5.1b333 hangs long time on status- show logging.
minsik
Post by minsik » 2009-03-11 12:38
Martin, 5.1b333 working great but when opened the status, show logs (in hmailserver administrator) it appeared to use 100%cpu, hanging for about a 2 minute period, then showed the log.
last log was only 96k and in the directory only about 8 logs and all v small.
Just reporting to you.
thanks for magnificent work.
Minsik
Ok b334 seem ok and did not have any problem starting the "show logs".
Yes the admin centre does open very speedy. Love your work!
Windows XP
ASSP - front end SPam killer
