decoded filename in BODYSTRUCTURE
alec
Post by alec » 2009-06-16 10:35
I'm the Roundcube Webmail developer. One of our users requested issue which is related to hMailServer's BODYSTRUCTURE reply. For message part headers:
Content-Type: application/x-zip-compressed; name="=?iso-8859-1?B?beT2LnppcA==?="
server returns:
("APPLICATION" "X-ZIP-COMPRESSED" ("NAME" "mäö.zip")
The name is decoded and converted to Unicode. The problem is because Roundcube converts returned name again from iso-8859-1 (it's message charset) to unicode and filename is displayed wrong. More info here: http://trac.roundcube.net/ticket/1485920.
My question: is this described in any RFC that decoded parameter value must/should/can be converted to Unicode?
Re: decoded filename in BODYSTRUCTURE
Post by martin » 2009-06-16 19:07
No, this is very much a real bug, and a fairly serious one.
It's the same bug which caused a similar problem reported in your forum:
http://trac.roundcube.net/ticket/1484969#comment:17
It was fixed in hMailServer 5.2, build 348. This build is currently alpha. A beta build will be up on the download page soon.
(I added your example above/below to the hMailServer automated test suite so that it's confirmed to continue work properly before every new build.)
