Automated Mailing List upgraded for 4.3
Spm
Post by Spm » 2007-03-01 21:30
Features
#Send Email to register on a distribution list.
#Send Email to be reomved from a distribution list.
#Mask Senders Email address.
#Works for version 4.3.1
Bugs
#sender receives a copy of the email they sent
How to use
Create a distribution List e.g Members manually add at least one user
Set Members List to Public * The scipt makes this list a private list any way!
change the admin password in the code below. Users can then subscribe to the disrtibution list by emailing the list with the word subscribe in the subject. They can also be removed from the lsit by having the word remove in the subject.
At the very top of the EventHandler.vbs file add the following
dim adminpassword
dim subscribeword
dim removeword
'Settings
adminpassword = "Your_hamail_admin_password_Here"
subscribeword = "subscribe"
removeword = "remove"
Next In the "OnAcceptMessage(oClient, oMessage)" section in EventHandlers.vbs and type
call signup_to_distributionList(domain, distribution list to join, mailing list name, oMessage)
e.g.
call signup_to_distributionList("domainname.co.uk", "distributionlist@domainname.co.uk", "name of distributionlistlist", oMessage)
   call signup_to_distributionList("otherdomainname.com", "members@otherdomainname.com", "Name of Members Mailinglist", oMessage)
then add the following code to the EventHandlers.vbs
Sub signup_to_distributionList(strDomain, distrtojoin, mailinglistname, oMessage)
	dim oMessagereply
	dim q
	dim rejectMessage
	dim htmlrejectMessage
	If InStr(oMessage.To, distrtojoin) Then
		'Check that domain exist
		Set oDomain    = GetDomainObjectByName(strDomain)
		If (oDomain is Nothing) Then
			WriteLog "Can't find the domain " + strDomain
	   'Check If Distribution List exists
	   Set oDList    = GetDistributionListObject(strDomain, distrtojoin)
		'Check If sender is in distribution List
		If InDistributionListObject(oDList, oMessage.fromaddress) or CleanAddress(oMessage.fromaddress)=distrtojoin Then
			'User Exisitsin List
			'If the subject has remove written in it then remove user
			If InStr(lcase(oMessage.Subject), removeword) Then
				'Remove email address from distribution list
					   address             = CleanAddress(oMessage.fromaddress)
					   qtyRecipients      = oDList.Recipients.Count
					   Set oRecipients    = oDList.Recipients
					   For iRecipient = 0 to qtyRecipients-1
					      If (address = CleanAddress(oRecipients(iRecipient).RecipientAddress)) Then
						oRecipients.DeleteByDBID( oRecipients(iRecipient).ID )
					        'Exit Function
					   q=chr(34)
						dim ByeMessage, HTMLByeMessage
						ByeMessage   = "Thank you for using "+ mailinglistname + " " & vbCRLF & vbCRLF
						HTMLByeMessage   = replace(ByeMessage,vbCRLF,"<br>")
						if oMessage.HasBodyType("text/html") Then
							oMessage.HTMLBody = HTMLByeMessage & oMessage.HTMLBody
						ELSE
							oMessage.body   = ByeMessage & oMessage.body
						oMessage.Subject = "Your address has been removed from " + distrtojoin
						oMessage.Save()
						oMessage.ClearRecipients()
						call oMessage.AddRecipient("", oMessage.FromAddress)
						oMessage.Save()
			ELSE
				'Send email to list
				 				 WriteLog "oMessage.FromAddress :" + oMessage.FromAddress
				 dim Signature, HTMLSignature
				Signature   = vbCRLF & vbCRLF & "To be removed from " + mailinglistname + ". " & vbCRLF & vbCRLF & "Simply send an email to " + distrtojoin + " with the word remove as the subject." & vbCRLF & vbCRLF
				HTMLSignature   = replace(Signature,vbCRLF,"<br></BODY>")
					oMessage.HTMLBody = replace(oMessage.HTMLBody,"</body>","") + HTMLSignature
				ELSE
					oMessage.body   = oMessage.body + Signature
				 oMessage.From = replace(oMessage.From,oMessage.Fromaddress, distrtojoin)
			END IF
		ELSE
			' User not in list
			If InStr(lcase(oMessage.Subject), subscribeword) Then
				Call AddDistributionListRecipient(oMessage.fromaddress, distrtojoin, strDomain)
				WriteLog fromaddress + " has been added"
				'Send Welcome Message
				q=chr(34)
				dim WelcomeMessage, HTMLWelcomMessage
				WelcomeMessage   = "Welcome to " + mailinglistname + ". " & vbCRLF & vbCRLF & "If you would like to be removed please send an email to " + distrtojoin + " with the word remove as the subject." & vbCRLF & vbCRLF
				HTMLWelcomeMessage   = replace(WelcomeMessage,vbCRLF,"<br>")
					oMessage.HTMLBody = HTMLWelcomeMessage & oMessage.HTMLBody
				ELSE
					oMessage.body   = WelcomeMessage & oMessage.body
				oMessage.Subject = "Your address has been added to " + distrtojoin
				oMessage.Save()
				oMessage.Save()
			ELSE
				'Drop email Email
				q=chr(34)
				rejectMessage   = "Rejected because you are not authorised to send to this email address" & vbCRLF & vbCRLF
				HTMLrejectMessage   = "Rejected because you are not authorised to send to this email address<br><br>"
					oMessage.HTMLBody = HTMLrejectMessage & oMessage.HTMLBody
				ELSE
					oMessage.body   = rejectMessage & oMessage.body
				oMessage.Subject = "Rejected: " + oMessage.Subject
				oMessage.Save()
				oMessage.Save()
			END IF
			WriteLog fromaddress + " is not in the distribution list"
	END IF
END SUb
Sub AddDistributionListRecipient(strRecipientAddress, strRecipientListAddress, strDomain)
	'WriteLog "AddDistributionListRecipient " + strRecipientAddress + " - " + strRecipientListAddress + " - " + strDomain
	Dim obApp
		' Authenticate. Without doing this, we won't have permission
		' to change any server settings or add any objects to the
		' installation.
		Call obBaseApp.Authenticate("Administrator", adminpassword)
	Dim obBaseApp
	Dim obDomain
	Dim obDistributionLists
	Dim obDistributionListRecipients
	Dim obNewDistributionListRecipient
	'Set obBaseApp = CreateObject("hMailServer.Application")
	Set obDomain = obBaseApp.Domains.ItemByName(strDomain)
	Set obDistributionLists = obDomain.DistributionLists
	Set obDistributionList = obDistributionLists.ItemByAddress(strRecipientListAddress)
	Set obDistributionListRecipients = obDistributionList.Recipients
	Set obNewDistributionListRecipient = obDistributionListRecipients.Add()
	obNewDistributionListRecipient.RecipientAddress = CleanAddress(strRecipientAddress)
	'recipientAddress
	obNewDistributionListRecipient.Save()
	'saves distributionListRecipient
	Set obNewDistributionListRecipient = Nothing
	Set obDistributionListRecipients = Nothing
	Set obDistributionList = Nothing
	Set obDistributionLists = Nothing
	Set obDomain = Nothing
' CleanAddress
' Do anything necessary to "clean up" an address:
'   1) make it lower case
'   2) remove angle brackets if any
' Clean addresses should be able to be compared to each other
' Usage:
'    If (CleanAddress(oMessage.FromAddress) = "joe@foo.com") Then
'      EventLog.Write("yes this is from Joe")
'    End If
' Returns the cleaned address
Function CleanAddress(originaladdress)
   address      = originaladdress
   ' remove any white space
   address         = Trim(address)
   ' make the address lower case
   address         = Lcase(address)
   ' remove a leading angle bracket
   pos      = InStrRev(address, "<")
   If (pos > 0) Then
      address      = Mid(address, pos+1)
   End IF
   ' remove a traiing angle bracket
   pos      = InStrRev(address, ">")
   If (pos > 0) Then
      address      = Mid(address, 1, pos-1)
   ' remove any white space again
   ' return the now-clean address
   CleanAddress   = address
' GetDomainObjectByName
' Returns the Domain object for the specified domain name
' Returns 'Nothing' if the domain can't be found
' usage:
'    Set oDomain    = GetDomainObjectByName("widgets.com")
'    If (oDomain is Nothing) Then
'        EventLog.Write("Can't find the domain widgets.com")
'    End If
Function GetDomainObjectByName(domain)
   Dim iDomain
   Dim oApp
   Dim oDomain
   Dim oDomains
   Dim qtyDomains
   ' get the application object
   Call oApp.Authenticate("Administrator", adminpassword)
   ' get the Domains object
   Set oDomains        = oApp.Domains
   ' get the number of domains
   qtyDomains          = oDomains.Count
   For  iDomain = 0 to qtyDomains-1
      Set oDomain         = oDomains.Item(iDomain)
      If (Lcase(oDomain.Name) = Lcase(domain)) Then
         ' found it!  return the index number
         Set GetDomainObjectByName   = oDomain
         Exit Function
   ' failure - domain not found
   Set GetDomainObjectByName      = Nothing
Function GetDistributionListObject(domainName, listName)
   Dim iList
   Dim oDistributionList
   Dim oDomain
   Dim qtyDistLists
   ' get the domain object
   Set oDomain         = GetDomainObjectByName(domainName)
   If (oDomain Is Nothing) Then
      GetDistributionListObject      = Nothing
      Exit Function
   qtyDistLists        = oDomain.DistributionLists.Count
   For  iList = 0 to qtyDistLists-1
      Set oDistributionlist   = oDomain.DistributionLists(iList)
      If (oDistributionList.Address = listName) Then
         Set GetDistributionListObject   = oDistributionlist
         Exit Function
' InDistributionListObject
' Tests if an email address is in a distribution list object
' Usage:
'    If InDistributionListObject(oDList, oMessage.FromAddress) Then
'        EventLog.Write(oMessage.FromAddress & " is in the distribution list")
'    End If
' Returns 1 if the address is in the distribution list
' Returns 0 if it is not
Function InDistributionListObject(oDistributionList, address)
   ' make address lower-case, etc
   address             = CleanAddress(address)
   qtyRecipients      = oDistributionList.Recipients.Count
   Set oRecipients    = oDistributionlist.Recipients
         InDistributionListObject   = 1
         Exit Function
   InDistributionListObject   = 0
Sub WriteLog( cString)
      SET ofs = CreateObject("scripting.filesystemobject")
      SET ofil = ofs.OpenTextFile( "C:\Program Files\hMailServer\Logs\stephen.log", 8, True)
      ofil.writeline( Now & " - " & cString)
      oFil.close
      SET ofil=nothing
      SET ofs = nothing
end sub
SUB SendMessage(toaddress,fromname,fromaddress,subject,messagebdy)
	dim oMessage
	oMessage.From = fromname & " <"& fromaddress & ">"
	oMessage.FromAddress = fromaddress
	oMessage.Subject = subject
	oMessage.AddRecipient toaddress
	oMessage.Body = messagebdy
END SUB
bgssgk
Post by bgssgk » 2007-04-04 23:00
Is there a way to limit who can send to the list, like the announce only type, I've got everything working as described but I only want one address to be able to post to the list.
Post by ^DooM^ » 2007-04-04 23:01
In the distribution list options in hmail admin you can setup who is allowed to post to the list.
bgssgk
Post by bgssgk » 2007-04-04 23:10
I did try that but i believe it broke the script above, as i could not do anything afterwards.
Spm
Post by Spm » 2007-04-05 12:55
The script drops any mail to people who are not inthe distribution list. You need to leave the securtiy option in hmail off otherwise new members can not register.
If you would like remove the drop featire so that it is just a normal distrubtion list that anyone can email then I can re-write the script for you! But you would still not be able to use the security features in hmail.
Let me know if you need any more help.
Spm
Post by Spm » 2007-04-05 13:17
bgssgk wrote:Is there a way to limit who can send to the list, like the announce only type, I've got everything working as described but I only want one address to be able to post to the list.
I could do this for you it will take some time as I do not have alot of time on my hands just now (trying to get my house on the market to sell)
If you want to have a crack at it your self you will need to find this section of code
		ELSE
				'Send email to list
				ELSE
        END IF
then replace it with
 	ELSE
			IF oMessage.fromaddress = "me@mydomain.com" then
				'Send email to list
				ELSE
			 ELSE
				 'Drop email Email
				q=chr(34)
				ELSE
				oMessage.Save()
				oMessage.Save()
			END IF
         END IF
I have not tested this but in theroy that is all you should need to do.
bgssgk
Post by bgssgk » 2007-04-05 21:15
I'm sure I can work with that thanks for the help and good luck with the house, mines been on the market for a year :(
Spm
Post by Spm » 2007-04-06 00:02
bgssgk wrote:I'm sure I can work with that thanks for the help and good luck with the house, mines been on the market for a year :(
Damn thats not that great. the house down the road went in a week and we are in a bad area so I am just hoping. Thanks good luck. Let me know how you get on if you run into probs i'll try and help
Thomas Parvais
compatible with Release 4.4 ?
Post by Thomas Parvais » 2007-05-15 11:35
Hello, is your script compatible with Release 4.4 ?
Finally, what should we do to implement a newsletter distribution list ?
Tx
Thomas
Spm
Post by Spm » 2007-05-19 17:34
Yes it should be. the only reason ppl have revised script for version 4.3 is that hmail was made more secure with vesion 4.3 so additional code was required for scripts.
Sorry for the delay in repling but my email was down! (not hmail) but a pop3 to SMTP collector I am using.
AJB111
Re: Automated Mailing List upgraded for 4.3
Post by AJB111 » 2008-05-20 07:35
Hi Everyone
Just struggling with this script.
I keep getting the 550 Not authorized error.
The DL is set to Active
The DL is set to Announcments,
The allowed email IS set and it exists
The DL email address is NOT set in the Accounts or Aliases
Authentication is NOT set
Even if I create a member manually and then try to subscribe again (which is handled by the script)
I still get the 550 Not Authorised error.
I must have tried 100 times with different accounts etc, have checked the script settings and admin password
Nothing I do allows a person to subscribe by email - you simply get the 550 Not authorized error every time
Any help appreciated, I can not see what I am doing wrong
TIA, JB
Windows Server 2003, IIS6
HMail Server 5.3.1 B1748
MySQL 5.0.67
Spm
Post by Spm » 2008-05-20 13:52
DL should be set to Public
I never tested the script with Membership or announcements as when I wrote the script these features were not available.
Also to help debug you will find this section in the script
      oFil.close
      SET ofil=nothing
      SET ofs = nothing
end sub
open "C:\Program Files\hMailServer\Logs\stephen.log" and reveiw the log to see what the issue is or even email me the log!
