create a UTF-8 encoded file, hMailserver will destroy it.
I really wonder why?
Wouldn't it be better to keep the same format and the same rotation?
Greetings
