Warning should be added in status (Auto Ban)
Post by ^DooM^ » 2010-04-19 13:21
Currently the only way to know if a range is auto banned is if you happen to check the IP ranges. There should be a warning on the status panel if there are IP ranges currently auto banned and what IP is banned.
Slug
Re: Warning should be added in status (Auto Ban)
Post by Slug » 2010-04-19 14:00
I think just a warning, if an IP is banned and you want to know you can go and look .. as having 20 IP's on the status panel might be a bit much.
Michael
Post by ^DooM^ » 2010-04-19 14:44
Perhaps instead of listing each one then just count how many ranges are banned and put a number up. If the number is high then it would indicate you are getting hammered.
Slug
Post by Slug » 2010-04-19 14:46
Yeap, Ill go with that .
Post by mattg » 2010-04-20 01:52
I sit pretty constantly between five and ten autobanned ranges and have since the day I first updated to the version that included the autoban , with one domain.
It has got to be saving my server heaps of work I reckon.
Oh, yeah, And I like the idea.
westdam
Post by westdam » 2010-04-20 14:55
what about warning if localhost is autoban?
Post by ^DooM^ » 2010-04-20 16:13
Yeah that would be useful as a separate warning.
Post by ^DooM^ » 2010-05-06 17:17
Diagnostics should also show if any ranges are currently banned.
Post by martin » 2010-05-06 18:44
I've noted these things...
Post by ^DooM^ » 2010-05-06 19:34
Thankyou :)
Post by martin » 2010-05-23 21:55
This has been added both under Status and to the diagnostic tests for version 5.4.
A very basic warning if localhost is banned and an informational message if other hosts are banned.
Post by ^DooM^ » 2010-05-23 23:57
Excellent :)
westdam
Post by westdam » 2010-05-24 08:40
thanks martin!!
