SSL cipher details in Received headers and log
Post by martin » 2014-10-04 10:51
While I'm still working on 5.5.1, I've added SSL cipher info to the Received headers in 5.6 as some users requested. 5.6 is currently pre-alpha and should not be used anywhere near production. :)
Wanted to share this only if some of you have some feedback. The information included is:
  • Version (SSLv2, SSLv3/TLSv1)
  • Cipher (the full name of the cipher used)
  • The number of bits used. (Can often be derived from the cipher)
It could look like something similar to this:
Received: from abc.example.com ([1.1.1.1])
	by def.example.com with ESMTP
	(version=TLSv1/SSLv3 cipher=DHE-RSA-AES256-SHA bits=256)
	; Mon, 19 Aug 2013 10:41:21 -0400
The same information is also included in the hMailServer TCP/IP log when handshake has completed.
TCPConnection - TLS/SSL handshake completed. Session Id: 1, Remote IP: 1.2.3.4, Version: TLSv1/SSLv3, Cipher: DHE-RSA-AES256-SHA, Bits: 256
Martin Knafve
martin@hmailserver.com
https://twitter.com/knafve
prisma
Re: SSL cipher details in Received headers and log
Post by prisma » 2014-10-06 15:47
Great!
ehych
Post by ehych » 2014-10-08 20:03
It looks great!
