I'm not having any large attachment problems with ASSP. I started a new thread in the off topic area to see if we can get to the bottom of this. ASSP works so good, lets see if we can get any bugs worked out
http://www.hmailserver.com/forum/viewtopic.php?t=422
Jason
Attachment upload speed
- Jason Weir
- Normal user
- Contact:
Sorry Martin,
you can remove tracker 149&150 I ran some proper tests...
summary...
1. Sending through ASSP(no Clam)>Worldmail running on ol' pentium = 17 minutes 25s. (don't even bother with clam on, she can't take it captain).
2. Sending direct to Worldmail running on ol' pentium = 40s
3. Receiving from worldmail running on ol' pentium = 25s.
4. Sending through ASSP(no Clam)>hMailserver on Sledgehammer = 21s
5. Sending through ASSP(Clam)>hMailserver on Sledgehammer = 2min 44s.
6. Sending direct to hMailserver on Sledgehammer = 10s.
7. Recieving from hMailserver on Sledgehammer = 3s.
Now bear in mind that all the send times include encoding in outlook and moving the email their respective folders, this was consistent at around 6-7s.
but speed increases are of course always welcome
summary...
i sent 3 files that was 20mb to my hmailserver from a different network..so it was using the internet the whole way...my upload speed was checked to be at my max...around 67kb/s...and i checked my server containing hmailserver..and it was still running smoothly...no big jump of ram usage from hmailserver...it just took a while to send cuz the file was sooo big
the only thing i noticed was that perl was using 35mb ram and apache using like 24mb....but i just checked again..like after several hours i sent the large test email, and the ram usage is at the same place...so not sure if that is relevant or not...
- Normal user
- Contact:
yes, i too experienced elevated ram useage which did not decrease after use.
Checking server resources tonight I noticed hmail at 143Mb. After restarting the service it returned to 4Mb.
Has anyone else looked at the three tests I've performed and were they able to recreate this?
I'm worried of the 12 minutes it takes for OE to handle a message, when it only takes 1.3 for SM and 1.1 for thunderbird. Something isn't right.
Just empty your log for the day and enable smtp filtering. Send a 20 meg file and check it after it completes it send with SM, OE and another mail ap such as thunderbird. Compare the times of the first connection to the 'message queued' line. That will give you a precise difference in time. People should be getting the same ratio as what I've been getting - with deviations dependant on your network speed and server power.
Lastly, compare these with simple file transfer speed capabilities.
Everything up to this point has been relative. If anyone has any other suggestions on what I might try to improve upload speeds, I'm all ears. Thanks for your efforts all. I'm sure we can fix this.
The new version is up. Would be interesting to compare some numbers.
On my computer, a delivery of a 25 mb attachment takes about 8 seconds.
There's a new setting in hmailserver.ini:
This settings says how many bytes the internal buffer should be when sending and receiving data. If it's not set, the default value is 40 000. If I increase this value from 40 000 to 100 000, the above delivery takes 5 seconds instead of 8. Changing the value requires server restart.
(I'm not sure what the best default value for this setting is yet. The higher the default value, the more memory will the server use. )
The new version also includes a small feature in the logs. The message queued now looks like this:
(The time is the time it took for the data to be delivered from the client to the server.)
I suggest you try the new version and try to send the message with OE again. And check the Message queued line for the exact delivery time.
[Settings]
SocketBufferSize=40000
250 Message queued (6.159 seconds)
- Normal user
- Contact:
- Normal user
- Contact:
UNBELIEVABLE!
Update:::
I've just tested the times for the latest hmailserver release and received great times and great results..
To get these results I installed Perl 5.6 instead of the 5.8 - couldn't tell you if this makes a difference because I also upgraded ASSP to Calvi's modded ASSP and I'm now using the HMail 25 build.
using the same attachment as the tests before along with the same Squirrelmail and Outlook E. Ii was able to attain the following results.
Hmailserver build 25 - ClamAv Scan
No ASSP
OE - 14.481 Seconds - down from 10 minutes!!!!
SM - 19.358 Seconds - down from a minute and a half.
John Calvi's ASSP Mod SMTP Proxy - No AV scan
OE - 87.806 seconds
SM - 90.600 seconds
Memory usage was constant at about 4.5Mb-7.5Mb
I can't tell you how pleased I am with these results. I can't thank Martin/John enough.
We just have to work on virus protection on hmail's side because I think it would handle it more efficiently than ASSP's integration with ClamAv which as we all know is notoriously slow.
Cheers - Pat
Update:::
No ASSP
OE - 87.806 seconds
SM - 90.600 seconds
Cheers - Pat
