Check IP-Ranges in diagnostics...
Rainer
Post by Rainer » 2010-03-22 09:37
Hello, check IP-Ranges in diagnostics to avoid overlapping of these.
Kind regards :)
Rainer Noa
Re: Check IP-Ranges in diagnostics...
Post by mattg » 2010-03-22 15:19
Good idea!!
Post by martin » 2010-03-23 20:08
But overlapping of IP ranges is normal and in many cases not an error. I mean, the My computer IP range overlaps the Internet IP range?
Post by ^DooM^ » 2010-03-23 20:13
True however it would be useful for non default ranges to perhaps throw a caution up as possible issue.
Post by martin » 2010-03-23 20:28
Yes, maybe. Maybe you have an IP range for 192.168.0.1-192.168.0.255 with some permissions, and then a specific IP range for 192.168.0.10 (where the web server may run). There's many cases where it's a good idea to have overlapping IP ranges. So warning people in these cases might cause confusion? Maybe it's a good idea if the warning message is clear enough...
Post by ^DooM^ » 2010-03-23 20:31
You could make it smart based on priority
If priority is higher and falls inside a lower priority range then that would assume a correct entry however if priority is lower or same then throw up a warning?
Post by martin » 2010-03-23 21:43
That is true though. So the diagnostics test should check for IP ranges not being used.
Post by ^DooM^ » 2010-03-23 22:11
Yes i think that's probably all you can check for realistically.
Post by mattg » 2010-03-24 02:03
I was thinking that if a summary of the IP ranges is included in the diagnostics, we may just get some extra info to help solve some of the issues, but you are correct, if you call that 'diagnostics', you actually need to check for something that is incorrect....
Perhaps the copy to clipboard button can just add some summary text, in preparation for posting to the forum, or sending to a paid tech for assistance...
Rainer
Post by Rainer » 2010-03-24 08:29
Hello, if a IP is overlapping with another IP in another rule, the check should say which rule it is and the priority of the rule.
Kind regards :)
Rainer Noa
Post by ^DooM^ » 2010-03-24 10:34
Rainer, All IP ranges overlap though.
