There's a new build available:
http://dev.hmailserver.com/hMailServer-4.0-Build-99.exe
Changes since the previous build:
* IMAP: BODY[HEADER] no longer touches the contents of the header fields. This should solve problem that Japanese characters not encoded properly.
* IMAP: FETCH command now supports partial fetches. I have not found a single client that uses this, but anyway... Might be used by hand-held devices and other clients that assumes a slow network connection. (It gives the client an option to download half an email.)
* Antivirus: hMailServer now uses the --tempdir command line option when running ClamScan. This should solve the "Return value 50" problem a couple of users have reported.
hMailServer 4.0 - Build 99 (Alpha)
hie martin,
i have some problems whith this build and build 98 (i have upgraded from build 91 to 98 first and later to 99)
i have upgraded mysql too (4.1.11)...
the problem occur when i try to open admin (GUI), i receive a box whith a COM error "mysql: can't connect to mysql server on 'localhost' 10061", when i press OK i receive:
"run-time error '91':
object variable or blockvariable not set"
BUT i have all acess in outlook via IMAP!
i have another problem whith 99 build (i don't see that on 98).
when i receive some new mails in some folder (IMAP using outlook express) when i goo to the folder the new mail milagrosily turn all new mails "read", but this is random!
can u help me ??
thanks
PS: here he is the error log:
"ERROR" 3012 "2005-04-13 03:37:59.190" "Source: MySQLConnection::Open, Code: HM10050, Description: Open(select messageid, messagefrom, messageaccountid, messagerecipients, messagetype, messagefilename, messagesize, messagerecipientsparsed, messagecurnooftries, messageflagseen, messagecreatetime, messageflagflagged, messageflagdraft, messageflaganswered, messageflagrecent from hm_messages WHERE messagetype = 1 AND (messagenexttrytime <= CONCAT(CURDATE(), ' ', CURTIME())) and messagelocked = 0 order by messageid asc) failed. Error: Lost connection to MySQL server during query"
"ERROR" 1592 "2005-04-13 09:29:01.689" "Source: MySQLConnection::Connect, Code: HM10048, Description: Error when connecting to database. Can't connect to MySQL server on 'localhost' (10061) Run hMail Administrator and check your database settings."
"ERROR" 3324 "2005-04-13 09:35:09.167" "Source: MySQLConnection::Open, Code: HM10050, Description: Open(select messageid, messagefrom, messageaccountid, messagerecipients, messagetype, messagefilename, messagesize, messagerecipientsparsed, messagecurnooftries, messageflagseen, messagecreatetime, messageflagflagged, messageflagdraft, messageflaganswered, messageflagrecent from hm_messages WHERE messagetype = 1 AND (messagenexttrytime <= CONCAT(CURDATE(), ' ', CURTIME())) and messagelocked = 0 order by messageid asc) failed. Error: Lost connection to MySQL server during query"
"ERROR" 3336 "2005-04-13 09:35:10.148" "Source: MySQLConnection::Open, Code: HM10050, Description: Open(select * from hm_fetchaccounts WHERE (fanexttry <= CONCAT(CURDATE(), ' ', CURTIME())) and falocked = 0 and faactive = 1 order by faid asc) failed. Error: Can't connect to MySQL server on 'localhost' (10061)"
"ERROR" 1532 "2005-04-13 09:35:58.783" "Source: MySQLConnection::Connect, Code: HM10048, Description: Error when connecting to database. Can't connect to MySQL server on 'localhost' (10061) Run hMail Administrator and check your database settings."
"ERROR" 1620 "2005-04-13 09:37:34.010" "Source: MySQLConnection::Connect, Code: HM10048, Description: Error when connecting to database. Can't connect to MySQL server on 'localhost' (10061) Run hMail Administrator and check your database settings."
can u help me ??
thanks
