hMailServer 5.1, build 338 (Beta)
Post by martin » 2009-03-29 19:26
A new hMailServer 5.1 beta is available:
http://download.hmailserver.com/hMailSe ... 1-B338.exe
  • Added a limit so that hMailServer never processes more than five DKIM-Signature headers in a single email message (to prevent different types of abuse).
  • Administrator: The numbers on the Status page is now refreshed automatically.
  • Installation: The installation program now stops if the user is using an old version of the internal MySQL database and tries to upgrade to v5 before first installing the latest v4-build.
  • Installation: The installation program now stops if a user is using v4 with the internal database, uninstalls hMailServer (and MySQL) and then upgrades to version 5. A user cannot do this, since he will then not have any MySQL installation.
  • Other: OpenSSL has been upgraded to 0.9.8k.
  • Other: Data Directory Synchronizer has been added to the hMailServer group in the Start menu.
  • POP3: When a user logs on, any message which has been marked by deletion by his IMAP client but not been deleted will have it's \Deleted flag removed. This is to prevent issues for users who are using both POP3 and IMAP to access the same mailbox.
PeterK2003
Re: hMailServer 5.1, build 338 (Beta)
Post by PeterK2003 » 2009-04-03 21:23
Any ETA on the final version? I am trying to decide if i want to upgrade to the beta or wait for the final version.
minsik
Post by minsik » 2009-04-04 04:35
well done.
In status. start logging it sometimes hangs loading what appears to be huge log. if press clear first then start logging is ok.
possible if left running its not cycle cleaning log file out?
Windows XP
ASSP - front end SPam killer
bazporter
Post by bazporter » 2009-04-04 15:32
minsik wrote: In status. start logging it sometimes hangs loading what appears to be huge log. if press clear first then start logging is ok.
I'm seeing this too. CPU utilisation shoots to between 95%-98% and have to kill the hMailAdmin process in Task Manager.
Regards
Barry
Post by martin » 2009-04-05 12:47
Thanks. Will be fixed in the next build. Which hopefully will be the last beta.
Uzi1
Post by Uzi1 » 2009-04-05 14:02
martin wrote:[*] Installation: The installation program now stops if a user is using v4 with the internal database, uninstalls hMailServer (and MySQL) and then upgrades to version 5. A user cannot do this, since he will then not have any MySQL installation.
Somehow I feel stupid because I don't get this one. If I upgraded from latest 4 with a MySQL to 5.0 (keeping MySQL), will installation of 5.1 delete MySQL and install MSSQL as well?
Uwe
Post by martin » 2009-04-05 14:16
I agree it's somewhat ambiguous.
Better put:
Installation: If a user is using v4 with the internal database, uninstalls hMailServer (and MySQL) and then upgrades to version 5, the hMailServer installation program will stop. A user cannot do this, since he will then not have any MySQL installation.
The hMailServer installation program won't uninstall MySQL. What I meant was that if the *user* uninstalls hMailServer/MySQL prior to v5, the installation will stop.
