hmailserver_changepass: Failed to create COM object `hCOM.Ba
Daikoku
Post by Daikoku » 2005-03-14 16:37
I'm getting this error when trying to use the hmailserver_changepass plugin. Compatibility plugin is installed:
Fatal error: Uncaught exception 'com_exception' with message 'Failed to create COM object `hCOM.BaseApp': Invalid syntax ' in C:\Inetpub\wwwroot\Webmail\plugins\hmailserver_changepass\options.php:284 Stack trace: #0 C:\Inetpub\wwwroot\Webmail\plugins\hmailserver_changepass\options.php(284): com->com('hCOM.BaseApp') #1 C:\Inetpub\wwwroot\Webmail\plugins\hmailserver_changepass\options.php(244): hmailserver_changepass_go('xxx') #2 C:\Inetpub\wwwroot\Webmail\plugins\hmailserver_changepass\options.php(91): hmailserver_changepass_check() #3 {main} thrown in C:\Inetpub\wwwroot\Webmail\plugins\hmailserver_changepass\options.php on line 284
Anybody knows what's wrong here?
Post by martin » 2005-03-14 23:54
Build 90 includes new plugins that works with 4.0. The plugins that came with build 89 used the hMailServer 3.4 typelibrary which isn't included with 4.0.
Daikoku
Post by Daikoku » 2005-03-15 00:53
works now ;)
Keep up the good work!
Edit: Autoresponder works also
zachary.litzinger
Re: hmailserver_changepass: Failed to create COM object `hCOM.Ba
Post by zachary.litzinger » 2017-06-29 17:04
I'm also getting this error with the following code:
function hcom_account_add($user, $domainid, $maxsize, $pass) {
$obBaseApp = new COM("hCOM.BaseApp");
$obBaseApp->Connect();
$obDomain = $obBaseApp->Domains->ItemByDBID($domainid);
$obAccounts = $obDomain->Accounts();
$obAccount = $obAccounts->Add();
$obAccount->Address = $user . "@" . $obDomain->Name;
$obAccount->Password = $imap_pass;
$obAccount->Active = 1;
$obAccount->MaxSize = $maxsize;
$obAccount->Save();
What am I doing wrong?
Post by mattg » 2017-06-29 17:48
whoa....
12 year old thread (and still not a record here)
I extremely doubt that you have the SAME issue.
Please start a new thread as per forum rules...
Is this an issue with the PHPWebadmin or are you trying to build and getting errors?
Which version of hMailserver
PLEASE ANSWER IN THE NEW THREAD. DO not add to this thread...
