New build available:
http://dev.hmailserver.com/hMailServer-4.0-Build-86.exe
Changes since previous build:
* When moving a message to an IMAP folder, it is now possible the message to sub folders. More information on the documentation page.
* If a database error occurs when executing a select-statement, hMailServer could in previous versions hang and try to read from the recordset in an endless loop, eventhough it did not contain any data. This is now fixed.
* The server should now work on NT4.
hMailServer 4.0 - Build 86 (Alpha)
Dear Martin,
I've downloaded this version and it works propertly except at reboot, because the hMailServer service don't start automaticaly.
Event Viewer reported an timeout for response from service...
I tryed it N times...
I'm using Windows 2000 Server PT-BR With Service pack 4
hMailServer v4.0 B86 with internal MySQL
Regards,
Edward Firmo
Regards,
Edward Firmo
if u serach the forum... but in you instalation directory you have a "addons", in that folder u will find another folder "Service dependencies", just a ckick on "MySQL Internal.reg" and voaláedwardtfn wrote:Dear Martin,
Regards,
Edward Firmo
Which of the .reg files did you run?
Open up the the propertes for Control Panel->Administrative tools->Services->hMailServer. Then click on "Dependices". Are there any services in the list?
What's the value of the registry key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\hMailServer\hMailServerMySQL
What's the exact error message in the event viewer?
