Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 46 posts ]
Author Message
 Post subject: Error 530 SMTP authentication is required
PostPosted: 2007-03-12 07:19
This happens on evey account I make using hMailserver version 4.3.1-B253
I have tried everything and still unable to recieve email via mail.bqwik.com using hailserver. I have turned off authentication for SMTP still nothing. I went to DnsStuff and got this error:
ERROR: One or more of your mailservers does not accept mail to postmaster@bqwik.com. Mailservers are required (RFC822 6.3, RFC1123 5.2.7, and RFC2821 4.5.1) to accept mail to postmaster.
mail.bqwik.com's postmaster response:
>>> RCPT TO:<postmaster@bqwik.com>
<<< 530 SMTP authentication is required.
I just don't understand this it is as if I have not turned off SMTP authentication yet I know I have.
I have another email server running exchange 2003 and it has no SMTP problems using the same ISP network connection. Port 25 is open.
Can anyone help please.
Top
 Profile
 Post subject:
PostPosted: 2007-03-12 10:33
Have you spelt your domain name correctly?
Have you setup the postmaster account?
Is this a main or a backup server?
Top
 Profile
PostPosted: 2007-03-12 10:58
Yes it is a main mail server
Yes I have a postmaster account
Yes domain name is correct
Top
 Profile
 Post subject:
PostPosted: 2007-03-12 13:35
How have you done that? Looks to me like you haven't done it the right way since it's apparently still turned on. :)
Top
 Profile
 Post subject: Not Getting email
PostPosted: 2007-03-13 07:57
hMailserver settings
Domains
Catch-all-address
incorrect@anyone.com
Names: none
No Rules
Domain anyone.com
Accounts:
me@anyone.com
Accouht: me
Password:1234
No Alias
No Distribution list
Settings
SMTP
Generasl Tab
Welcome message set
Max Message Size 20MB
Delivery of email Tab
Number of retires 4
Minutes between 60
Host name: anyone.com
SMTP Relayer
mail.anyone.com port 25
No Server authentication set
RFC Compliance tab
All boxes checked
Advanced tab
Bind to local IP address 12.205.67.145 (Example only)
Other:
Use database delivery log box checked
Routes
Name
anyone.com
Target MTP Host:
mail.anyone.com
anyone.com
General Tab
Domain
anyone.com
Target MTP Host:
mail.anyone.com
Local Domain checked
POP3
Minimum Numbersof simultaneous connections
15
Welcome Message correct
IMAP is disabled
SPAM protection
All services are active
Antivirus
usine external virus checker
Return value is 0
TCP/IP Port
SMTP 25
POP# 110
IMAP 143
Advanced
Settings
default domain
anyone.com
Multihoming
All TCP/IP addresses
IP Ranges
My Computer
127.0.0.1 to 127.0.0.1
Priority 15
Allow Connections
SMTP
POP3
Require Authentication for Deliveries "all unchecked"
Other
Spam protection box checked
Allow Deliveries from all boxes checked except last one External to External
Internet
12.205.67.145 to 12.205.67.145
Priority 10
Allow Connections
SMTP
POP3
Other
Mirro
Not set
Performance
Active box checked
Server messages
As is on installatiion
Utilities
Backup is setup
Server Send out is not set up
Outlook Express Client setup
Accounts
Accounts:
me@anyone.com
Servers
SMTP: mail.anyone.com
POP3 mail.anyone.com
Account name: me
Passwors as loaded in hmailserver account
My Server requires authentication box is checked
and above account info set.
That is it but I get not incomming email and my out going email is sent but does seem to arrive.
Server OS is Windows 2000 Advanced Server (Not running Actiive Directory)
Service Pack 4
hMailserver Version in use: hMailServer-4.3.1-B253
DNS Report.com
Shows it is setup correctly to send and recieve email yet I get niether.
Except when I do an actual email test on Dnsstuff.com I get this back mressage:
Step 1: Try connecting to the following mailserver:
mail.anyone.com. - 12.205.67.145
Step 2: If still unsuccessful, queue the E-mail for later delivery.
Trying to connect to all mailservers:
mail.anyone.com. - 12.205.67.145 [Could not connect: Got an unknown RCPT TO response: 451 Please try again later.
NOTE: This tool does NOT attempt to determine if an E-mail address exists!
______________________________________________________________
In hMailserber Admin
The Logging Tab
When I send a test email this is the type of info it says:
"TCPIP" 1676 "2007-03-12 22:18:34.980" "Created accept socket 1628 on listening socket 1332"
"DEBUG" 1676 "2007-03-12 22:18:34.980" "Socket::Socket(ID: 808)"
"DEBUG" 1676 "2007-03-12 22:18:34.980" "TransparentTransmissionBuffer::Initialize()"
"POP3D" 1676 808 "2007-03-12 22:18:35.011" "12.205.67.145" "SENT: +OK mail.bqwik.com ESMTP MAIL Service, Version: 4.3.1-B253 ready"
"POP3D" 1676 808 "2007-03-12 22:18:35.011" "12.205.67.145" "RECEIVED: USER rb@bqwik.com"
"POP3D" 1676 808 "2007-03-12 22:18:35.011" "12.205.67.145" "SENT: +OK Send your password"
"POP3D" 1676 808 "2007-03-12 22:18:35.011" "12.205.67.145" "RECEIVED: PASS ***"
"POP3D" 1676 808 "2007-03-12 22:18:35.027" "12.205.67.145" "SENT: +OK Mailbox locked and ready"
"POP3D" 1676 808 "2007-03-12 22:18:35.027" "12.205.67.145" "RECEIVED: STAT"
"POP3D" 1676 808 "2007-03-12 22:18:35.027" "12.205.67.145" "SENT: +OK 0 0"
"POP3D" 1676 808 "2007-03-12 22:18:35.027" "12.205.67.145" "RECEIVED: QUIT"
"POP3D" 1676 808 "2007-03-12 22:18:35.042" "12.205.67.145" "SENT: +OK POP3 server saying goodbye..."
Note ALL I Addresses are false for privacy issues the inserted IPs are just for example only.
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 19:16
I just run DNSReport and it now reported All of your mailservers accept mail to postmaster@bqwik.com. So I guess you solved it yourself..
Top
 Profile
 Post subject: I have the exact same problem.
PostPosted: 2007-03-13 19:27
I have installed the latest build of hMailServer and cannot get email to go in or out to external addresses. I can only send email to myself.
ports all check out. I am running hMailServer on another machine and it works fine. I have compared all settings and I am at a loss. I have SMTP authorization on, but I am supplying the correct credentials.
Here is a short log...
"TCPIP" 6060 "2007-03-13 10:16:50.426" "Created accept socket 732 on listening socket 1196"
"DEBUG" 6060 "2007-03-13 10:16:50.426" "Socket::Socket(ID: 29)"
"SMTPD" 6060 29 "2007-03-13 10:16:50.426" "67.41.76.33" "SENT: 220 ServerName.com Email Server"
"SMTPD" 6060 29 "2007-03-13 10:16:50.489" "67.41.76.33" "RECEIVED: EHLO CT3916"
"SMTPD" 6060 29 "2007-03-13 10:16:50.489" "67.41.76.33" "SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN PLAIN"
"SMTPD" 6060 29 "2007-03-13 10:16:50.535" "67.41.76.33" "RECEIVED: MAIL FROM: <tank@InsideDomain.com>"
"SMTPD" 6060 29 "2007-03-13 10:16:50.535" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 29 "2007-03-13 10:16:50.598" "67.41.76.33" "RECEIVED: RCPT TO: <phillip@outsidedomain.com>"
"SMTPD" 6060 29 "2007-03-13 10:16:50.598" "67.41.76.33" "SENT: 530 SMTP authentication is required."
"DEBUG" 6060 "2007-03-13 10:16:50.598" "AWStats::LogDeliveryFailure"
"SMTPD" 6060 29 "2007-03-13 10:16:50.645" "67.41.76.33" "RECEIVED: QUIT"
"DEBUG" 6060 "2007-03-13 10:16:50.645" "PersistentMessage::DeleteFile()"
"DEBUG" 6060 "2007-03-13 10:16:50.645" "PersistentMessage::~DeleteFile() - E3"
"SMTPD" 6060 29 "2007-03-13 10:16:50.645" "67.41.76.33" "SENT: 221 goodbye"
"TCPIP" 6060 "2007-03-13 10:16:50.645" "Disconnecting socket 1568 for session 29"
"DEBUG" 6060 "2007-03-13 10:16:50.645" "Socket::~Socket(ID: 29)"
"TCPIP" 6060 "2007-03-13 10:16:50.723" "Created accept socket 1568 on listening socket 1500"
"DEBUG" 6060 "2007-03-13 10:16:50.723" "Socket::Socket(ID: 30)"
"IMAPD" 6060 30 "2007-03-13 10:16:50.723" "67.41.76.33" "SENT: * OK ServerName.com IMAP4 Server!"
"IMAPD" 6060 30 "2007-03-13 10:16:50.770" "67.41.76.33" "RECEIVED: 4t22 CAPABILITY"
"IMAPD" 6060 30 "2007-03-13 10:16:50.770" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]4t22 OK CAPABILITY completed"
"IMAPD" 6060 30 "2007-03-13 10:16:50.817" "67.41.76.33" "RECEIVED: asx0 LOGIN "tank@InsideDomain.com" ***"
"IMAPD" 6060 30 "2007-03-13 10:16:50.817" "67.41.76.33" "SENT: asx0 OK LOGIN completed"
"IMAPD" 6060 30 "2007-03-13 10:16:50.879" "67.41.76.33" "RECEIVED: qq4a IDLE"
"IMAPD" 6060 30 "2007-03-13 10:16:50.879" "67.41.76.33" "SENT: + idling"
"IMAPD" 6060 30 "2007-03-13 10:16:50.926" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 6060 30 "2007-03-13 10:16:50.942" "67.41.76.33" "SENT: qq4a OK IDLE terminated"
"IMAPD" 6060 30 "2007-03-13 10:16:50.989" "67.41.76.33" "RECEIVED: x9p3 STATUS "Drafts" (MESSAGES UNSEEN)"
"IMAPD" 6060 30 "2007-03-13 10:16:50.989" "67.41.76.33" "SENT: * STATUS "Drafts" (MESSAGES 0 UNSEEN 0)[nl]x9p3 OK Status completed"
"IMAPD" 6060 30 "2007-03-13 10:16:51.035" "67.41.76.33" "RECEIVED: 68g3 IDLE"
"IMAPD" 6060 30 "2007-03-13 10:16:51.035" "67.41.76.33" "SENT: + idling"
"IMAPD" 6060 30 "2007-03-13 10:16:51.082" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 6060 30 "2007-03-13 10:16:51.082" "67.41.76.33" "SENT: 68g3 OK IDLE terminated"
"IMAPD" 6060 30 "2007-03-13 10:16:51.129" "67.41.76.33" "RECEIVED: q99w STATUS "INBOX" (MESSAGES UNSEEN)"
"IMAPD" 6060 30 "2007-03-13 10:16:51.129" "67.41.76.33" "SENT: * STATUS "INBOX" (MESSAGES 1 UNSEEN 1)[nl]q99w OK Status completed"
"IMAPD" 6060 30 "2007-03-13 10:16:51.176" "67.41.76.33" "RECEIVED: xpjo IDLE"
"IMAPD" 6060 30 "2007-03-13 10:16:51.176" "67.41.76.33" "SENT: + idling"
"IMAPD" 6060 30 "2007-03-13 10:16:51.239" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 6060 30 "2007-03-13 10:16:51.239" "67.41.76.33" "SENT: xpjo OK IDLE terminated"
"IMAPD" 6060 30 "2007-03-13 10:16:51.285" "67.41.76.33" "RECEIVED: lmtj STATUS "Sent Items" (MESSAGES UNSEEN)"
"IMAPD" 6060 30 "2007-03-13 10:16:51.285" "67.41.76.33" "SENT: * STATUS "Sent Items" (MESSAGES 1 UNSEEN 0)[nl]lmtj OK Status completed"
"IMAPD" 6060 30 "2007-03-13 10:16:51.379" "67.41.76.33" "RECEIVED: bhz9 IDLE"
"IMAPD" 6060 30 "2007-03-13 10:16:51.395" "67.41.76.33" "SENT: + idling"
"TCPIP" 6060 "2007-03-13 10:16:51.395" "Disconnecting socket 1296 for session 30"
"IMAPD" 6060 30 "2007-03-13 10:16:51.395" "67.41.76.33" "SENT: bhz9 OK IDLE terminated"
"TCPIP" 6060 "2007-03-13 10:16:51.395" "Aborting send of data for session 30 since client is disconnected."
"DEBUG" 6060 "2007-03-13 10:16:51.395" "Socket::~Socket(ID: 30)"
"TCPIP" 6060 "2007-03-13 10:16:51.442" "Created accept socket 1296 on listening socket 1500"
"DEBUG" 6060 "2007-03-13 10:16:51.442" "Socket::Socket(ID: 31)"
"IMAPD" 6060 31 "2007-03-13 10:16:51.442" "67.41.76.33" "SENT: * OK ServerName.com IMAP4 Server!"
"IMAPD" 6060 31 "2007-03-13 10:16:51.489" "67.41.76.33" "RECEIVED: aym0 CAPABILITY"
"IMAPD" 6060 31 "2007-03-13 10:16:51.489" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]aym0 OK CAPABILITY completed"
"IMAPD" 6060 31 "2007-03-13 10:16:51.535" "67.41.76.33" "RECEIVED: goqf LOGIN "tank@InsideDomain.com" ***"
"IMAPD" 6060 31 "2007-03-13 10:16:51.551" "67.41.76.33" "SENT: goqf OK LOGIN completed"
"IMAPD" 6060 31 "2007-03-13 10:16:51.598" "67.41.76.33" "RECEIVED: knfp IDLE"
"IMAPD" 6060 31 "2007-03-13 10:16:51.598" "67.41.76.33" "SENT: + idling"
"IMAPD" 6060 31 "2007-03-13 10:16:51.645" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 6060 31 "2007-03-13 10:16:51.645" "67.41.76.33" "SENT: knfp OK IDLE terminated"
"IMAPD" 6060 31 "2007-03-13 10:16:51.692" "67.41.76.33" "RECEIVED: x0xt SELECT "INBOX""
"IMAPD" 6060 31 "2007-03-13 10:16:51.692" "67.41.76.33" "SENT: * 1 EXISTS[nl]* 1 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 0][nl]* OK [UNSEEN 3][nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)][nl]x0xt OK [READ-WRITE] SELECT completed"
"IMAPD" 6060 31 "2007-03-13 10:16:51.754" "67.41.76.33" "RECEIVED: qeuw IDLE"
"IMAPD" 6060 31 "2007-03-13 10:16:51.754" "67.41.76.33" "SENT: + idling"
"IMAPD" 6060 31 "2007-03-13 10:16:51.801" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 6060 31 "2007-03-13 10:16:51.801" "67.41.76.33" "SENT: qeuw OK IDLE terminated"
"IMAPD" 6060 31 "2007-03-13 10:16:51.848" "67.41.76.33" "RECEIVED: yp3k UID FETCH 4:* (BODY.PEEK[HEADER.FIELDS (References X-Ref X-Priority X-MSMail-Priority X-MSOESRec Newsgroups)] ENVELOPE RFC822.SIZE UID FLAGS INTERNALDATE)"
"IMAPD" 6060 31 "2007-03-13 10:16:51.848" "67.41.76.33" "SENT: yp3k OK UID completed"
"IMAPD" 6060 31 "2007-03-13 10:16:51.895" "67.41.76.33" "RECEIVED: w576 UID FETCH 1:3 (UID FLAGS)"
"IMAPD" 6060 31 "2007-03-13 10:16:51.910" "67.41.76.33" "SENT: * 1 FETCH (UID 3 FLAGS ())"
"IMAPD" 6060 31 "2007-03-13 10:16:51.910" "67.41.76.33" "SENT: w576 OK UID completed"
"IMAPD" 6060 31 "2007-03-13 10:16:52.145" "67.41.76.33" "RECEIVED: rom7 IDLE"
"IMAPD" 6060 31 "2007-03-13 10:16:52.145" "67.41.76.33" "SENT: + idling"
"TCPIP" 6060 "2007-03-13 10:16:52.145" "Disconnecting socket 1568 for session 31"
"IMAPD" 6060 31 "2007-03-13 10:16:52.145" "67.41.76.33" "SENT: rom7 OK IDLE terminated"
"TCPIP" 6060 "2007-03-13 10:16:52.145" "Aborting send of data for session 31 since client is disconnected."
"DEBUG" 6060 "2007-03-13 10:16:52.145" "Socket::~Socket(ID: 31)"
"DEBUG" 6088 "2007-03-13 10:17:09.879" "GreyListCleanerTask::DoWork()"
"DEBUG" 6088 "2007-03-13 10:18:09.879" "TimedoutConnectionRemoverTask::DoWork()"
"DEBUG" 6088 "2007-03-13 10:19:09.879" "GreyListCleanerTask::DoWork()"
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 19:42
pblanton, please never re-use existing threads for unrelated problems. It will just cause confusion and annoy people.
You need to enable SMTP authentication in your email client when sending your message. Your client is trying to deliver the message without using SMTP authentication. If you think you have enabled SMTP authentication in your email client already, you need to read the documentation for your client and see what you have missed.
Top
 Profile
 Post subject: This is not an unrelated problem.
PostPosted: 2007-03-13 21:42
I am having the same problem as the user who started the thread, therefore this thread is the logical place for my query.
I am properly sending the smtp credentials. I have tried it with both thunderbird and outlook express. The credentials are the same ones I am using to check mail with and they work fine for that.
There is another problem unrelated to my credentials.
I'd appreciate it if you'd not reply and waste my time if you don't know the answer and just want to berate me for some imagined transgression of forum etiquette.
Top
 Profile
 Post subject: See Post subject: Not Getting email
I posted my settings, you are correct Martin it checks out ok when you run a DNSReport.
The problem I'm having now is I can't send and recieve emails yet the DNSReport says its fine.
I posted my hMailserver setting so you could see if I missed anything there or made a mistake. I don't know what else to do now.
Thank you
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 21:45
Then what happens when you try to send an email?
Have you read the troubleshooting guides on this topic?
http://www.hmailserver.com/documentatio ... es_outside
http://www.hmailserver.com/documentatio ... fic_server
Top
 Profile
 Post subject: Yes. I have been through both documents
PostPosted: 2007-03-13 21:57
I get a 530 error.
>http://www.hmailserver.com/documentation/?>page=ts_send_messages_outside
>http://www.hmailserver.com/documentation/?>page=ts_send_messages_to_specific_server
Yes, I ahve been through both documents and verified that all of those issues are as described.
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 22:14
pblanton, I wasn't asking you, I was asking tekweb. This is the reason different peoples problems should be discussed in different threads. It's not a matter of, as you call it, "imagined transgression of forum etiquette", it's a matter of being able to solve problem efficiently. If many people talk at the same time, the discussion will get confused. This just proved it. I wouldn't ask you what error you got, since I already knew it. Yet you replied to my question.
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 22:16
Martin,
He and I are having the same problem. I guess I could start another thread, but then I am positive someone would complain that there is already a thread on that topic. :?
_________________
With Regards,
Phillip H. Blanton
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 22:26
pblanton wrote:
Martin,
This post was completely pointless. If you start a new thread for your own issues you may have someone point you to another thread but no one would "complain" about having an additional thread. If necessary they can be merged at a later date and arguing semantics really doesn't get your problem fixed any quicker does it?
_________________
Top
 Profile
 Post subject:
The fact that your problem symptoms are the same doesn't mean you have the same problem. As a developer, I'm sure you know that different problems can result in the same symptom. When troubleshooting, assuming nothing is a good thing and no-one will complain if you do that. It could very well be that you're having the same problem, but assuming it is still wrong. Anyway, since this thread is alerady all messy, I guess we can just as well continue here.
The log you posted shows the following:
The problem is that your server tries to send an email without sending login credentials. After your client sent EHLO CT3916, and before it sent MAIL FROM, it should start a login procedure by sending an AUTH command - but it doesn't. If you have entered login credentials in your email client, it could be that something makes your client think that the server does not support authentication.
I'm not sure whether you entered the welcome message "ServerName.com Email Server" in your config, or whether it's something you just replaced before posting the log here. If you actually entered that welcome message in the SMTP config, you need to update it. Try adding the word ESMTP in front of the string, so it says "ESMTP ServerName.com Email Server" instead. The lack of the word ESMTP may make your client assume that hMailServer does not support authentication.
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 22:47
Mr. Doom. Thank you so much for your non-pointless helpful message. I'm sure once I try it, it will certainly solve my problem with hMailServer.
Top
 Profile
 Post subject:
PostPosted: 2007-03-13 22:49
Yadayada.., stop caring about things you consider to be pointless and focus on the problem you want to solve instead. Start of by reading my previous response to you, 10 centimeters up on your screen from this text.
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 01:01
I did that. I changed the line to read...
"ESMTP TankBonesteel.com Email Server"
I then tried to set up the email account in Outlook 2007 and I get this error on testing the settings...
"Send test e-mail message: None of the authentication methods supported by this client are supported by your server."
Lemme go get the new log... Ok the log of the Outlook test is...
"TCPIP" 2584 "2007-03-13 17:01:04.348" "Created accept socket 1656 on listening socket 1500"
"DEBUG" 2584 "2007-03-13 17:01:04.364" "Socket::Socket(ID: 117)"
"IMAPD" 2584 117 "2007-03-13 17:01:04.364" "67.41.76.33" "SENT: * OK TankBonesteel.com IMAP4 Server!"
"IMAPD" 2584 117 "2007-03-13 17:01:04.410" "67.41.76.33" "RECEIVED: eape CAPABILITY"
"IMAPD" 2584 117 "2007-03-13 17:01:04.410" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]eape OK CAPABILITY completed"
"IMAPD" 2584 117 "2007-03-13 17:01:04.457" "67.41.76.33" "RECEIVED: uc3s LOGIN "Bloot@tankbonesteel.com" ***"
"IMAPD" 2584 117 "2007-03-13 17:01:04.473" "67.41.76.33" "SENT: uc3s OK LOGIN completed"
"IMAPD" 2584 117 "2007-03-13 17:01:04.520" "67.41.76.33" "RECEIVED: t8nt IDLE"
"IMAPD" 2584 117 "2007-03-13 17:01:04.520" "67.41.76.33" "SENT: + idling"
"TCPIP" 2584 "2007-03-13 17:01:04.520" "Disconnecting socket 1568 for session 117"
"IMAPD" 2584 117 "2007-03-13 17:01:04.520" "67.41.76.33" "SENT: t8nt OK IDLE terminated"
"TCPIP" 2584 "2007-03-13 17:01:04.520" "Aborting send of data for session 117 since client is disconnected."
"DEBUG" 2584 "2007-03-13 17:01:04.520" "Socket::~Socket(ID: 117)"
"TCPIP" 6060 "2007-03-13 17:01:04.614" "Created accept socket 1568 on listening socket 1196"
"DEBUG" 6060 "2007-03-13 17:01:04.614" "Socket::Socket(ID: 118)"
"SMTPD" 6060 118 "2007-03-13 17:01:04.614" "67.41.76.33" "SENT: 220 ESMTP TankBonesteel.com Email Server"
"SMTPD" 6060 118 "2007-03-13 17:01:04.676" "67.41.76.33" "RECEIVED: EHLO CT3916"
"SMTPD" 6060 118 "2007-03-13 17:01:04.676" "67.41.76.33" "SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN PLAIN"
"SMTPD" 6060 118 "2007-03-13 17:01:04.723" "67.41.76.33" "RECEIVED: QUIT"
"SMTPD" 6060 118 "2007-03-13 17:01:04.723" "67.41.76.33" "SENT: 221 goodbye"
"TCPIP" 6060 "2007-03-13 17:01:04.723" "Disconnecting socket 1296 for session 118"
"DEBUG" 6060 "2007-03-13 17:01:04.723" "Socket::~Socket(ID: 118)"
"DEBUG" 6088 "2007-03-13 17:01:09.879" "GreyListCleanerTask::DoWork()"
Edited to remove real email address.
_________________
With Regards,
Phillip H. Blanton
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 01:43
And now some logs from an attempt to send mail to outside accounts through the TankBonesteel.com server. The outside accounts have been modified to despan the innocent, but they appear in the log as "whql22@gmail.com" and "phillip@outsidedomain.com"
"TCPIP" 6060 "2007-03-13 17:38:48.598" "Created accept socket 1664 on listening socket 1196"
"DEBUG" 6060 "2007-03-13 17:38:48.598" "Socket::Socket(ID: 119)"
"SMTPD" 6060 119 "2007-03-13 17:38:48.598" "67.41.76.33" "SENT: 220 ESMTP TankBonesteel.com Email Server"
"SMTPD" 6060 119 "2007-03-13 17:38:48.645" "67.41.76.33" "RECEIVED: EHLO CT3916"
"SMTPD" 6060 119 "2007-03-13 17:38:48.645" "67.41.76.33" "SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN PLAIN"
"SMTPD" 6060 119 "2007-03-13 17:38:48.723" "67.41.76.33" "RECEIVED: MAIL FROM: <Bloot@tankbonesteel.com>"
"SMTPD" 6060 119 "2007-03-13 17:38:48.723" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 119 "2007-03-13 17:38:48.770" "67.41.76.33" "RECEIVED: RCPT TO: <phillip@outsidedomain.com>"
"SMTPD" 6060 119 "2007-03-13 17:38:48.785" "67.41.76.33" "SENT: 530 SMTP authentication is required."
"DEBUG" 6060 "2007-03-13 17:38:48.785" "AWStats::LogDeliveryFailure"
"SMTPD" 6060 119 "2007-03-13 17:38:48.832" "67.41.76.33" "RECEIVED: RSET"
"DEBUG" 6060 "2007-03-13 17:38:48.832" "PersistentMessage::DeleteFile()"
"DEBUG" 6060 "2007-03-13 17:38:48.832" "PersistentMessage::~DeleteFile() - E3"
"SMTPD" 6060 119 "2007-03-13 17:38:48.832" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 119 "2007-03-13 17:38:48.879" "67.41.76.33" "RECEIVED: MAIL FROM: <Bloot@tankbonesteel.com>"
"SMTPD" 6060 119 "2007-03-13 17:38:48.879" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 119 "2007-03-13 17:38:48.926" "67.41.76.33" "RECEIVED: RCPT TO: <Bloot@tankbonesteel.com>"
"SMTPD" 6060 119 "2007-03-13 17:38:48.942" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 119 "2007-03-13 17:38:48.989" "67.41.76.33" "RECEIVED: RCPT TO: <whql22@gmail.com>"
"SMTPD" 6060 119 "2007-03-13 17:38:48.989" "67.41.76.33" "SENT: 530 SMTP authentication is required."
"DEBUG" 6060 "2007-03-13 17:38:48.989" "AWStats::LogDeliveryFailure"
"SMTPD" 6060 119 "2007-03-13 17:38:49.051" "67.41.76.33" "RECEIVED: QUIT"
"DEBUG" 6060 "2007-03-13 17:38:49.051" "PersistentMessage::DeleteFile()"
"DEBUG" 6060 "2007-03-13 17:38:49.051" "PersistentMessage::~DeleteFile() - E3"
"SMTPD" 6060 119 "2007-03-13 17:38:49.051" "67.41.76.33" "SENT: 221 goodbye"
"TCPIP" 6060 "2007-03-13 17:38:49.051" "Disconnecting socket 1568 for session 119"
"DEBUG" 6060 "2007-03-13 17:38:49.051" "Socket::~Socket(ID: 119)"
"TCPIP" 2584 "2007-03-13 17:38:49.332" "Created accept socket 1568 on listening socket 1500"
"DEBUG" 2584 "2007-03-13 17:38:49.332" "Socket::Socket(ID: 120)"
"IMAPD" 2584 120 "2007-03-13 17:38:49.332" "67.41.76.33" "SENT: * OK TankBonesteel.com IMAP4 Server!"
"IMAPD" 2584 120 "2007-03-13 17:38:49.426" "67.41.76.33" "RECEIVED: r1e2 CAPABILITY"
"IMAPD" 2584 120 "2007-03-13 17:38:49.426" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]r1e2 OK CAPABILITY completed"
"IMAPD" 2584 120 "2007-03-13 17:38:49.473" "67.41.76.33" "RECEIVED: k0ww LOGIN "Bloot@tankbonesteel.com" ***"
"IMAPD" 2584 120 "2007-03-13 17:38:49.473" "67.41.76.33" "SENT: k0ww OK LOGIN completed"
"IMAPD" 2584 120 "2007-03-13 17:38:49.520" "67.41.76.33" "RECEIVED: nvt8 IDLE"
"IMAPD" 2584 120 "2007-03-13 17:38:49.520" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 120 "2007-03-13 17:38:49.582" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 120 "2007-03-13 17:38:49.582" "67.41.76.33" "SENT: nvt8 OK IDLE terminated"
"IMAPD" 2584 120 "2007-03-13 17:38:49.629" "67.41.76.33" "RECEIVED: g3ya STATUS "Drafts" (MESSAGES UNSEEN)"
"IMAPD" 2584 120 "2007-03-13 17:38:49.629" "67.41.76.33" "SENT: * STATUS "Drafts" (MESSAGES 0 UNSEEN 0)[nl]g3ya OK Status completed"
"IMAPD" 2584 120 "2007-03-13 17:38:49.707" "67.41.76.33" "RECEIVED: 8tn9 IDLE"
"IMAPD" 2584 120 "2007-03-13 17:38:49.707" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 120 "2007-03-13 17:38:49.754" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 120 "2007-03-13 17:38:49.754" "67.41.76.33" "SENT: 8tn9 OK IDLE terminated"
"IMAPD" 2584 120 "2007-03-13 17:38:49.817" "67.41.76.33" "RECEIVED: 2tyj STATUS "INBOX" (MESSAGES UNSEEN)"
"IMAPD" 2584 120 "2007-03-13 17:38:49.817" "67.41.76.33" "SENT: * STATUS "INBOX" (MESSAGES 4 UNSEEN 0)[nl]2tyj OK Status completed"
"IMAPD" 2584 120 "2007-03-13 17:38:49.864" "67.41.76.33" "RECEIVED: fm9i IDLE"
"IMAPD" 2584 120 "2007-03-13 17:38:49.864" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 120 "2007-03-13 17:38:49.910" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 120 "2007-03-13 17:38:49.910" "67.41.76.33" "SENT: fm9i OK IDLE terminated"
"IMAPD" 2584 120 "2007-03-13 17:38:49.989" "67.41.76.33" "RECEIVED: l4uo STATUS "Sent Items" (MESSAGES UNSEEN)"
"IMAPD" 2584 120 "2007-03-13 17:38:49.989" "67.41.76.33" "SENT: * STATUS "Sent Items" (MESSAGES 5 UNSEEN 0)[nl]l4uo OK Status completed"
"IMAPD" 2584 120 "2007-03-13 17:38:50.035" "67.41.76.33" "RECEIVED: 64ib IDLE"
"IMAPD" 2584 120 "2007-03-13 17:38:50.035" "67.41.76.33" "SENT: + idling"
"TCPIP" 2584 "2007-03-13 17:38:50.035" "Disconnecting socket 1656 for session 120"
"IMAPD" 2584 120 "2007-03-13 17:38:50.035" "67.41.76.33" "SENT: 64ib OK IDLE terminated"
"TCPIP" 2584 "2007-03-13 17:38:50.051" "Aborting send of data for session 120 since client is disconnected."
"DEBUG" 2584 "2007-03-13 17:38:50.051" "Socket::~Socket(ID: 120)"
"TCPIP" 2584 "2007-03-13 17:38:50.114" "Created accept socket 1656 on listening socket 1500"
"DEBUG" 2584 "2007-03-13 17:38:50.114" "Socket::Socket(ID: 121)"
"IMAPD" 2584 121 "2007-03-13 17:38:50.114" "67.41.76.33" "SENT: * OK TankBonesteel.com IMAP4 Server!"
"IMAPD" 2584 121 "2007-03-13 17:38:50.160" "67.41.76.33" "RECEIVED: e5j5 CAPABILITY"
"IMAPD" 2584 121 "2007-03-13 17:38:50.160" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]e5j5 OK CAPABILITY completed"
"IMAPD" 2584 121 "2007-03-13 17:38:50.207" "67.41.76.33" "RECEIVED: lv50 LOGIN "Bloot@tankbonesteel.com" ***"
"IMAPD" 2584 121 "2007-03-13 17:38:50.223" "67.41.76.33" "SENT: lv50 OK LOGIN completed"
"IMAPD" 2584 121 "2007-03-13 17:38:50.285" "67.41.76.33" "RECEIVED: 8l2v IDLE"
"IMAPD" 2584 121 "2007-03-13 17:38:50.285" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 121 "2007-03-13 17:38:50.332" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 121 "2007-03-13 17:38:50.332" "67.41.76.33" "SENT: 8l2v OK IDLE terminated"
"IMAPD" 2584 121 "2007-03-13 17:38:50.395" "67.41.76.33" "RECEIVED: 5mw6 SELECT "INBOX""
"IMAPD" 2584 121 "2007-03-13 17:38:50.395" "67.41.76.33" "SENT: * 4 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 0][nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)][nl]5mw6 OK [READ-WRITE] SELECT completed"
"IMAPD" 2584 121 "2007-03-13 17:38:50.442" "67.41.76.33" "RECEIVED: 6ewg IDLE"
"IMAPD" 2584 121 "2007-03-13 17:38:50.442" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 121 "2007-03-13 17:38:50.489" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 121 "2007-03-13 17:38:50.504" "67.41.76.33" "SENT: 6ewg OK IDLE terminated"
"IMAPD" 2584 121 "2007-03-13 17:38:50.551" "67.41.76.33" "RECEIVED: 3ito UID FETCH 7:* (BODY.PEEK[HEADER.FIELDS (References X-Ref X-Priority X-MSMail-Priority X-MSOESRec Newsgroups)] ENVELOPE RFC822.SIZE UID FLAGS INTERNALDATE)"
"IMAPD" 2584 121 "2007-03-13 17:38:50.551" "67.41.76.33" "SENT: * 3 FETCH (UID 11 RFC822.SIZE 608 FLAGS (\Seen \Deleted) INTERNALDATE "13-Mar-2007 15:01:41 -0600" ENVELOPE ("Tue, 13 Mar 2007 15:01:41 -0600" "Undeliverable: test" (("mailer-daemon@TankBonesteel.com" NIL "mailer-daemon" "TankBonesteel.com")) (("mailer-daemon@TankBonesteel.com" NIL "mailer-daemon" "TankBonesteel.com")) (("mailer-daemon@TankBonesteel.com" NIL "mailer-daemon" "TankBonesteel.com")) (("Bloot@tankbonesteel.com" NIL "tank" "tankbonesteel.com")) NIL NIL NIL "<CB7E1E4B-2A8B-4693-BD10-173A0A18B041@TankBonesteel.com>") BODY[HEADER.FIELDS (References X-Ref X-Priority X-MSMail-Priority X-MSOESRec Newsgroups)] "")"
"IMAPD" 2584 121 "2007-03-13 17:38:50.551" "67.41.76.33" "SENT: * 4 FETCH (UID 14 RFC822.SIZE 655 FLAGS (\Seen) INTERNALDATE "13-Mar-2007 15:04:56 -0600" ENVELOPE ("Tue, 13 Mar 2007 15:04:56 -0600" "Test 2" (("Tank Bonesteel" NIL "tank" "tankbonesteel.com")) (("Tank Bonesteel" NIL "tank" "tankbonesteel.com")) (("Tank Bonesteel" NIL "tank" "tankbonesteel.com")) (("<Bloot@tankbonesteel.com>" NIL "tank" "tankbonesteel.com")) NIL NIL NIL "=?iso-8859-1?B?PDAwMjQwMWM3NjViMyQ0MGQ5Njk5MCRmMmNiZjczZkBha2Fub21pMT4=?=") BODY[HEADER.FIELDS (References X-Ref X-Priority X-MSMail-Priority X-MSOESRec Newsgroups)] {42}"
"IMAPD" 2584 121 "2007-03-13 17:38:50.551" "67.41.76.33" "SENT: )"
"IMAPD" 2584 121 "2007-03-13 17:38:50.551" "67.41.76.33" "SENT: 3ito OK UID completed"
"IMAPD" 2584 121 "2007-03-13 17:38:50.754" "67.41.76.33" "RECEIVED: qr7e UID FETCH 1:6 (UID FLAGS)"
"IMAPD" 2584 121 "2007-03-13 17:38:50.754" "67.41.76.33" "SENT: * 1 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD" 2584 121 "2007-03-13 17:38:50.754" "67.41.76.33" "SENT: * 2 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD" 2584 121 "2007-03-13 17:38:50.754" "67.41.76.33" "SENT: qr7e OK UID completed"
"IMAPD" 2584 121 "2007-03-13 17:38:50.926" "67.41.76.33" "RECEIVED: oowd IDLE"
"IMAPD" 2584 121 "2007-03-13 17:38:50.926" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 121 "2007-03-13 17:38:50.973" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 121 "2007-03-13 17:38:50.973" "67.41.76.33" "SENT: oowd OK IDLE terminated"
"IMAPD" 2584 121 "2007-03-13 17:38:51.020" "67.41.76.33" "RECEIVED: z4ms UID FETCH 11 (BODY.PEEK[] UID)"
"IMAPD" 2584 121 "2007-03-13 17:38:51.020" "67.41.76.33" "SENT: * 3 FETCH (UID 11 BODY[] {608}"
"IMAPD" 2584 121 "2007-03-13 17:38:51.020" "67.41.76.33" "SENT: )"
"IMAPD" 2584 121 "2007-03-13 17:38:51.020" "67.41.76.33" "SENT: z4ms OK UID completed"
"IMAPD" 2584 121 "2007-03-13 17:38:51.223" "67.41.76.33" "RECEIVED: xm79 IDLE"
"IMAPD" 2584 121 "2007-03-13 17:38:51.223" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 121 "2007-03-13 17:38:51.270" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 121 "2007-03-13 17:38:51.270" "67.41.76.33" "SENT: xm79 OK IDLE terminated"
"IMAPD" 2584 121 "2007-03-13 17:38:51.332" "67.41.76.33" "RECEIVED: g2zm UID FETCH 14 (BODY.PEEK[] UID)"
"IMAPD" 2584 121 "2007-03-13 17:38:51.332" "67.41.76.33" "SENT: * 4 FETCH (UID 14 BODY[] {655}"
"IMAPD" 2584 121 "2007-03-13 17:38:51.332" "67.41.76.33" "SENT: )"
"IMAPD" 2584 121 "2007-03-13 17:38:51.332" "67.41.76.33" "SENT: g2zm OK UID completed"
"IMAPD" 2584 121 "2007-03-13 17:38:51.520" "67.41.76.33" "RECEIVED: 8u9l IDLE"
"IMAPD" 2584 121 "2007-03-13 17:38:51.520" "67.41.76.33" "SENT: + idling"
"TCPIP" 2584 "2007-03-13 17:38:51.535" "Disconnecting socket 1568 for session 121"
"IMAPD" 2584 121 "2007-03-13 17:38:51.535" "67.41.76.33" "SENT: 8u9l OK IDLE terminated"
"TCPIP" 2584 "2007-03-13 17:38:51.535" "Aborting send of data for session 121 since client is disconnected."
"DEBUG" 2584 "2007-03-13 17:38:51.535" "Socket::~Socket(ID: 121)"
"TCPIP" 2584 "2007-03-13 17:38:55.754" "Created accept socket 1568 on listening socket 1500"
"DEBUG" 2584 "2007-03-13 17:38:55.754" "Socket::Socket(ID: 122)"
"IMAPD" 2584 122 "2007-03-13 17:38:55.754" "67.41.76.33" "SENT: * OK TankBonesteel.com IMAP4 Server!"
"IMAPD" 2584 122 "2007-03-13 17:38:55.801" "67.41.76.33" "RECEIVED: d3ko CAPABILITY"
"IMAPD" 2584 122 "2007-03-13 17:38:55.801" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]d3ko OK CAPABILITY completed"
"IMAPD" 2584 122 "2007-03-13 17:38:55.848" "67.41.76.33" "RECEIVED: 7zfu LOGIN "Bloot@tankbonesteel.com" ***"
"IMAPD" 2584 122 "2007-03-13 17:38:55.848" "67.41.76.33" "SENT: 7zfu OK LOGIN completed"
"IMAPD" 2584 122 "2007-03-13 17:38:55.910" "67.41.76.33" "RECEIVED: 0ag9 IDLE"
"IMAPD" 2584 122 "2007-03-13 17:38:55.910" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 122 "2007-03-13 17:38:56.114" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 122 "2007-03-13 17:38:56.114" "67.41.76.33" "SENT: 0ag9 OK IDLE terminated"
"IMAPD" 2584 122 "2007-03-13 17:38:56.160" "67.41.76.33" "RECEIVED: 7kko SELECT "INBOX""
"IMAPD" 2584 122 "2007-03-13 17:38:56.160" "67.41.76.33" "SENT: * 4 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 0][nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)][nl]7kko OK [READ-WRITE] SELECT completed"
"IMAPD" 2584 122 "2007-03-13 17:38:56.207" "67.41.76.33" "RECEIVED: gf4e IDLE"
"IMAPD" 2584 122 "2007-03-13 17:38:56.207" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 122 "2007-03-13 17:38:56.254" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 122 "2007-03-13 17:38:56.254" "67.41.76.33" "SENT: gf4e OK IDLE terminated"
"IMAPD" 2584 122 "2007-03-13 17:38:56.301" "67.41.76.33" "RECEIVED: mfdk UID FETCH 15:* (BODY.PEEK[HEADER.FIELDS (References X-Ref X-Priority X-MSMail-Priority X-MSOESRec Newsgroups)] ENVELOPE RFC822.SIZE UID FLAGS INTERNALDATE)"
"IMAPD" 2584 122 "2007-03-13 17:38:56.301" "67.41.76.33" "SENT: mfdk OK UID completed"
"IMAPD" 2584 122 "2007-03-13 17:38:56.364" "67.41.76.33" "RECEIVED: icod UID FETCH 1:14 (UID FLAGS)"
"IMAPD" 2584 122 "2007-03-13 17:38:56.364" "67.41.76.33" "SENT: * 1 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD" 2584 122 "2007-03-13 17:38:56.364" "67.41.76.33" "SENT: * 2 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD" 2584 122 "2007-03-13 17:38:56.364" "67.41.76.33" "SENT: * 3 FETCH (UID 11 FLAGS (\Seen \Deleted))"
"IMAPD" 2584 122 "2007-03-13 17:38:56.364" "67.41.76.33" "SENT: * 4 FETCH (UID 14 FLAGS (\Seen))"
"IMAPD" 2584 122 "2007-03-13 17:38:56.364" "67.41.76.33" "SENT: icod OK UID completed"
"IMAPD" 2584 122 "2007-03-13 17:38:56.551" "67.41.76.33" "RECEIVED: 25hb IDLE"
"IMAPD" 2584 122 "2007-03-13 17:38:56.551" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 122 "2007-03-13 17:39:08.176" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 122 "2007-03-13 17:39:08.176" "67.41.76.33" "SENT: 25hb OK IDLE terminated"
"IMAPD" 2584 122 "2007-03-13 17:39:08.223" "67.41.76.33" "RECEIVED: 3oha EXPUNGE"
"DEBUG" 2584 "2007-03-13 17:39:08.223" "PersistentMessage::DeleteObject()"
"DEBUG" 2584 "2007-03-13 17:39:08.223" "PersistentMessage::DeleteFile()"
"DEBUG" 2584 "2007-03-13 17:39:08.223" "PersistentMessage::~DeleteFile() - E3"
"DEBUG" 2584 "2007-03-13 17:39:08.223" "PersistentMessage::DeleteObject() - E5"
"IMAPD" 2584 122 "2007-03-13 17:39:08.285" "67.41.76.33" "SENT: * 3 EXPUNGE"
"IMAPD" 2584 122 "2007-03-13 17:39:08.285" "67.41.76.33" "SENT: 3oha OK EXPUNGE Completed"
"IMAPD" 2584 122 "2007-03-13 17:39:08.535" "67.41.76.33" "RECEIVED: 0fyw IDLE"
"IMAPD" 2584 122 "2007-03-13 17:39:08.535" "67.41.76.33" "SENT: + idling"
"DEBUG" 6088 "2007-03-13 17:39:10.145" "GreyListCleanerTask::DoWork()"
"TCPIP" 6060 "2007-03-13 17:39:12.660" "Created accept socket 1052 on listening socket 1196"
"DEBUG" 6060 "2007-03-13 17:39:12.660" "Socket::Socket(ID: 123)"
"SMTPD" 6060 123 "2007-03-13 17:39:12.660" "67.41.76.33" "SENT: 220 ESMTP TankBonesteel.com Email Server"
"SMTPD" 6060 123 "2007-03-13 17:39:12.739" "67.41.76.33" "RECEIVED: EHLO CT3916"
"SMTPD" 6060 123 "2007-03-13 17:39:12.754" "67.41.76.33" "SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN PLAIN"
"SMTPD" 6060 123 "2007-03-13 17:39:12.801" "67.41.76.33" "RECEIVED: MAIL FROM: <Bloot@tankbonesteel.com>"
"SMTPD" 6060 123 "2007-03-13 17:39:12.817" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 123 "2007-03-13 17:39:12.864" "67.41.76.33" "RECEIVED: RCPT TO: <phillip@outsidedomain.com>"
"SMTPD" 6060 123 "2007-03-13 17:39:12.864" "67.41.76.33" "SENT: 530 SMTP authentication is required."
"DEBUG" 6060 "2007-03-13 17:39:12.864" "AWStats::LogDeliveryFailure"
"SMTPD" 6060 123 "2007-03-13 17:39:12.942" "67.41.76.33" "RECEIVED: RSET"
"DEBUG" 6060 "2007-03-13 17:39:12.942" "PersistentMessage::DeleteFile()"
"DEBUG" 6060 "2007-03-13 17:39:12.942" "PersistentMessage::~DeleteFile() - E3"
"SMTPD" 6060 123 "2007-03-13 17:39:12.942" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 123 "2007-03-13 17:39:12.989" "67.41.76.33" "RECEIVED: MAIL FROM: <Bloot@tankbonesteel.com>"
"SMTPD" 6060 123 "2007-03-13 17:39:12.989" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 123 "2007-03-13 17:39:13.035" "67.41.76.33" "RECEIVED: RCPT TO: <Bloot@tankbonesteel.com>"
"SMTPD" 6060 123 "2007-03-13 17:39:13.051" "67.41.76.33" "SENT: 250 OK"
"SMTPD" 6060 123 "2007-03-13 17:39:13.114" "67.41.76.33" "RECEIVED: RCPT TO: <whql22@gmail.com>"
"SMTPD" 6060 123 "2007-03-13 17:39:13.114" "67.41.76.33" "SENT: 530 SMTP authentication is required."
"DEBUG" 6060 "2007-03-13 17:39:13.114" "AWStats::LogDeliveryFailure"
"SMTPD" 6060 123 "2007-03-13 17:39:13.317" "67.41.76.33" "RECEIVED: QUIT"
"DEBUG" 6060 "2007-03-13 17:39:13.317" "PersistentMessage::DeleteFile()"
"DEBUG" 6060 "2007-03-13 17:39:13.317" "PersistentMessage::~DeleteFile() - E3"
"SMTPD" 6060 123 "2007-03-13 17:39:13.317" "67.41.76.33" "SENT: 221 goodbye"
"TCPIP" 6060 "2007-03-13 17:39:13.317" "Disconnecting socket 1664 for session 123"
"DEBUG" 6060 "2007-03-13 17:39:13.317" "Socket::~Socket(ID: 123)"
"TCPIP" 2584 "2007-03-13 17:39:13.364" "Created accept socket 1664 on listening socket 1500"
"DEBUG" 2584 "2007-03-13 17:39:13.364" "Socket::Socket(ID: 124)"
"IMAPD" 2584 124 "2007-03-13 17:39:13.364" "67.41.76.33" "SENT: * OK TankBonesteel.com IMAP4 Server!"
"IMAPD" 2584 124 "2007-03-13 17:39:13.426" "67.41.76.33" "RECEIVED: i8vl CAPABILITY"
"IMAPD" 2584 124 "2007-03-13 17:39:13.426" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]i8vl OK CAPABILITY completed"
"IMAPD" 2584 124 "2007-03-13 17:39:13.473" "67.41.76.33" "RECEIVED: 0tlk LOGIN "Bloot@tankbonesteel.com" ***"
"IMAPD" 2584 124 "2007-03-13 17:39:13.473" "67.41.76.33" "SENT: 0tlk OK LOGIN completed"
"IMAPD" 2584 124 "2007-03-13 17:39:13.520" "67.41.76.33" "RECEIVED: 50oe IDLE"
"IMAPD" 2584 124 "2007-03-13 17:39:13.520" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 124 "2007-03-13 17:39:13.567" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 124 "2007-03-13 17:39:13.567" "67.41.76.33" "SENT: 50oe OK IDLE terminated"
"IMAPD" 2584 124 "2007-03-13 17:39:13.614" "67.41.76.33" "RECEIVED: ftaf STATUS "Drafts" (MESSAGES UNSEEN)"
"IMAPD" 2584 124 "2007-03-13 17:39:13.614" "67.41.76.33" "SENT: * STATUS "Drafts" (MESSAGES 0 UNSEEN 0)[nl]ftaf OK Status completed"
"IMAPD" 2584 124 "2007-03-13 17:39:13.754" "67.41.76.33" "RECEIVED: 77ql IDLE"
"IMAPD" 2584 124 "2007-03-13 17:39:13.754" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 124 "2007-03-13 17:39:13.848" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 124 "2007-03-13 17:39:13.848" "67.41.76.33" "SENT: 77ql OK IDLE terminated"
"IMAPD" 2584 124 "2007-03-13 17:39:13.895" "67.41.76.33" "RECEIVED: tbgx STATUS "INBOX" (MESSAGES UNSEEN)"
"IMAPD" 2584 124 "2007-03-13 17:39:13.895" "67.41.76.33" "SENT: * STATUS "INBOX" (MESSAGES 3 UNSEEN 0)[nl]tbgx OK Status completed"
"IMAPD" 2584 124 "2007-03-13 17:39:13.942" "67.41.76.33" "RECEIVED: smkz IDLE"
"IMAPD" 2584 124 "2007-03-13 17:39:13.942" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 124 "2007-03-13 17:39:13.989" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 124 "2007-03-13 17:39:13.989" "67.41.76.33" "SENT: smkz OK IDLE terminated"
"IMAPD" 2584 124 "2007-03-13 17:39:14.035" "67.41.76.33" "RECEIVED: qs9z STATUS "Sent Items" (MESSAGES UNSEEN)"
"IMAPD" 2584 124 "2007-03-13 17:39:14.035" "67.41.76.33" "SENT: * STATUS "Sent Items" (MESSAGES 5 UNSEEN 0)[nl]qs9z OK Status completed"
"IMAPD" 2584 124 "2007-03-13 17:39:14.082" "67.41.76.33" "RECEIVED: kbtb IDLE"
"IMAPD" 2584 124 "2007-03-13 17:39:14.082" "67.41.76.33" "SENT: + idling"
"TCPIP" 2584 "2007-03-13 17:39:14.082" "Disconnecting socket 1568 for session 124"
"IMAPD" 2584 124 "2007-03-13 17:39:14.098" "67.41.76.33" "SENT: kbtb OK IDLE terminated"
"TCPIP" 2584 "2007-03-13 17:39:14.098" "Aborting send of data for session 124 since client is disconnected."
"DEBUG" 2584 "2007-03-13 17:39:14.098" "Socket::~Socket(ID: 124)"
"TCPIP" 2584 "2007-03-13 17:39:14.145" "Created accept socket 1568 on listening socket 1500"
"DEBUG" 2584 "2007-03-13 17:39:14.145" "Socket::Socket(ID: 125)"
"IMAPD" 2584 125 "2007-03-13 17:39:14.145" "67.41.76.33" "SENT: * OK TankBonesteel.com IMAP4 Server!"
"IMAPD" 2584 125 "2007-03-13 17:39:14.239" "67.41.76.33" "RECEIVED: 7agl CAPABILITY"
"IMAPD" 2584 125 "2007-03-13 17:39:14.239" "67.41.76.33" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT[nl]7agl OK CAPABILITY completed"
"IMAPD" 2584 125 "2007-03-13 17:39:14.364" "67.41.76.33" "RECEIVED: agte LOGIN "Bloot@tankbonesteel.com" ***"
"IMAPD" 2584 125 "2007-03-13 17:39:14.379" "67.41.76.33" "SENT: agte OK LOGIN completed"
"IMAPD" 2584 125 "2007-03-13 17:39:14.426" "67.41.76.33" "RECEIVED: l2h3 IDLE"
"IMAPD" 2584 125 "2007-03-13 17:39:14.426" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 125 "2007-03-13 17:39:14.473" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 125 "2007-03-13 17:39:14.473" "67.41.76.33" "SENT: l2h3 OK IDLE terminated"
"IMAPD" 2584 125 "2007-03-13 17:39:14.520" "67.41.76.33" "RECEIVED: c3t6 SELECT "INBOX""
"IMAPD" 2584 125 "2007-03-13 17:39:14.535" "67.41.76.33" "SENT: * 3 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 0][nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)][nl]c3t6 OK [READ-WRITE] SELECT completed"
"IMAPD" 2584 125 "2007-03-13 17:39:14.582" "67.41.76.33" "RECEIVED: 07rp IDLE"
"IMAPD" 2584 125 "2007-03-13 17:39:14.582" "67.41.76.33" "SENT: + idling"
"IMAPD" 2584 125 "2007-03-13 17:39:14.629" "67.41.76.33" "RECEIVED: DONE"
"IMAPD" 2584 125 "2007-03-13 17:39:14.629" "67.41.76.33" "SENT: 07rp OK IDLE terminated"
"IMAPD" 2584 125 "2007-03-13 17:39:14.676" "67.41.76.33" "RECEIVED: 10hk UID FETCH 15:* (BODY.PEEK[HEADER.FIELDS (References X-Ref X-Priority X-MSMail-Priority X-MSOESRec Newsgroups)] ENVELOPE RFC822.SIZE UID FLAGS INTERNALDATE)"
"IMAPD" 2584 125 "2007-03-13 17:39:14.676" "67.41.76.33" "SENT: 10hk OK UID completed"
"IMAPD" 2584 125 "2007-03-13 17:39:14.723" "67.41.76.33" "RECEIVED: cnzk UID FETCH 1:14 (UID FLAGS)"
"IMAPD" 2584 125 "2007-03-13 17:39:14.723" "67.41.76.33" "SENT: * 1 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD" 2584 125 "2007-03-13 17:39:14.723" "67.41.76.33" "SENT: * 2 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD" 2584 125 "2007-03-13 17:39:14.723" "67.41.76.33" "SENT: * 3 FETCH (UID 14 FLAGS (\Seen))"
"IMAPD" 2584 125 "2007-03-13 17:39:14.723" "67.41.76.33" "SENT: cnzk OK UID completed"
"IMAPD" 2584 125 "2007-03-13 17:39:14.957" "67.41.76.33" "RECEIVED: vroa IDLE"
"IMAPD" 2584 125 "2007-03-13 17:39:14.973" "67.41.76.33" "SENT: + idling"
"TCPIP" 2584 "2007-03-13 17:39:14.973" "Disconnecting socket 1664 for session 125"
"IMAPD" 2584 125 "2007-03-13 17:39:14.973" "67.41.76.33" "SENT: vroa OK IDLE terminated"
"TCPIP" 2584 "2007-03-13 17:39:14.973" "Aborting send of data for session 125 since client is disconnected."
"DEBUG" 2584 "2007-03-13 17:39:14.973" "Socket::~Socket(ID: 125)"
_________________
With Regards,
Phillip H. Blanton
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 02:44
I am having a great deal of trouble getting hMailServer st up on a new machine. After metaphoricaly poking at it with a pointy stick, I have found that on the "ipRanges" settings page, Under "Require Authentication For Deliveries", in the "Internet" range (127.0.0.1 - 127.0.0.1)...
If I set "To Remote Accounts" true, then all attempts to authenticate with Thunderbird, Outlook Express and Outlook 2007, fail. Username and passwords are good, because I can check mail with them, but I get a
"The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'poit@gmail.com'. Subject 'test', Account: 'mail.tankbonesteel.com', Server: 'mail.tankbonesteel.com', Protocol: SMTP, Server Response: '530 SMTP authentication is required.', Port: 25, Secure(SSL): No, Server Error: 530, Error Number: 0x800CCC79"
If I de-select that, then I can send and receive email, but open relay tests fail when the test impersonates a user on the system.
I really want to require authentication in order to send to remote accounts, but it is causing me great pain.
I am strarting a new thread with this, more isolated issue.
Top
 Profile
 Post subject: Send Recieve email issues Tekweb
PostPosted: 2007-03-14 03:13
Thank you Martin for your guidence, pblanton has really confused this thread I'm having trouble knowing what to reply to now. :?
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 03:23
Tekweb,
Try disabling "Require Authentication For Deliveries" - "To Remote Accounts" and see if you can't send email to outside users. I'll bet you can.
Not that it will "solve" the problem, but I bet you have the same issue I do.
http://www.hmailserver.com/forum/viewtopic.php?t=8164
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 04:02
Hi Tekweb, I would suggest you follow what martin wrote in his last post to you. I've quoted what martin has said below.
Top
 Profile
 Post subject: email sends ok sends to hmailserver account do not arrive
PostPosted: 2007-03-14 06:26
:o email sends out ok, sends to hmailserver account do not arrive
Raymond I checked out the links Martin suggested I did the tests and all checks out good port 25 is open.
This is the error that comes back after sending to hmailserver account:
Recipient: <rb@bqwik.com>
Reason: SMTP authentication is required.
I have checked all authentication settings in hmailserver they are all "off" yet I still get this error when sending to hmailserver account.
I can send out to external account no problem.
Thank you pblanton I tried that still no luck
Help I still in the dark.
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 06:34
tekweb wrote:
Internet
Priority 10
The Internet IP range should be from
0.0.0.0 to 255.255.255.255
If you haven't yet, can you try changing your IP ranges back to the installation defaults?
Top
 Profile
 Post subject: It worked Inet setting change
PostPosted: 2007-03-14 07:09
Thank you Raymond,
I have change the Internet setting as you suggested
My computer are to to 127.0.0.1 to 127.0.0.5
Is that correct?
Eureaka! I just tried thos setting and it worked now able to recieve email from external accounts.
Thank you Raymond :D
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 07:16
Not quite. My Computer should be 127.0.0.1 to 127.0.0.1
I'm glad it worked :)
Top
 Profile
 Post subject: Email Now working
PostPosted: 2007-03-14 07:42
I changes my computer settings to what you said.
Reymond I've noticed that when I check the box for Greylist I don't recieve any emails is there something need setting up for that to work?
Also WebAdmin PHP I have no experience with that on a wihndows 2000 server Computer not sure exactly what needs to be done to do that.
Thank you for your help
Ron
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 07:58
No, you don't need to set anything else up. What Greylisting does is that it delays emails that are coming into your mail server. The usual hMailserver setting is to delay the attempts for 30 minutes. You can adjust it to 5 minutes if you find that delay too long. I find that setting it to 5 minutes works quite well.
http://www.hmailserver.com/documentatio ... reylisting
Most spammers use bots to send their messages and these bots generally don't attempt to resend after they have been delayed. Normal mail servers do retry after certain intervals.
If you haven't yet read the phpwebadmin installation documentation...
http://www.hmailserver.com/documentatio ... hpwebadmin
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 08:00
Thank you for all your help
I can see noe that I'm going to be using hmailserver for a long time great email server. I hope to make a donation very soon.
Thank you Raymond :)
Top
 Profile
 Post subject: Greylist updates
PostPosted: 2007-03-14 09:29
How do I update the greylist?
Thank you :shock:
Top
 Profile
 Post subject: Grey/white kist settings
PostPosted: 2007-03-14 09:50
I've noticed the when I activate the greylist I put an email address in the whitelist yet it still got bounced and didn't arrive what am I doing wrong? :(
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 10:07
I would suggest you read this documentation before stepping into the unknown... :)
You actually need to add the IP address of the sender's mail server and not the email address to the whitelist.
Top
 Profile
 Post subject: I'll readit first
PostPosted: 2007-03-14 10:14
Good idea will do that.
Thank you,
Ron 8)
Top
 Profile
 Post subject: Domain Catchall account
PostPosted: 2007-03-14 10:30
What is the catchall account used for in the Domians section,
How can it be used?
Sorry in advance if this sounds a dumb question
Thank you,
Ron :?
Top
 Profile
 Post subject:
PostPosted: 2007-03-14 10:35
If you need to know how a feature in hMailserver works, have a look at this link.
http://www.hmailserver.com/documentation/?page=overview
This link talks about the catch-all account.
http://www.hmailserver.com/documentatio ... e_catchall
Top
 Profile
 Post subject: Domain catch-all address
PostPosted: 2007-03-16 21:53
The catch-all address I'm referring to is the one that resides in Domains under the General TAB. It asks for Domain Name then just below it it asks for Catch-all address. In the help documentation it talks about adding a catch-all email address but not anything I could see on this particular Catch-all address.
Could someone please tell me how this particular Catch-all address is utilized/
Thank you. :?
Top
 Profile
 Post subject:
PostPosted: 2007-03-16 21:58
It is possible to specify an email address that receives all emails being sent to non-existent addresses on your domain. For example, you may have sales@mydomain.com, webmaster@mydomain.com and support@mydomain.com as existing accounts. But there's a risk that someone might misspell an email address, writing sails@mydomain.com instead of sales@mydomain.com.
The solution is to specify an account - either a previously existing one, or one created for the purpose - to be the catch-all account. All email sent to non-existent addresses on the domain will then be delivered to the catch-all account.
What part of this was unclear? :)
Top
 Profile
 Post subject: Catch-all
PostPosted: 2007-03-16 22:06
Hi Martin,
hMailserver is great thank you for your efforts, you did some great work on this and I'm currently testing it. It is proves as good as it currently does I'm going to get rid of Exchange 2003
The explanation you gave is clear and nmakes sense. However, Under the Domain "General TAB" it allows you to put the address inncorrect@anyone.com as the catchall address. So, that being set what happens to these incorrectly addresed email once they go into that email account incoorect@anyone.com I didn't see a forward tab so I could see what is comnig into that accoiunt account.
Thank you.
Top
 Profile
 Post subject:
PostPosted: 2007-03-16 22:30
Not sure what you mean now. Either you configure your email client to download messages from this account as well. Or you specify yourownadderss@yourdomain.com as catch-all address, and all messages sent to invalid addresses will be forwarded to you.
Top
 Profile
 Post subject: Catch all
PostPosted: 2007-03-16 22:38
Nartin,
Sorry for the confusion I'll have to think how to word this so it is plain and doesn't waste your time. I'll be back soon.
Thank you. :(
Top
 Profile
 Post subject:
PostPosted: 2007-03-16 22:42
Hehe, you're not wasting my time. But it's probably more efficient for yourself if you read the documentation and then test the functionality. It won't hurt you. :)
Top
 Profile
 Post subject:
PostPosted: 2007-03-23 08:19
Not sure if this was ever resolved, but I ran into this issue as well. The documentation does cover it, but it does seem a bit confusing, especially if you have a bit more complicated setup.
At first I wasn't using an SMTP relay and with that setup I really didn't need to make any changes other than domain, host, etc.
However, if I switch to using the SMTP relay to my ISP's host (so outgoing email doesn't end up in a Junk Mail folder due to dynamic IP) it gets a bit confusing. My ISP doesn't require authentication for their SMTP server. With this in mind, you wouldn't think anything else would need to be set, but you would be wrong.
hMailServer is set by default to require SMTP authentication on the External to External Internet IP range. With that set, you do need to set your email client (Outlook, etc.) to require authentication. The username and password you select in your email client will be the one you used in hMailServer account, not the one for your ISP (since it doesn't require it).
An alternative would be to disable the authentication on the External to External for the Internet IP range, but I would suggest that you do not for security reasons.
My problem was in setting the wrong username and password for authentication (I was trying my ISP account instead of my hMailServer account). I simply didn't think I needed to authenticate on my hMailServer since I didn't have authentication set in my SMTP settings there and my ISP's SMTP doesn't require it. I totally overlooked the IP Range settings since my previous setup worked without it.
The reason for this is because the previous setup would see an outgoing email as Internal to External. Using an SMTP Relay, that same email becomes an External to External since it has to route it through the relay.
I hope this helps understand this a bit more. It took me a bit of testing and scratching my head to figure it out. :)
Top
 Profile
 Post subject: Re: Error 530 SMTP authentication is required
PostPosted: 2009-08-19 02:16
having same issues regarding 530.
what i note, is that i have two names (eg. mail.domain.net & mail.domain2.com) -- as aliases under the "NAMES" tab for my primary domain (eg. MyDOMAIN.NET").
when i send to mail.domain.net -- all is okay.
when i send to the second, mail.domain2.com -- it fails with the 530
(as a footnote, in order to manage multiple domains so that the spf records match w/authentication, it would require the local.host setting to be soft and set on an account-level basis (at a minimum) versus a machine-level basis.)
Top
 Profile
PostPosted: 2009-08-19 02:41
Please do not re-use old threads. Please start a new thread.
Your footnote is incorrect.
http://www.hmailserver.com/documentatio ... sages_smtp
530 is requires authentication
Some useful information when you repost in a new thread will please include
The version of hMailserver you are using
What troubleshooting you have done
a detailed description of the error
some logs from when this error has occured
_________________
Documentation
Top
 Profile
Who is online
Search for:
