Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: Cannot Browse using http://127.0.0.1:55555
PostPosted: 2006-12-27 03:39
I just finished intalling hmailserver 4.3 and assp using the how to
instuctions for assp. The only problem I have for now is connecting to the
configuration page for assp using http://127.0.0.1:55555. What I am getting is Cannot Display the Web Page. Assp and hmailserver is running on Windows Server 2003 with IE 7.0
Any help would be much appreicated.
Karl
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 03:46
Have you checked to see if the service "Anti-Spam Smtp Proxy" is running?
I assume you are accessing the webpage on the server that ASSP is installed.
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 03:58
Thanks for the reply. Yes the "Anti-Spam Smtp Proxy" is running which i check in Comuter Management - Services and yes I am accessing the webpage on the server that ASSP in intalled
Karl
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 06:14
Do you have a firewall? Perhaps try disabling it.
Try running this in the command prompt on the server to see if ASSP web configuration application is running on port 55555.
netstat -a | find ":55555"
You should get a response similar to this...
TCP myserver:55555 myserver.somewhere.com:0 LISTENING
You should also try posting in the ASSP Help forums.
http://sourceforge.net/forum/forum.php?forum_id=235333
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 06:54
Hello Raymond,
Thanks for your reply. I tried your suggestion using nestat and what I got
was TCP myserver:55555 myserver:0 Listening
I do have a firewall which is ISA 2004. This firewall is located in front of the system.
Karl
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 08:16
Did you follow the ASSP howto from the following link?
http://www.asspsmtp.org/wiki/Quick_Start_for_Win32
The ASSP installation howtos located in this forum are ... out of date.
Also check your Perl version. You will need at least Perl 5.8 for the webinterface to work.
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 17:35
Hi Raymond,
Once again, thanks for your reply. I did what you suggested with installing
the lastest Active Perl 5.8. The installion went well.
The problem I have now is with the Anti-Spam Smtp Proxy Service. When I try to start the service I get and error.
Could not start the Anti-Spam Smtp Proxy Service on local computer. Error 1053: The service did not respond to the start or control request in a timely fashion.
How would I go about removing the service and reintalling it?
Karl
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 23:37
you should go to andersonit.com and download and install the assp msi installer package...and then upgrade with the latest upgrade version of assp...
i've never been able to get a working upgrade without configuring the andersonit version first...
good luck...i've installed assp on windows 40+ times in this manner with 100% success....
Top
 Profile
 Post subject:
PostPosted: 2006-12-27 23:53
Code:
perl addservice.pl -u
Type this command in the C:\ASSP folder to uninstall the service.
Code:
perl addservice.pl -i c:\assp\assp.pl c:\assp
And then this to reinstall.
Top
 Profile
 Post subject:
PostPosted: 2006-12-28 01:41
I would like to thank you all for your help. You guys have been great.
Using raymond's suggestions I was able to get it all running. I guess the
latest perl "5.8" was the answer and the removing of the service and reinstalling worked.
I would like to make a suggestion. the article http://www.hmailserver.com/forum/viewto ... light=assp
should be modified to say install version 5.8 and not 5.6.
Karl
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
