Mails bigger than 5 MB wont get passed to spamd
steelworm
Post by steelworm » 2020-05-07 19:38
Hello there,
Whenever I receive a message bigger than 5 MB it wont get passed to spamd. This can be confirmed by looking at SA logs which do not state a connection from hmail. In addition to that in hmail's logs the typical "Sending message to SpamAssassin" record is also missing. I adjusted the "Maximum message size to scan" but this did not help. It also seems that no DKIM check has happened but only the following checks:
"DEBUG" 3784 "2020-05-03 02:23:58.172" "Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG" 3784 "2020-05-03 02:23:58.181" "Spam test: SpamTestHeloHost, Score: 0"
"DEBUG" 3784 "2020-05-03 02:23:58.181" "Spam test: SpamTestMXRecords, Score: 0"
"DEBUG" 3784 "2020-05-03 02:23:58.184" "Spam test: SpamTestSPF, Score: 0"
"DEBUG" 3784 "2020-05-03 02:23:58.185" "Total spam score: 0"
Re: Mails bigger than 5 MB wont get passed to spamd
Post by SorenR » 2020-05-07 20:49
hMailAdmin -> Settings -> Anti-Spam [General] : Maximum message size to scan (KB) = ?
steelworm
Post by steelworm » 2020-05-08 00:31
I have set it to 10MB which are 10.240 KB for the setting. So the mails in question which are about 5 to 6 MB should get scanned as all the others get which are <5 but they aren’t.
Post by jimimaseye » 2020-05-08 01:15
There is also a maximum size in spamassassin (500kb I think). Review spamassassin documentation for more information and how to increase.
steelworm
Post by steelworm » 2020-05-08 09:07
I already created an according spamc.conf. Do you think there might be an issue with that?
Post by jimimaseye » 2020-05-08 09:52
I will leave it to you to research and seek help with spamassassin configurations.
For hms: run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
Post by RvdH » 2020-05-10 14:36
spamc is only used for spam learning i think... hmailserver uses a internal client, i doubt this will read values from spamc.conf
Not sure what maxIterations is, hardcoded limit?
Post by SorenR » 2020-05-10 14:51
2020-05-10 14:36
Reading 20000 byte chunks for a maximum of 100000 times... 1.9 GB of data ?
      const int maxIterations = 100000;
      for (int i = 0; i < maxIterations; i++)
         std::shared_ptr<ByteBuffer> pBuf = oFile.ReadChunk(20000);
         if (pBuf->GetSize() == 0)
            break;
         BYTE *pSendBuffer = (BYTE*) pBuf->GetBuffer();
         size_t iSendBufferSize = pBuf->GetSize();
         EnqueueWrite(pBuf);
Post by RvdH » 2020-05-10 15:30
Looks a bit exuberant, isn't? ;)
Anyway, this is controlled/overruled by Maximum message size to scan (KB) in hmailserver settings, so if that value is reasonable it will never reach this 1.9GB
Post by katip » 2020-05-10 22:57
in fact, there is a setting for spamc
    -s *max_size*, --max-size=*max_size*
        Set the maximum message size which will be sent to spamd -- any
        bigger than this threshold and the message will be returned
        unprocessed (default: 500 KB). If spamc gets handed a message bigger
        than this, it won't be passed to spamd. The maximum message size is
        256 MB.
        The size is specified in bytes, as a positive integer greater than
        0. For example, -s 500000.
i have no idea where to place a spamc.conf in a JAM SA installation (and if it ever works). root probably??
but this should be irrelevant. OP means, mail never gets queued to SA, according to logs.
Post by RvdH » 2020-05-11 13:54
katip wrote:
2020-05-10 22:57
        256 MB.
Duh....only hMailServer doesn't use it clamc, but has a build in client :lol: :wink:
