BODYSTRUCTURE not returning Content-ID
ssevennm
Post by ssevennm » 2005-06-24 21:53
Martin,
Doing a FETCH of the BODYSTRUCTURE is NOT returning the Content-ID. It's also not returning the correct Content-Disposition. An example of an alternative text/plain, text/html message with one inline image that is used as an <img src="cid:my_image"> follows:
BODYSTRUCTURE
			"TEXT" "PLAIN"
			("CHARSET" "US-ASCII")
			NIL
			NIL
			"8bit"
			912
			33
			"TEXT" "HTML"
			NIL
			NIL
			"8bit"
			2304
			85
		"ALTERNATIVE"
		("BOUNDARY" "b2_00160b99fab657ababc820f52998b751")
		NIL
		NIL
		"APPLICATION" "OCTET-STREAM"
		("NAME" "logo.jpg")
		NIL <<< ** this should be "<my_image>" **
		NIL
		"base64"
		5696
		NIL
		("ATTACHMENT" ("FILENAME" "logo.jpg")) <<< ** this should be "INLINE" **
	"RELATED"
	("BOUNDARY" "b1_00160b99fab657ababc820f52998b751")
	NIL
	NIL
SquirrelMail is unable to find the image by cid if the Content-ID is not returned in the BODYSTRUCTURE for HTML mail. I will post the raw message of this sample less base64 block below. If I can help you with this problem, please let me know.
ssevennm
Post by ssevennm » 2005-06-24 22:00
RFC822 Message body
Received: FROM [192.168.0.2] BY foo.bar.com with hMailServer ; Fri, 24 Jun 2005 12:23:24 -0600
Received: from localhost ([192.168.0.245]) by foo.bar.com with Microsoft SMTPSVC(6.0.3790.211);
Fri, 24 Jun 2005 12:23:22 -0600
Date: Fri, 24 Jun 2005 12:23:21 -0600
Return-Path: mailer@foo.com
To: Foo Bar <foo@bar.com>
Subject: Test Message
Message-ID: <fb853b08fa1f1a9c355fd4498e5f2374@localhost>
X-Priority: 3
X-Mailer: PHPMailer [version 1.72]
MIME-Version: 1.0
Content-Type: multipart/related;
type="text/html";
boundary="b1_fb853b08fa1f1a9c355fd4498e5f2374"
X-OriginalArrivalTime: 24 Jun 2005 18:23:23.0120 (UTC) FILETIME=[CE256F00:01C578E9]
--b1_fb853b08fa1f1a9c355fd4498e5f2374
Content-Type: multipart/alternative;
boundary="b2_fb853b08fa1f1a9c355fd4498e5f2374"
--b2_fb853b08fa1f1a9c355fd4498e5f2374
Content-Type: text/plain; charset = "iso-8859-1"
Content-Transfer-Encoding: 8bit
This is the plain text version.
Content-Type: text/html; charset = "iso-8859-1"
<p>This is the <b>HTML</b> version.</p>
--b2_fb853b08fa1f1a9c355fd4498e5f2374--
Content-Type: application/octet-stream; name="logo.jpg"
Content-Transfer-Encoding: base64
Content-ID: <my_image>
Content-Disposition: inline; filename="logo.jpg"
<<base64 block removed for posting>>
--b1_fb853b08fa1f1a9c355fd4498e5f2374--
ssevennm
Post by ssevennm » 2005-06-24 23:11
Well, as you probably already know, the code that's doing this is in IMAPFetch::_GetPartStructure(). Not having a windows development enviornment at my disposal, I hesitate to suggest a fix, though it looks like a NIL is hardcoded and a Content-ID isn't being written. Any change you could look at this?
      sResult += "(";
      sResult += "\"" + sMainType + "\"";
      sResult += " \"" + sSubType + "\"";
      sResult += " " + sBodyParams ;
      sResult += " NIL";  // Content-ID ???
      if (sSubject.IsEmpty())
         sResult += " NIL";
      else
         sResult += " \"" + sSubject + "\"";
      if (sEncoding.IsEmpty())
         sResult += " NIL";
      else
         sResult += " \"" + sEncoding + "\"";
      sResult += " " + sSize;
Thanks.
Post by martin » 2005-06-26 21:34
I think I have fixed this now, but I'm not entirely sure. The bodystructure part of the RFC is probably the most confusing part and it looks like I've misunderstood several parts of it. :-\
I would appreciate if you could forward the email to martin@hmailserver.com so that I can test with the "correct" data. :-\
ssevennm
Post by ssevennm » 2005-06-27 03:33
I read it too. It is pretty ugly.
I'll send you the file right away.
Thanks.
Post by martin » 2005-06-27 20:42
In your email to me, you write:
Here's what I think we SHOULD get:
BODYSTRUCTURE ((("TEXT" "PLAIN" ("CHARSET" "US-ASCII") NIL NIL "8bit"
153 7)("TEXT" "HTML" ("CHARSET" "US-ASCII") NIL NIL "8bit" 220 12)
"ALTERNATIVE" ("BOUNDARY" "b2_fb853b08fa1f1a9c355fd4498e5f2374") NIL
NIL)("APPLICATION" "OCTET-STREAM" ("NAME" "logo.jpg") "<logo.jpg>"
NIL "base64" 5696 NIL ("INLINE" ("FILENAME" "logo.jpg")))
"RELATED" ("BOUNDARY" "b1_fb853b08fa1f1a9c355fd4498e5f2374") NIL NIL)
In the example file you attached, the content-id was <logo_cid>. So I assume that in your bodystructure above, it should be "<logo_cid>" and not "<logo.jpg>", right?
I've modified the source so that the output is
BODYSTRUCTURE ((("TEXT" "PLAIN" ("CHARSET" "US-ASCII") NIL NIL "8bit" 153 7)("TEXT" "HTML" ("CHARSET" "US-ASCII") NIL NIL "8bit" 220 12) "ALTERNATIVE" ("BOUNDARY" "b2_fb853b08fa1f1a9c355fd4498e5f2374") NIL NIL)("APPLICATION" "OCTET-STREAM" ("NAME" "logo.jpg") "<logo_cid>" NIL "base64" 5696 NIL ("inline" ("FILENAME" "logo.jpg"))) "RELATED" ("BOUNDARY" "b1_fb853b08fa1f1a9c355fd4498e5f2374") NIL NIL))
Both the Content-ID and the Content-Disposition is now read from the MIME-part instead of being hardcoded... I've tested it with SquirrelMail 1.4.4, 1.5.0 and 1.5.1 and it works fine in those versions.
http://dev.hmailserver.com/hMailServer- ... ld-118.exe
Huge thanks for pointing out this error. This is probably the highest-quality bug report so far. :)
ssevennm
Post by ssevennm » 2005-06-27 20:49
You're absolutely correct. I did mean <logo_cid> and not <logo.jpg>. That would have been horrible if I had you fix the bug incorrectly. :wink:
I try to make it as painless as possible to fix the bugs, so you might be tempted to just go and fix them right away. And so far, you haven't let us down.
Thank for the quick turn around. I'll test it right away and let you know of the results.
FAWTS
Post by FAWTS » 2005-06-27 23:16
It works perfectly, congratulation all of you!!!!!! And thank you very much!!!
ssevennm
Post by ssevennm » 2005-06-28 00:01
I have also confirmed that the BODYSTRUCTURE is including the Content-ID and that images in HTML mail images referenced by cid are showing.
Good job, Martin.
I think I might have to make a donation now. :!:
Post by martin » 2005-06-28 22:12
So I create the bugs, you find them I fix them, you donate. Sounds like a good deal to me. ;-)
Reporting stuff like this is donation enough .. but of course I don't mind a couple of $ as well. :)
ssevennm
Post by ssevennm » 2005-06-28 22:18
I like (and appreciate) the timeliness of your fixes, that's all.
Post by martin » 2005-06-28 22:54
May I ask what you are using the server for?
ssevennm
Post by ssevennm » 2005-06-28 22:56
You may, I'll PM you details.
